Atari Punk Pots
Page 3 of 5 [105 Posts]
frijitz
Audio files: 54
PostPosted: Wed Jul 11, 2007 8:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Wild Zebra wrote:
And this is not intented to be combative, but I don't think you can call 6 working builds from the same layout luck.
Sorry, but a given device from different manufacturers may not behave identically. This is well known. Usually it is not a problem if the device is used as intended, but can show up in nonstandard designs. The gate of the reset transistor may be somehow biased up in the batch of chips you have, but not in others. But the designers certainly did not intend for it to be left floating.
I don't want to be combative either, but I have been designing with this chip for over 30 years, and I hope that counts for something. I posted on this thread because I thought I had a solution to a problem several people were having. If not, then I apologize for misunderstanding.
I'll leave now.
Wild Zebra
PostPosted: Wed Jul 11, 2007 8:42 am    Post subject: Reply with quote  Mark this post and the followings unread
I'll leave now.
it's cool, we're both trying to do the same thing. Help. You obviously have waaaay more experience than I do. I'm a paint by numbers, kinda know some things, does it sound like it suppose to, guy. I built six working units from the same layout I hope that counts for something. We're just bothtrying to help from different directions. Sorry it came off bad. This is the first time I've ever had to defend myself in a thread.
So back to helping. I truly didn't mean to offend you
Wild (little fish in a big pond) Zebra
"your stripes are killer bro"
moondogsunra
PostPosted: Wed Sep 05, 2007 1:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
I know some time has past and Im bringing up a dead post....... however, im a newb and cant sem to get my 556 based APC working. My question is what do I do with all of those grounds specified on the schematics. I'm not familiar with routing things to grounds, what is the best method to insure success? Where does the other wire for the power go, and the line out, etc?
Thanks in advance for your help,
newb
Danno Gee Ray
PostPosted: Wed Sep 05, 2007 2:40 pm    Post subject:
Subject description: Grounds
In a basic DC circuit like the APC, the grounds are just a common point of connection. Usually the negative connection for the battery is also connected to ground which completes the electrical circuit. try running wires from all the ground points on the schematic to the place where the negative terminal of the battery is connected and see if it works then.
loss1234
PostPosted: Wed Sep 05, 2007 2:43 pm    Post subject: hmmmm Reply with quote  Mark this post and the followings unread
i got this to work without any problems. i am trying to remember which layout i used but it worked pretty easy once i figured out how to wire the pots.
if anybody still is having problems i might be able to help
dan
oootini
PostPosted: Mon Oct 15, 2007 4:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Does anybody have a vero layout for the 556 APC? the one listed in this thread has been taken down. I can’t seem to find any online. I’ve tried and failed to build the dual 555 apc. I’d really like to finish an apc successfully. I don’t know enough about circuits to attempt building a vero version from the PCB layout. Can someone help? I would be eternally grateful…
Danno Gee Ray
PostPosted: Mon Oct 15, 2007 7:07 am    Post subject: Reply with quote  Mark this post and the followings unread
I found these.
 Filesize:  60.75 KB
 Viewed:  37041 Time(s)
 Filesize:  8.12 KB
 Viewed:  37042 Time(s)
 Filesize:  84.34 KB
 Viewed:  606 Time(s)
oootini
PostPosted: Mon Oct 15, 2007 7:34 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks. i've found those diagrams too. the thing is that i'd like to see a vero layout for the 556 APC because i don't want to try and make a 556 vero one based on the above diagrams in case i get it wrong again...
para
PostPosted: Mon Oct 15, 2007 11:19 am    Post subject: Reply with quote  Mark this post and the followings unread
there is this too
http://thesquarewaveparade.com/brdlayot.html
steven
oootini
PostPosted: Tue Oct 16, 2007 4:39 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks for all these suggestions. it's a veroboard diagram i am looking for because i'm not confident enough to try and turn a circuit diagram into a vero layout...
para
PostPosted: Tue Oct 16, 2007 2:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
for the APC? just use this http://www.storm-software.co.yu/diy/forums.html?project=software
its free but can get slow
steven
oootini
PostPosted: Wed Oct 17, 2007 2:24 am    Post subject: Reply with quote  Mark this post and the followings unread
steven
cool, thanks!
i think i'm gonna try that program and post it up the results here...hopefully any mistakes i make in the layout can be pointed out by you helpful knowledgeable types Very Happy .
but if any of you guys have the vero layout from the first page of this thread please post it up...
fanks.
para
PostPosted: Wed Oct 17, 2007 6:24 am    Post subject: Reply with quote  Mark this post and the followings unread
you should still learn how to use that program though it will make future projects easier
steven
 Filesize:  27.2 KB
 Viewed:  36938 Time(s)
 Filesize:  30.82 KB
 Viewed:  647 Time(s)
oootini
PostPosted: Wed Oct 17, 2007 7:03 am    Post subject: Reply with quote  Mark this post and the followings unread
cheerss steven. that second one was what i was looking for. i know what your saying about getting my head around circuits. for a first project i just wanna make some cool noises without worrying about how their made. thanks again...
bikini-inspector
PostPosted: Thu Nov 29, 2007 1:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
sorry bout bringing up an old thread again, but i am desperate maybe someone around here can help me.
i started building the apc about a week ago. i started off with the parts list from nateMC and tried to imitate the layout he used, as far as i could recognize it from the photos.
the result didn't do anything at all, even the LED didn't work. Sad
So i checked if i had all the jumpers in the right place and if all the other connections were correct. I used the schematic from worth_ekik as a reference.
after i was finished i had a half-working unit that only spit out sounds at one sweet spot. With other pot settings, it produced a lot of static and only very low volume. Confused
the second problem was that as soon as i tried to put the sound through an amp, it was dead and the only sound that came through was the "thump!" of the power switch.
