 Forum index » Clavia Nord Modular » G2 Performances - Experimental
BigRedMonolith
Page 1 of 1 [10 Posts]
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Thu Jul 08, 2004 4:17 pm    Post subject: BigRedMonolith Reply with quote  Mark this post and the followings unread
Some old experiments combined with new ideas and modules. Probably of note is the interaction between slots A+B. I had the idea that B could change variations on A, but that A controlled how long it was active by sending a return message to slot B (in this case by counting down triggers from B). The idea was to take some control back from the randomness. I guess it would be possible to extend the idea so that A could influence the selections made by B.
BigRedMonolith.prf2
Noodle by Ian Sayer
 Filename:  BigRedMonolith.prf2
 Filesize:  8.15 KB
 Downloaded:  2130 Time(s)
Audio files: 235
PostPosted: Fri Jul 09, 2004 8:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice one, Ian.
Wow, what a difference in sound quality from the G2 and the mp3 file!
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Fri Jul 09, 2004 12:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Um, yes I updated the pch2. You know how it is, I uploaded the patch and mp3 then listened for a while. Just can't resist fiddling with it.
Normally I would not replace what I had already uploaded but this was a significant improvement (and being on GMT+12, I post when most people are in bed). I think maybe one or two people had downloaded the old version.
Some level reduction in the Slot C sounds but mainly the structure has been changed by introducing a second slower variation. Again, this change is made when slot A decides it is time. The mp3 is similar to the 'allegro' section so I have not replaced it.
I also find it difficult to choose which 60 seconds. Listening to a 'live' noodle is so different, so many unexpected surprises and subtle variations.
What we need is a noodle CD compilation =)
General Elektrick
PostPosted: Fri Jul 09, 2004 2:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
What we need is a noodle CD compilation =)[/quote]
Wink A Noodle compilation would be nice to join in and to listen to,
what is missing is the compiler Question Question Question
Nice noodle, Ian Exclamation
Best General Elektrick
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Fri Jul 09, 2004 8:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, a volunteer to create the compilation, and everyone’s permission. Could the GNU public licence apply to patches? Great name for a record label though ‘GNU MUSIC’.
I also forgot to give credit to Howard, the patch in slot C uses his simple cross modulation concept described elsewhere. It is capable of a huge range of interesting sounds. I could have had some random lfo’s adjusting some things but I think it is best explored manually. Some of the effects exist only within a very narrow range of settings. I saved each ‘discovery’ into its own variation. Even with nothing but variation switching, some change character depending on which variation was selected before. Sometimes a nice chorus of bullfrogs, other times a demented tenor having an appendectomy without anaesthetic.
General Elektrick
PostPosted: Sat Jul 10, 2004 5:47 am    Post subject: Reply with quote  Mark this post and the followings unread
I think the permission would not be the problem.
Every noodle creator would like to be released or am I wrong?
I think i would be difficult to record the noodles, I sometime
record 10 minutes of noodle and still I am missing a lot of random variations i have heard before. Every Noodleist would have to make his own recording,
so he would be responsible for the choice. I remember some Ideas about a noodle compilation on the newslist, but nothing happend finally.
I could even imagine a double CD or vinyl, one dark and one chilly side of the noodles.
The GNU records is a nice name idea!
Dreaming about noodle soup Rolling Eyes
Best
General Elektrick
PostPosted: Sat Jul 10, 2004 11:36 am    Post subject: Reply with quote  Mark this post and the followings unread
But before re-inventing the wheel maybe have a look at http://www.ram.org/ramblings/philosophy/fmp.html
Sort of a GNU for music, otoh ... maybe noodles are prgrams and not music ?
Jan.
Audio files: 235
PostPosted: Sat Jul 10, 2004 8:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
There is an alternative to copyright, it is a lisence by Creative Commons. This is quite nice in that is provides some right to copy the music, but with restrictions - like you must not use the music for commercial purposes or for profit, you must always post the author when you post the music, etc. See:
http://creativecommons.org/
Fozzie
G2 patch files: 49
PostPosted: Sun Jul 11, 2004 11:10 am    Post subject: Reply with quote  Mark this post and the followings unread
there are competitors with compilations already in Dutch supermarkets
 Filesize:  10.32 KB
 Viewed:  12378 Time(s)
PostPosted: Sun Jul 11, 2004 11:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Hadn't listened to the patch uip to now, but now I do it will be on for a while.
It is hard to select indeed, this noodle has a lot of variiation. I guess an mp3 compilation DVD would be needed, a simple CD is just barely enough for one noodle of this kind :-)
Nice one !
Jan.
