Solina or Onmi ensemble board?
Page 11 of 16 [394 Posts]
Goto page: Previous 1, 2, 3, ..., 9, 10, 11, 12, 13, 14, 15, 16 Next
If I'd make a string chorus PCB, what kind of multi-BBD circuit would you prefer?
Solina style (also: Crumar Performer, Böhm Phasing Rotor, and others)
62%
 62%  [ 28 ]
ARP Omni style
13%
 13%  [ 6 ]
Elka Synthex 4 BBD circuit
11%
 11%  [ 5 ]
other (please name in thread)
6%
 6%  [ 3 ]
I would want neither - it's old fashioned and overused, and if I need it, there are digital FX boxes
6%
 6%  [ 3 ]
Total Votes : 45
Usine Karate
PostPosted: Tue Dec 18, 2007 10:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Got my boards today, Merry Christmas everybody!!!!
gavgomad
PostPosted: Wed Dec 19, 2007 11:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey all! Part of the Canadian contingent (yours truly) has received his package of joy from JH!
Cheers all, and happy hols! Wink
Gav.
Stavros
PostPosted: Thu Dec 20, 2007 1:34 pm    Post subject: Potentiometers Reply with quote  Mark this post and the followings unread
I can get locally (Greece) ‘Piher’ potentiometers, shield in plastic casing. Would they be OK or it would be better to try get ‘Alpha’ Potentiometers in metal casing?
Best Regards and Merry Christmas to all.
SG
jhaible
PostPosted: Thu Dec 20, 2007 4:11 pm    Post subject: Re: Potentiometers Reply with quote  Mark this post and the followings unread
SG
Any pot with the required value will do.
(Personally I'm not a big fan of Piher pots, though.)
JH.
b-funk
PostPosted: Thu Dec 20, 2007 5:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
hi jürgen,
i started soldering the solina board today, and it is like a charm Very Happy
really cool...
there are just some resistors values left which i didn´t have at hand, but i´m pretty sure i can put the chorus under the christmas tree for myself...
one question though: do the bc560s need to be matched, or doesn´t it matter?
best wishes,
tobias
ps: merry christmas to all the freaks!!
jhaible
PostPosted: Thu Dec 20, 2007 5:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
No. These are just emitter followers, used for sallen key low pass filters.
You could probably use _any_ silicon small signal pnp transistor with C-B-E pinout here.
JH.
b-funk
PostPosted: Thu Dec 20, 2007 6:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
cool, thank you jürgen...
The Alison Project
PostPosted: Fri Dec 28, 2007 11:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Finished my Triple Chorus today, I am in love....
I officially vote for a JH Design forum here at EM so it's easy to keep track of all his projects.
 Filesize:  173.38 KB
 Viewed:  463 Time(s)
The Alison Project
www.thealisonproject.com
Luka
PostPosted: Thu Jan 03, 2008 11:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
i got my pcb Wink
problemchild
melbourne australia
chriswilliams
PostPosted: Mon Jan 07, 2008 3:35 am    Post subject: Reply with quote  Mark this post and the followings unread
I've got mine too! Thanks and Happy New Year Very Happy
bugbrand
PostPosted: Tue Jan 08, 2008 4:49 am    Post subject:
Subject description: !!
I'm hoping to get things to a testing stage today. Its taken surprisingly long to build the PCBs - I think 'cos they are so densely packed - but there's nothing too tricky with the building.
I'm glad you've gone with SMD bypass caps - its a real eye opener! I'd been meaning to investigate and this gave me the suitable kick-up-the-ass. And, it turns out that its a very simple method (as long as you've got tweezers!). This is very inspiring - thanks Jurgen!
The only big thing left to figure is how to power a little JFET buffer for hi-impedence input - I want to have this switchable on the input so it can be used fine for guitar etc. I've got to look at the schems a bit more, but I think it should be possible to tap off the rectifier diodes to make a little positive regulator for this (does this sound reasonably reasonable?!) - anyways, testing the ideas today! Otherwise I guess I must figure it using Gnd and -ve supply - sure its possible, I just got a little confused..
http://www.bugbrand.co.uk
jhaible
PostPosted: Tue Jan 08, 2008 5:04 pm    Post subject:
You could simply increase the resistor values of the input amp.
Increasing the impedance by a factor of 10 (1Meg input, 2.2Meg feedback) should work. You should then omit the inout level pot (maybe make the feedback resistor a 2.2Meg log potentiometer instead).
Untested - but should work.
