Mr clacks Dual Soundlab and Soundlab Mod PCB's
Page 1 of 1 [9 Posts]
Clack
PostPosted: Tue Nov 20, 2007 4:18 pm    Post subject: Mr clacks Dual Soundlab and Soundlab Mod PCB's Reply with quote  Mark this post and the followings unread
Hey , Im almost finished my dual soundlab and thought I'd post some custom PCB's I made from Ray's mod circuits.
drum trigger
Tested and it works ( on 12-12v . It says TL074 but i'm using an LF444 ( No lf444 in eagle library , im sure both will work )
 Filesize:  28.11 KB
 Viewed:  205 Time(s)
Soundlab - Drum Trigger.pdf
 Filename:  Soundlab - Drum Trigger.pdf
 Filesize:  62.13 KB
 Downloaded:  211 Time(s)
Drum trigger.zip
Eagle BRD file
 Filename:  Drum trigger.zip
 Filesize:  3.99 KB
 Downloaded:  230 Time(s)
Clacktronics.co.uk
PostPosted: Tue Nov 20, 2007 4:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey nice! Cool
Have you sent this to Ray? I'm sure he would dig this Very Happy
ACHTUNG!
Clack
PostPosted: Wed Nov 21, 2007 3:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Thought i'd show off my work. Its a dual soundlab. Its semi-modular and I screen printed the front onto wood then varnished it. I will show more pics when I get better light in my room ( my camera cant cope with the dull light! ) Case needs finishing and I havn't completely done the insides yet. One SL is on the right one is on the left and each SL has a mixer that has all the available VCO's and an external input
When its running i'll post a video mmm
 Filesize:  452.12 KB
 Viewed:  227 Time(s)
Clacktronics.co.uk
Lemmy
PostPosted: Thu Nov 22, 2007 2:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
wow, looks great!
Pehr
PostPosted: Thu Nov 22, 2007 2:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Really nice! Very Happy Shocked
I love the symmetry Laughing
YouTube channel
flickr photostream
http://loxodrom.blogspot.com
gubbeper
PostPosted: Mon Nov 26, 2007 12:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Looks really nice! Very Happy
/Per
I'm on Twitter
PostPosted: Mon Nov 26, 2007 1:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, beautiful work! Very Happy
Lemmy
PostPosted: Mon Nov 26, 2007 4:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Mr. Clack, any more info on screen printing would be useful. Do you need specialist equipment to do that? (I'm thinking Andy Warhol prints here - same kind of process?) Is it expensive if you get someone else to do if for you? And can you screenprint onto aluminium?
asafnetzer
PostPosted: Mon Nov 26, 2007 11:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Lemmy,
Screen printing can be done on almost any material and it's as you thought, andy warhol kind of process.
Screen printing at home require some equipment, you can search it out on the web but mostly you will need a bit of free space for it.
I have done my fare share of screen printing, both home made and by some companies for a run of shirts I have made in the past, if you are making a one run print it might be expensive doing it as most of the time making one or 20 cost the same.
I did a run of prints on my 3 WSG at home as you can see on my flickr account, WSG Photos and I used a nice product that you can check at the following link that save you the trouble of making your own print and using chemicals at home - EzScreenPrint
