 Forum index » Clavia Nord Modular » G2 Performances - Experimental
BigRedMonolith
Page 1 of 1 [10 Posts]
G2 patch files: 626
PostPosted: Thu Jul 08, 2004 4:17 pm    Post subject: BigRedMonolith Reply with quote  Mark this post and the followings unread
Some old experiments combined with new ideas and modules. Probably of note is the interaction between slots A+B. I had the idea that B could change variations on A, but that A controlled how long it was active by sending a return message to slot B (in this case by counting down triggers from B). The idea was to take some control back from the randomness. I guess it would be possible to extend the idea so that A could influence the selections made by B.
BigRedMonolith.prf2
Noodle by Ian Sayer
 Filename:  BigRedMonolith.prf2
 Filesize:  8.15 KB
 Downloaded:  1906 Time(s)
Audio files: 224
PostPosted: Fri Jul 09, 2004 8:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice one, Ian.
Wow, what a difference in sound quality from the G2 and the mp3 file!
G2 patch files: 626
PostPosted: Fri Jul 09, 2004 12:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Um, yes I updated the pch2. You know how it is, I uploaded the patch and mp3 then listened for a while. Just can't resist fiddling with it.
Normally I would not replace what I had already uploaded but this was a significant improvement (and being on GMT+12, I post when most people are in bed). I think maybe one or two people had downloaded the old version.
Some level reduction in the Slot C sounds but mainly the structure has been changed by introducing a second slower variation. Again, this change is made when slot A decides it is time. The mp3 is similar to the 'allegro' section so I have not replaced it.
I also find it difficult to choose which 60 seconds. Listening to a 'live' noodle is so different, so many unexpected surprises and subtle variations.
What we need is a noodle CD compilation =)
General Elektrick
PostPosted: Fri Jul 09, 2004 2:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
What we need is a noodle CD compilation =)[/quote]
Wink A Noodle compilation would be nice to join in and to listen to,
what is missing is the compiler Question Question Question
Nice noodle, Ian Exclamation
Best General Elektrick
G2 patch files: 626
PostPosted: Fri Jul 09, 2004 8:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, a volunteer to create the compilation, and everyone’s permission. Could the GNU public licence apply to patches? Great name for a record label though ‘GNU MUSIC’.
I also forgot to give credit to Howard, the patch in slot C uses his simple cross modulation concept described elsewhere. It is capable of a huge range of interesting sounds. I could have had some random lfo’s adjusting some things but I think it is best explored manually. Some of the effects exist only within a very narrow range of settings. I saved each ‘discovery’ into its own variation. Even with nothing but variation switching, some change character depending on which variation was selected before. Sometimes a nice chorus of bullfrogs, other times a demented tenor having an appendectomy without anaesthetic.
General Elektrick
PostPosted: Sat Jul 10, 2004 5:47 am    Post subject: Reply with quote  Mark this post and the followings unread
I think the permission would not be the problem.
Every noodle creator would like to be released or am I wrong?
I think i would be difficult to record the noodles, I sometime
record 10 minutes of noodle and still I am missing a lot of random variations i have heard before. Every Noodleist would have to make his own recording,
so he would be responsible for the choice. I remember some Ideas about a noodle compilation on the newslist, but nothing happend finally.
I could even imagine a double CD or vinyl, one dark and one chilly side of the noodles.
The GNU records is a nice name idea!
Dreaming about noodle soup Rolling Eyes
Best
General Elektrick
Audio files: 297
PostPosted: Sat Jul 10, 2004 11:36 am    Post subject: Reply with quote  Mark this post and the followings unread
But before re-inventing the wheel maybe have a look at http://www.ram.org/ramblings/philosophy/fmp.html
Sort of a GNU for music, otoh ... maybe noodles are prgrams and not music ?
Jan.
Audio files: 224
PostPosted: Sat Jul 10, 2004 8:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
There is an alternative to copyright, it is a lisence by Creative Commons. This is quite nice in that is provides some right to copy the music, but with restrictions - like you must not use the music for commercial purposes or for profit, you must always post the author when you post the music, etc. See:
http://creativecommons.org/
Fozzie
G2 patch files: 49
PostPosted: Sun Jul 11, 2004 11:10 am    Post subject: Reply with quote  Mark this post and the followings unread
there are competitors with compilations already in Dutch supermarkets
 Filesize:  10.32 KB
 Viewed:  10758 Time(s)
Audio files: 297
PostPosted: Sun Jul 11, 2004 11:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Hadn't listened to the patch uip to now, but now I do it will be on for a while.
It is hard to select indeed, this noodle has a lot of variiation. I guess an mp3 compilation DVD would be needed, a simple CD is just barely enough for one noodle of this kind :-)
Nice one !
Jan.
