celebutante
Posted: Sun Jan 06, 2008 3:17 pm Post subject:
hand clap/smash sound generator |
I have to preface this by saying that I'm a little more obsessed with sound of analog handclaps/"smashes" than most average humans. This is probably because I grew up in 80's listening to Yaz/Devo/Human League, etc. Lucky for me, Logic has the Ultrabeat drum synth which is optimized for this kind of nonsense. I have a favorite "handclap smash" sound that I use all the time. It started as one of their 808 clap emulations, but I tweaked it... the biggest thing I did was remove the three cycles of LFO amplitude mod that give it the "multiple hands clapping" sound; so it now it's a bit more like whipcrack. Blah blah, get to the point... bear with me.
I'd like to DIY a module to make this sound. Instead of making a module for my modular synth, I'd actually like to mount it inside my Pearl DRX-1 drum module. It's an obscure beast much like a Simmons SDS-V with kick, snare, and three tom voices, drum pad/trigger inputs, no MIDI (not for long!), and eight kit memories. The reason I want to build it into the DRX-1 is that I'd like to use it live.
So with all that established, I went ahead and reverse engineered the sound from Logic Ultrabeat (block diagram attached). I then set about recreating this "for real" on my modular. I used my Ken Stone digital noise> .com state-variable high pass>.com ladder filter with no res in 12/db oct mode >VCA. I also plugged the out of the modular into a Boss GE-7 graphic EQ stomp box for the boost (the freq wasn't right on, but it was close enough).
It doesn't sound exactly like Ultrabeat... as usual in real analog world, it sounds even better! And there's a fair amount of tweaking options with the filters and env settings. Gotta love modulars. Love using about $1500 worth of synth to make a clap!
But back to my point (I'm pretty sure I had one...).
Anyone think there's an easy way to build such a creature in a somewhat small and simple package? Roland must have, right? I'm just not sure what could be trimmed down. I tried using a single bandpass filter in place of the highpass/lowpass combo, both in Logic Ultrabeat world and on my modular, but in both cases, it didn't sound nearly as good (made it too middy, and lost lots of impact as a result)... maybe this could improved upon with the right bandpass filter.
I don't want this to be the kind of thing with a million controls; I was thinking just to have trimmers for cutoff/res and maybe it'd be cool to bring the env releases out to the front panel. Maybe trims for the EQ....
Any suggestions? Think this is too nutty for a small and simple thing?
Mitchell
| Description: |
| Filesize: |
42.49 KB |
| Viewed: |
297 Time(s) |
danielwarner
ickystay
Posted: Sun Jan 06, 2008 6:48 pm Post subject:
I'm not familiar with the Logic Ultrabeat sound. Would a stand alone clapper (Boss HC-2, Simmons Clap Trap, Tama TS204, Electro Harmonix Claptrack, Coron DC-890) get you there? In the neighborhood?
Perhaps one of those circuits could be the starting point to add and subtract features to get your sound. |
andrewF
celebutante
Posted: Mon Jan 07, 2008 2:46 am Post subject:
| ickystay wrote: | I'm not familiar with the Logic Ultrabeat sound. Would a stand alone clapper (Boss HC-2, Simmons Clap Trap, Tama TS204, Electro Harmonix Claptrack, Coron DC-890) get you there? In the neighborhood?
Well, Ultrabeat doesn't really have "a sound", as it's a synthesizer optimized for making percussion sounds, so the possibilities are endless, but the initial sound I started with was one of its presets for an 808-style clap, and it was pretty spot on.
Anyhow, it had certainly occurred to me that getting a Boss HC-2 and yanking out the PCB might be the easiest thing to do. I couldn't find any on ebay or craigslist. I'm not so sure about the others mentioned... don't know what a Simmons Clap Trap or EH Claptrack sounds like. There's also the size issue; I want it to be one relatively small PCB. Analog
Solutions also makes a eurorack 808-clap module, but it's a bit pricey.
I guess I can either hold out 'til I find an HC-2 (or Amdek equivalent), or I can get my buddy to help me reverse enigineer the clap circuit from the DR-110 schemo...
mitchell |
synth_ollie
Posted: Mon Jan 07, 2008 7:44 am Post subject:
here´s the amdek/boss schemo if it could be of any help,
posted it to matixsynth some time ago...
ickystay
Posted: Mon Jan 07, 2008 2:20 pm Post subject:
Thanks, synth_ollie!