JH.
bugbrand
PostPosted: Wed Jan 09, 2008 3:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah, yes, of course! Talk about bleeding obvious! That'd be much simpler!
6079smith
PostPosted: Wed Jan 09, 2008 4:05 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm just curious, are there any PCB's left? I'd like to try my hand at this project (if there any TDA1022's left on the planet!)
jhaible
PostPosted: Wed Jan 09, 2008 8:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Plenty. Just send an official order mail.
(It may take a few days before I'm answering. I'm currently sick at home, and my own little pcb business will also rest as long as I don't work for my employer.)
JH.
6079smith
PostPosted: Wed Jan 09, 2008 9:32 am    Post subject: Reply with quote  Mark this post and the followings unread
It seems as everyone's ill at the moment, we've just gotten over the 'flu... hope you get well soon.
Now to investigate some BBD's...
b-funk
PostPosted: Wed Jan 09, 2008 3:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
so, after a long time i worked again on the solina board, and mostly finished it.
just the transformer is missing.
now my question: how much current is the circuit approx drawing? i have a 18vac/250ma transformer here. will this be enough, or should i get a stronger one?
best wishes,
tobias.
bugbrand
PostPosted: Thu Jan 10, 2008 2:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey Tobias -- the BOM says the fuse required is 200mA so I'd presume your AC adaptor should be fine.
I haven't finished the boxes either yet due to general flu-ish-ness. Darn its annoying.
b-funk
PostPosted: Thu Jan 10, 2008 4:08 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks bug - i presume that too, but ithought i better ask. you never know...
and yeah, the flu - this damn thing forces me to stay in bed, instead of soldering. too bad...
jhaible
PostPosted: Mon Jan 21, 2008 2:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
I measured 115mA on my prototype.
That value depends on the exact AC voltage, the load the FX is driving, and it may be a little off because of the crest factor and my multimeter's ability to measure true RMS.
But the 250mA is plenty, for sure.
JH.
jhaible
PostPosted: Thu Jan 24, 2008 4:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've made an update of my triple chorus page:
http://www.jhaible.heim.at/triple_chorus/triple_chorus.html
Picture of my 2nd prototype (in 19" 1U enclosure)
Links to 3rd party documentation (front panel designs, BOMs, etc.)
JH.
whomper
PostPosted: Sat Jan 26, 2008 7:25 am    Post subject: Component Replacements Reply with quote  Mark this post and the followings unread
I would like to check with you whether the following components are proper replacements for the ones listen in the BOM:
1. CD4011 -> HEF4011BP
2. LM1458 -> 4558P OR CHN4558P
Thanks,
Whomper
jhaible
PostPosted: Sat Jan 26, 2008 11:32 am    Post subject: Re: Component Replacements Reply with quote  Mark this post and the followings unread
whomper wrote:
Thanks,
Whomper
1. Yes the HEF4011BP is the Philips version of that chip; it will work.
2. No - 4558 is not the same as 1458. It *might* work, but I have not tested it. The 1458 is quite common, and also made by different manufacturers. MC1458, for instance.
JH.
bugbrand
PostPosted: Mon Jan 28, 2008 3:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey,
Just to report that I delivered the first pedal last night ---- there was a very very big smile from the receiver!
We tried the chorus with a proper Solina and very much liked sound - absolutely the same! But, of course, there's loads of other possibilities too!
The 3band EQ setting is very powerful - the Mid band, when cranked, seemed to really emphasise lovely harmonic content. Though, even with the treble cranked there seemed to be less of the very high end present. Am I right in thinking the EQ section was inspired by a particular keyboard type?
I added Depth dials to each modulator section as detailed on Jurgen's page, plus a 3 way switch (one of those C&K type On.On.On switches) to allow just Chorus, just Vibrato or both (again, using details off Jurgen's page -- 100u caps to ground). These extras allow so many extra and more subtle settings to be dialed in.
The only bad-ish was when we tried guitar into it and found the noise floor to be quite bad -- I'd added a little hi impendence buffer circuit, switchable on the input, but it turned out that the input level really needs to be high (ie line, not guitar) - when we added a boost pedal in front, keeping the levels higher, the resulting sounds were super lovely -- in fact, I had to excuse myself after a while 'cos my mate would have quite happily played for hours!
Overall results = freaking awesome!
 Filesize:  44.44 KB
 Viewed:  244 Time(s)
 Filesize:  54.39 KB
 Viewed:  251 Time(s)
jhaible
PostPosted: Mon Jan 28, 2008 1:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great looking stomp box!
JH.
