Clack
Joined: Aug 08, 2005 Posts: 438 Location: Walthamstow - london
Posted: Tue Nov 20, 2007 4:18 pm Post subject:
Mr clacks Dual Soundlab and Soundlab Mod PCB's |
Hey , Im almost finished my dual soundlab and thought I'd post some custom PCB's I made from Ray's mod circuits.
drum trigger
Tested and it works ( on 12-12v . It says TL074 but i'm using an LF444 ( No lf444 in eagle library , im sure both will work )
28.11 KB |
| Viewed: |
206 Time(s) |
 Download (listen) |
| Filename: |
Soundlab - Drum Trigger.pdf |
62.13 KB |
| Downloaded: |
217 Time(s) |
 Download (listen) |
| Filename: |
Drum trigger.zip |
3.99 KB |
| Downloaded: |
233 Time(s) |
_________________ Clacktronics.co.uk Last edited by Clack on Fri Nov 23, 2007 2:55 am; edited 3 times in total |
Posted: Tue Nov 20, 2007 4:30 pm Post subject:
Hey nice!
Have you sent this to Ray? I'm sure he would dig this  _________________ ACHTUNG!
Clack
Lemmy
Posted: Thu Nov 22, 2007 2:23 pm Post subject:
| wow, looks great! |
Pehr
Joined: Aug 14, 2005 Posts: 1307 Location: Björkvik, Sweden
gubbeper
Posted: Mon Nov 26, 2007 12:04 am Post subject:
Looks really nice!  _________________ /Per
I'm on Twitter |
Posted: Mon Nov 26, 2007 1:19 am Post subject:
Yes, beautiful work!  _________________ What makes a space ours, is what we put there, and what we do there. |
Lemmy
Posted: Mon Nov 26, 2007 4:04 am Post subject:
Mr. Clack, any more info on screen printing would be useful. Do you need specialist equipment to do that? (I'm thinking Andy Warhol prints here - same kind of process?) Is it expensive if you get someone else to do if for you? And can you screenprint onto aluminium?
Thanks! |
asafnetzer
Posted: Mon Nov 26, 2007 11:35 am Post subject:
Lemmy,
Screen printing can be done on almost any material and it's as you thought, andy warhol kind of process.
Screen printing at home require some equipment, you can search it out on the web but mostly you will need a bit of free space for it.
I have done my fare share of screen printing, both home made and by some companies for a run of shirts I have made in the past, if you are making a one run print it might be expensive doing it as most of the time making one or 20 cost the same.
I did a run of prints on my 3 WSG at home as you can see on my flickr account, WSG Photos and I used a nice product that you can check at the following link that save you the trouble of making your own print and using chemicals at home - EzScreenPrint |
