Scott Stites
Audio files: 96
Posted: Sat Oct 13, 2007 10:02 am Post subject:
Oh, that's good! I suppose this means, however, you're probably not getting to the moon....  _________________ My Site |
germaniac
Posted: Sat Oct 13, 2007 10:52 am Post subject:
Happy to learn you're regaining "balance" and feeling better!
Wise man once say, Walk lightly and you'll walk long, so take it slow and easy. . . .
Regards,
Joe |
jhaible
Posted: Sun Oct 14, 2007 6:58 am Post subject:
v-un-v wrote: | Hey Jurgen have you had a chance to find any suitable LDR's yet?
Tom |
I'm starting to evaluate suitable LDRs again.
Right now, I have the Perkin Elmer M996011B in my focus.
It looks about right from the data and physical size.
While I'm going to test these some time next week, can anybody check the availibility from mail order shops outside Germany, and the USA in particular? (In Germany, it's available from Schuricht.)
Mind you, this is still completely untested.
JH. _________________ "I tell you the truth, if anyone says to this mountain, 'Go, throw yourself into the sea,' and does not doubt in his heart but believes that what he says will happen, it will be done for him. Therefore I tell you, whatever you ask for in prayer, believe that you have received it, and it will be yours." (Mk 11,23f) |
germaniac
Posted: Sun Oct 14, 2007 10:42 am Post subject:
Hey JH,
I think Perkin Elmer might be better known in the US as the "Vactrol" line, which is stocked by Allied Electronics. They carry lots of LDRs like these
But I don't find any part number resembling M996011B. Maybe a different part numbering scheme for US and Europe?
Regards,
Joe
[Edit Blue Hell: shortened the link] |
jhaible
Posted: Sun Oct 14, 2007 11:09 am Post subject:
That's the one I mean:
http://optoelectronics.perkinelmer.com/content/datasheets/dts_m9960.pdf
http://optoelectronics.perkinelmer.com/Catalog/Product.aspx?ProductID=M9960+11b
germaniac
Posted: Sun Oct 14, 2007 12:10 pm Post subject:
It doesn't look as though the PE flatpack LDRs are very available here--Google only delivers nine results, none of which is a small-quantity supplier in the US. Here's a comparison chart with everything PE makes, but I'm having trouble ( ) comparing the dissimilar spec parameters:
http://optoelectronics.perkinelmer.com/content/RelatedLinks/SpecificationSheets/SPC_Photocells.pdf
If the flatpacks turn out to be must-have, probably something more available here with similar on/off ohms, etc. could be found? |
jhaible
Posted: Sun Oct 14, 2007 12:56 pm Post subject:
germaniac wrote: | It doesn't look as though the PE flatpack LDRs are very available here--Google only delivers nine results, none of which is a small-quantity supplier in the US. Here's a comparison chart with everything PE makes, but I'm having trouble ( ) comparing the dissimilar spec parameters:
Flatpacks are not a must.
What I know by now: The lowest on-resistance you can get is probably right for this application.
So I've been looking for low Z, and things like NORP-12 (or even better, NORP-13) might work, but they are quite expensive and rather bulky. Then I found these flatpacks and their specs seem to be roughly in the right range, and they look so damn similar to the unmarked old surplus LDRs I've used 8 years ago, that I thought I will try these first.
Once I know there work (hopefully), we can simply match specs to find something similar.
As of now (before I've tried these), it's hard to tell, because I have no reference for measuring the light conditions for which LDRs are spec'ed.
jhaible
Posted: Thu Oct 18, 2007 1:48 pm Post subject:
jhaible wrote: | v-un-v wrote: | Hey Jurgen have you had a chance to find any suitable LDR's yet?
Tom |
JH. |
Got my samples today. They look the same, they measure the same. Gotta solder them in and listen, just to be 100% sure.
Then it will all be easy. Either I can match specs with other more available parts, or just try to buy a thousand of them. Or two thousand.
JH.
ETA: Bot sure about Bingo. See my next mail. _________________ "I tell you the truth, if anyone says to this mountain, 'Go, throw yourself into the sea,' and does not doubt in his heart but believes that what he says will happen, it will be done for him. Therefore I tell you, whatever you ask for in prayer, believe that you have received it, and it will be yours." (Mk 11,23f) Last edited by jhaible on Thu Oct 18, 2007 2:38 pm; edited 1 time in total |
Posted: Thu Oct 18, 2007 1:50 pm Post subject:
Superb!  _________________ ACHTUNG!
jhaible
Posted: Thu Oct 18, 2007 2:37 pm Post subject:
jhaible wrote: | jhaible wrote: | v-un-v wrote: | Hey Jurgen have you had a chance to find any suitable LDR's yet?
