Recommended ASIO drivers?
Post new topic   Reply to topic Moderators: blue hell
Page 1 of 1 [15 Posts]
PostPosted: Wed Jan 03, 2007 7:46 am    Post subject: Recommended ASIO drivers? Reply with quote  Mark this post and the followings unread
Can anyone here recommend any good ASIO drivers for XP?
ASIO4ALL seems to have died, and I can't seem to get it working again Sad
svivens
PostPosted: Tue Jan 08, 2008 5:36 am    Post subject: asio drivers Reply with quote  Mark this post and the followings unread
what do you mean by died?
re-installation?
asio4all works pretty good for my XP, with humouristic interface...
this link works pretty well.
www.asio4all.com
Mohoyoho
PostPosted: Tue Jan 08, 2008 8:01 am    Post subject: Reply with quote  Mark this post and the followings unread
I've had a problem with ASIO4ALL where it just won't seem to "load" in my DAWs or show in the XP control panel. It's like it doesn't exist. I've tried every setting on ASIO4ALLs control panel, rebooted. Then sometimes it will work.
Mark Mahoney
Kingsport, Tennessee
www.cdbaby.com/cd/markmahoney
svivens
PostPosted: Tue Jan 08, 2008 4:56 pm    Post subject: pb asio4all Reply with quote  Mark this post and the followings unread
oh-ho...i m'trying to dig that and ask to my guru...
PostPosted: Tue Jan 08, 2008 9:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
What sound card/device is this for? Rather than use ASIO4ALL, can you find a driver that is made for the same chipset (intel, creative, etc)?
ASIO4ALL works, but I think it's a bandaid to the wave driver. So I'm not entirely convinced that it could ever truly be as fast as true ASIO drivers (fast = low latency). But anyway, why not download the latest ASIO4ALL that you could find? Should still work fine. XP hasn't changed (though we'll see what SP3 does this year).
Mohoyoho
PostPosted: Tue Jan 08, 2008 11:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
I downloaded mine about one month ago.
Mark Mahoney
PostPosted: Wed Jan 09, 2008 9:06 am    Post subject: Reply with quote  Mark this post and the followings unread
SP3?? Shocked
ACHTUNG!
svivens
PostPosted: Wed Jan 09, 2008 10:03 am    Post subject: asio4all in reg edit Reply with quote  Mark this post and the followings unread
I had a similar problem with Usine and ASIO4ALL v2, senso settled this mater by looking in "reg edit";
some host doesn't like strange path character (my problem was the presence of the "%")
if you find it, try to remove it.
for my computer it works perfectly now, but my audio chipsets
are "Intel":
and we also know that there is simply an incompatibility between ASIO4ALL and some chipsets!
good luck.
SV.
cappy2112
PostPosted: Fri Jan 11, 2008 10:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
v-un-v wrote:
SP3?? Shocked
SP3- aka Vista Wink
cappy2112
PostPosted: Fri Jan 11, 2008 10:48 pm    Post subject: Re: Recommended ASIO drivers? Reply with quote  Mark this post and the followings unread
Have yo uninstalled-rebooted-reinstalled?
I use ASIO4all with 2 Arturia's Prophet V and Timewarp 2600, and it works fine for me on XP.
Are you running SP2 at the very least?
cappy2112
PostPosted: Fri Jan 11, 2008 10:51 pm    Post subject: Re: asio4all in reg edit Reply with quote  Mark this post and the followings unread
SV.
Are you sure the % wasn't part of an environment variable expansion?
This %ENVAR% is pretty common on Windows.
PostPosted: Sat Jan 12, 2008 11:25 am    Post subject: Reply with quote  Mark this post and the followings unread
cappy2112 wrote:
v-un-v wrote:
SP3?? Shocked
SP3- aka Vista Wink
No really, there's Service Pack 3 coming out this quarter.
http://keznews.com/3776_Windows_XP_SP3_Yields_Performance_Gains_Over_Vista_SP1
PostPosted: Sat Jan 12, 2008 11:30 am    Post subject: Reply with quote  Mark this post and the followings unread
I find it highly amusing that XP SP3 is gonna be much faster than Vista, when OSX Leopard is tons faster than OSX Tiger.
Come on Microsoft, get yer shit together! Smile
Actually I had a play with Vista a couple of weeks back- it ain't that bad you know.
ACHTUNG!
PostPosted: Sun Jan 13, 2008 6:45 am    Post subject: Re: Recommended ASIO drivers? Reply with quote  Mark this post and the followings unread
I didn't think SP2 affected sound? I thought it was only a security update, I haven't installed it as i don't connect Windows to the net at all and haven't found any issues with this.
Do you know what aspects of SP2 affect sound and how I could install those without also getting the rest (I'm not installing a firewall and IE and so on) without putting my XP install online?
V-un-V; didn't your card come with ASIO drivers? most of the time those should be the ones to use, with some exception ASIO4ALL is only for consumer cards that don't come with ASIO drivers. If this is a issue with Apple's build in cards then it's likely caused by Apple's refusal to release notes on how those work, this affected Linux on Mac's as well but I thought a lot of that would be reverse-engineered by now.
BobTheDog
PostPosted: Mon Jan 21, 2008 3:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Apart from security enhancements SP2 did make some changes to DEP which affected some drivers especially if more than 4GB of ram was installed and they used PAE although I wouldn't have thought this would effect audio drivers.
Some usb changes where made as well but I think these where for block storage devices.
Also Tablet PC stuff was included.
I was one of the poor gits that had to try to work out why things stopped working when sp2 was installed