Here's the Tama:
(Part of the circuit is for presets. I never took the time to figure out how they worked when I had mine.)
| Description: |
| Filesize: |
74.61 KB |
| Viewed: |
464 Time(s) |
| Description: |
| Filesize: |
71.17 KB |
| Viewed: |
393 Time(s) |
ickystay
Posted: Mon Jan 07, 2008 2:25 pm Post subject:
and the EH:
| Description: |
| Filesize: |
238.07 KB |
| Viewed: |
364 Time(s) |
| Description: |
| Filesize: |
237.84 KB |
| Viewed: |
347 Time(s) |
G2 patch files: 626
Posted: Mon Jan 07, 2008 3:33 pm Post subject:
| andrewF wrote: | The Boss DR-110 is famed for it`s handclaps (and not much else)
Interesting circuit. They use the micro to produce the multiple triggers required for the envelopes. Cool. |
celebutante
creatorlars
Posted: Mon Jan 07, 2008 3:48 pm Post subject:
I've got an 808 hand-clap clone module on my desk right now I'm putting together. It's based on the modular PCB layouts on microLARGE's 808 clone site (http://xlargex.xl.funpic.de/). I'll definitely post when/if I get it working.
100% there with you on the clap/crack, by the way. What I do is electronic percussion + live (and very loud) guitar and bass. So claps tend to punch thru the mix waaay better than typical electronic snares. I'd be very interested to see what you end up deciding on here. I need more than one clap.  |
celebutante
Posted: Mon Jan 07, 2008 5:04 pm Post subject:
| creatorlars wrote: | I've got an 808 hand-clap clone module on my desk right now I'm putting together. It's based on the modular PCB layouts on microLARGE's 808 clone site (http://xlargex.xl.funpic.de/). I'll definitely post when/if I get it working.
Yeah, I just saw that site. That kid's a frickin' genius! Looks like that might be a way to go, though I can't help but think my life would less complicated if could just find one of those Boss Hand Clapper things and gutted it and shoved it inside my Pearl module.
BTW, sounds like you might dig my project... it's definitely a hybrid of live stuff and analog-y electronics. We're putting together the live version right now, and my keyboardist is using my Prophet-5 and his Jupiter 8, my "bass player" is currently playing an Aleis Ion, but she's going to start using my .com modular, and I play guitar and sing. Drummer will be playing acoustic kik/snr/cymbals with elec toms and claps.
URL is www.celebusite.com
Love to hear what you're doing!
Mitchell |
creatorlars
Posted: Mon Jan 07, 2008 6:34 pm Post subject:
Sexy tunes. You can check my shit out here:
http://www.myspace.com/theundoingofdavidwright
Kinda like Gang of Four in a haunted house? Hah. We dig no wave, performance art and 70's noise/progpunk. A few kinda weird tracks there right now, not really representational. Need to get stuff from the new album up. No DIY synths in those recordings yet (have used Alesis SR-16, MPC1000 and software, in the past). |
etaoin
Joined: Jun 30, 2005 Posts: 761 Location: Utrecht, NL
Posted: Mon Jan 07, 2008 11:59 pm Post subject:
| synth_ollie wrote: | here´s the amdek/boss schemo if it could be of any help,
posted it to matixsynth some time ago... |
This is very, very similar if not partly identical to the 808 clap. Different noise generator, but the same envelope generator. _________________ http://www.casia.org/modular/ |
StephenGiles
Posted: Tue Jan 08, 2008 12:31 pm Post subject:
| Many thanks for the EH circuit - has anyone spotted the CA3094s ? Personally, any form of music that employs hand claps is to be avoided at all costs, with the exception of early Gene Vincent and Elvis! |
celebutante
Posted: Wed Jan 09, 2008 6:36 pm Post subject:
| StephenGiles wrote: | | Many thanks for the EH circuit - has anyone spotted the CA3094s ? Personally, any form of music that employs hand claps is to be avoided at all costs, with the exception of early Gene Vincent and Elvis! |
You didn't just say that? It's as if I've been stabbed in the heart. Tell me those tracks suck, and I'll be on my way, heart in hand...
The Cars "Since You're Gone"
Yaz "Don't Go"
:>P mitchell |