Tom |
JH. |
Bingo!
JH. |
Sorry - I was too fast.
The Perkin Elmer M996011B match the LDRs that gave good results on my new version of the CC. But apparently I have used others on th eold one. I just found some photos that hint in that direction. I'll have to dismantle it again to be sure.
Looks like I got tired and should stop working now.
Also, they give Ken Russel's "Gothic" on the TV tonight. Must go and watch it, probably for the 4th or 5th time. Awesome film.
See you tomorrow.
germaniac
Posted: Thu Oct 18, 2007 2:53 pm Post subject:
See you tomorrow.
JH. |
Ken Russell's "Lair Of The White Worm" is also lots of fun. Have not seen "Gothic" yet, but will check it out sometime.  |
Posted: Thu Oct 18, 2007 3:11 pm Post subject:
jhaible wrote: |
See you tomorrow.
'Gothic' is a classic!
It sounds like you got what I had over the summer- it really does. It goes away eventually but it takes ages. I was initially told it was Glandular Fever- but all the blood tests came back negative. I'm still getting mild dizzyness- especially when I get tired. _________________ ACHTUNG!
jhaible
Posted: Fri Oct 19, 2007 10:25 am Post subject:
Update
More pictures of the prototype:
http://www.jhaible.heim.at/compact_clone/compact_clone.html
jhaible
Posted: Fri Oct 19, 2007 10:27 am Post subject:
fluxmonkey
Posted: Fri Oct 19, 2007 11:46 am Post subject:
jhaible wrote: |
that is so damn sexy. |
Posted: Fri Oct 19, 2007 1:28 pm Post subject:
bbob wrote: |
you're telling me!  _________________ ACHTUNG!
Posted: Fri Oct 19, 2007 1:30 pm Post subject:
Oh yeah, the board has that Lauren Bacall look.  _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
jhaible
Posted: Fri Oct 19, 2007 1:43 pm Post subject:
Ha ha, sexy.
You have to hide these incandescent lamps inside, of course.
But did I mention there's a 3rd of these on the front panel?
It's in the red socket above the "Modulation" Knob in this picture:
http://home.debitel.net/user/jhaible/compact_clone1.jpg
Posted: Sat Oct 20, 2007 2:35 am Post subject:
jhaible wrote: | Ha ha, sexy.
Yes it's a shame that there really isn't such a thing as 1-way glass!  _________________ ACHTUNG!
Peake
Joined: Jun 29, 2007 Posts: 1113 Location: Loss Angeles
Posted: Sat Oct 20, 2007 8:40 am Post subject:
This is the kind of old-school technology that give me grins, relying on natural and varying rise and fall times... Kudos, Juergen! |
jhaible
Posted: Sat Oct 20, 2007 9:30 am Post subject:
Peake wrote: | This is the kind of old-school technology that give me grins, relying on natural and varying rise and fall times... Kudos, Juergen! |
Well the good thing is that with the incandescent lamps being so slow that they dominate the time constants, I don't have to worry that much about the time constants of the LDRs.
And the lamps, together with the control circuit, absolutely make a difference. I have a phaser setting in my Matrix FX that emulates the structure of the Compact A's audio path (which is quite unique, too), but not the incandescent lamp control, and something is clearly missing.
Posted: Sat Oct 20, 2007 10:16 am Post subject:
JH, I reckon you need to update your avatar with a pic of these bulbs!  _________________ ACHTUNG!
mono-poly
Joined: Jul 07, 2004 Posts: 937 Location: Rotterdam, Netherlands
Posted: Sat Oct 20, 2007 10:40 am Post subject:
So true! |
jhaible
Posted: Sat Oct 20, 2007 10:59 am Post subject:
v-un-v wrote: | JH, I reckon you need to update your avatar with a pic of these bulbs!  |
I made another demo; wanted to know how the effect sounds on Mellotron strings. Excuse my sloppy playing.
Setup is GMedia MTron -> Roland RE201 -> Compact Clone -> Quantec QRS
The Compact Clone still has the flatpack LDRs which give a too high idle setting of the pole frequencies. This will be cured later, either with larger capacitors, or with a different LDR type.
But I think that typical sweep waveform at th elow frequencies is already there.
JH.
Description: |
 Download (listen) |
Filename: |
jh_cc_mysterious_tron.mp3 |
Filesize: |
1.37 MB |
Downloaded: |
1217 Time(s) |
Peake
Posted: Sat Oct 20, 2007 8:51 pm Post subject:
You are about to be single-handedly responsible for a huge amount of new TD-ish space rock!
Sounding great! I can't wait.
You have a Quantec?  |