The next thing i did was i disassembled the whole thing. Meanwhile i found it really annoying, but i didn't want to give up on the project.
so when i reassembled the lil f*cker Mad i did it exactly the way i read it from Worth_Ekik's schematic. Because this schematic is a lot smaller in size, and i found out that the electronics dude gave me a wrong cap for "C2", i found it pretty sweet and was confident that it would finally work.....for about 2 minutes. Crying or Very sad
now the pots work allright (after i bought a new set, because my lack of soldering skills ruined the old ones), the sound is good and i think i have the full range of the pots.
But still, there is no way to amplify the sound! i can only listen to it via headphone.
i have a small "homebuild" guitar amp that i can switch from passive to active (i can use it as a speaker or an amp) which works fine in passive mode. as soon as i switch it off, the apc doesn't work (or maybe it does, but i can't hear it)
can anyone help me with this problem? I guarantee eternal gratitude and would even be willing to name my firstborn child after the genious that saved me from dumping the entire thing into a lake of sulphuric acid, after roasting it alive over pile of burning cow dung.
Please Please Please
Ben
para
PostPosted: Thu Nov 29, 2007 2:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
what made you think that the apc could drive a large speaker all by itself?you will need an amp. it may drive a tiny little speaker but i can't imagine it would sound good.
there are amp circuits all over the place like the ruby and gem http://www.runoffgroove.com/articles.html
s
bikini-inspector
PostPosted: Thu Nov 29, 2007 4:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
yeah i know that
it can power headphones, though, which works just fine.
when i plug the apc into an amp, there is no output at all(except for a "thump!" when i hit the power switch)
any ideas what i might have done wrong?
sorry if my post was a little confusing...it's late around here
para
PostPosted: Thu Nov 29, 2007 5:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
it was
maybe you have the tip and sleeve on the output jack backwards? hard to say
steven
bikini-inspector
PostPosted: Thu Nov 29, 2007 6:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Embarassed
its working now!
i checked if i had mixed up the output cables, which wasnt the case
BUT
to do so i had to desolder the ground connection because i needed a better overview.
I forgot to switch off the apc, and when the soldering iron touched the ground-bus it worked!
so i knew there was something wrong with the way i connected ground. Turns out I simply forgot to connect pin 7 to ground.
d'oh
Embarassed shame on me Embarassed
sorry i made such a fuzz around a noob mistake, but if it wasnt for you i'd still be desperate.
so thank you thank you thank you cheeeezeeey
PS: I hope my first born child is a boy, steven isnt the ideal name for a girl Wink
para
PostPosted: Thu Nov 29, 2007 7:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
well as i was growing up my family shared a pretty cruel sense of humor so i was often called Stephanie. maybe that will work out better
just glad you got it working
steven
danielwarner
PostPosted: Thu Nov 29, 2007 11:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
The easiest way to get this circuit to work is probably to use the original Forrest Mims schematic and ignore the various PCB/perfboard layouts and various circuit hacks floating around until you've first got the circuit working on a breadboard. Some of the PCB/perfboard layouts floating around for various circuits haven't even been tested! WORTH_EKIK's site, for example, provides several PCB layouts that haven't been tested, and I find that site very useful and full of good information, but I wouldn't etch and populate a PCB or perfboard layout that had not been tested. You're just asking for troubleshooting. Wink
Jgleeks
PostPosted: Fri Nov 30, 2007 11:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Folks,
I`ve built the APC on a breadboard using this design, but sadly, along with many others using various schematics, I can`t get it to work. Confused
Can someone cast a quick eye at it and tell me if it`s correct Question
Thanks in advance
danielwarner
PostPosted: Sat Dec 01, 2007 5:08 am    Post subject: Reply with quote  Mark this post and the followings unread
In the original schematic
a) pin four is tied to the positive rail
b) pin two is tied to pin six
Jgleeks
PostPosted: Sat Dec 01, 2007 6:36 am    Post subject: Reply with quote  Mark this post and the followings unread
many thanks for that.
Just tried it and it still doesn`t work Confused not a sound at all
Maybe the chip got fried while it was incorrectly wired, I`ll get another and retry.
This really is quite annoying for a simple circuit!!
Jgleeks
PostPosted: Tue Dec 04, 2007 3:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Tried it with a new chip, but to no avail - I`d advise anyone looking to ignore the breadboard circuit I posted above as it doesn`t seem to work (unless it`s me got a component wrong!)
