today> Various Artists September equinox Concert
Interested in Tau Pipe Phaser / Flanger boards ?
Page 15 of 26 [640 Posts]
Goto page: Previous 1, 2, 3, ..., 13, 14, 15, 16, 17, ..., 24, 25, 26 Next
mph
PostPosted: Fri Dec 07, 2007 10:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello
I am still waiting for some parts to finish this project... I hope it will be ready-to-plug before the end of this year Wink
and I would like to know what could be this "bounce" circuit? what kind of function does it do?
Is it going to be easy to add this to the "deluxe" version?
funkyfarm
PostPosted: Fri Dec 07, 2007 10:30 am    Post subject: Reply with quote  Mark this post and the followings unread
"your thumb on the reel"... Cool
http://home.debitel.net/user/jhaible/jh_storm_tide_flanger.html
The summed control voltage (Manual, Pedal, LFO, Envelope follower) is fed into a sub audio BPF, then into a nonlinear amplifier with positive feedback (not a schmitt trigger, but similar), and then filtered by a second BPF. A variable portion of this is mixed to the straight CV to control the BBD's clock frequency. The effect is most prominent on single-shot, non-periodic CV changes, such as a fast single Manual of Pedal sweep. The single sweep is followed by smooth "echoes" that go in either direction (faster clock and slower clock). This is to emulate the "bouncing" tape speed of reel-to-reel tape machines when the friction from a thump against the reel is suddenly released.
Here's another description :
StephenGiles wrote:
I can't find my manual right now but I found this reference from the manual:
When the BOUNCE control (a knob on the front) is full clockwise, only changes in the control signal (0 - 5 VDC, or what Steve refers to as CV in his post) affect the flanging while at full CCW only the control signal itself affects it. The control signals can come from the oscillator, the envelope follower, a manual adjust on the front panel, and a socket called remote (for a footpedal or other CV source). Unlike the Phaser, the FL-201 allows for combinations of the these four sources - for example the oscillator can be sweeping along at a given rate AND the envelope follower can add transients or longer releases.
At one extreme of the knob, the user brings a signal differentiator, pulse shaper, and an active filter on-line. At the other extreme a VCO for setting the low frequency limit and a full-wave rectifier are in the path. The knob allows for mixing between these two extremes.
They say, "(a)s this control is rotated clockwise, the flanging control signal is progressively substituted for by a damped sine wave initiated by changes in the control signal. This damped signal swings the flanging back and forth by a diminishing amount for each swing, simulating the "hunting" effect created by an AC or servo motor changing speed."
How the electrons flow is described in great detail in the section called "Circuit Description" But without the schematic in front of you, the IC references won't make any sense I'll quote what's relevant. Let me know if you are bored.
It seems IC11 is the differentiator and its output is dependent upon the rate of change of the input. They say, "(t)hus, when the oscillator changes from positive slope to negative slope," (crossing zero, right?), "the output of IC11 changes polarity." It says later, "The effect of all this circuitry is to generate a damped sinusoidal oscillation at a low frequency when the control voltage changes direction" (rising or falling, essentially anything but zero).
Then it says, "(t)his corresponds in classical flanging to removing the load from the reel motor. The damped oscillation in flanging is caused by the mechanical inertia of the motor - when it reaches its proper speed, it cannot stop changing speed instantly, and thus tends to overshoot, causing it to slow down, etc."
http://electro-music.com/forum/topic-19784-25.html
I've understood it is a process applied on the incoming modulation, the same thing as for "smooth switch" but for a totally different effect...
mph
PostPosted: Fri Dec 07, 2007 11:16 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks! that makes sense...
seems very interesting!!! (even if I don't really understand all the details Confused )
well, let's be "educated"!
Cheers.
yusynth
PostPosted: Sat Dec 08, 2007 8:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Jürgen
I have completed one of the two boards I got and I ran the first tests feeding it with a Crumar Multiman S and it does work and sound nicely and as expected. Great stuff indeed. Thanks Jürgen.
Now it's time to adjust the various trimmers and if the gain and resonance trimmers can be adjusted as see fit, can you provide us with some guide lines for adjusting the pitch trimmer and the V/Oct trimmer. For the V/Oct for example, the module cannot oscillate and it's difficult to figure out an octave interval... how do proceed to adjust it ? Does just measuring a mere 18mV variation at pin 3 of U5A, for a variation of 1V at the input, is good enough or should I proceed otherwise ?
Yves
jhaible
PostPosted: Mon Dec 10, 2007 10:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Cheers.
He he, that was "eductional", as in opposed to "commercial".
Not, me becomming less cryptical, suddenly. Smile
As I finish building the extra stuff on verobaord, I'll post updates.
But it will take time. With all these commercial stuff runing, building my own phaser has become low priority - sad but true.
That version will also have a resonance that can be switched to self oscillation.
JH.
jhaible
PostPosted: Mon Dec 10, 2007 10:36 am    Post subject: Reply with quote  Mark this post and the followings unread
yusson wrote:
Hi Jürgen
Change the 220k resistor that's in series with the resonance trimmer to 180k. Now it should self oscillate with the resonance pot all turned up. Then adjust the V/Oct trimmer by ear or with a guitar tuner.
Don't expect perfect tracking. It's a phaser, not a MOTM VCO.
In my Tau, I'm using a 100k "Pull Pot" for resonance.
The formerly 220k is changed to 180k on the board,
The 100k resonance pot has a 20k (final value tbd) resistor in series with its cw end. (i.e., cw end of pot goes to 20k resistor, 20k resistor goes to board connector.)
The switch of the pull pot is connected to short the 20k resistor, when the knob is pulled out. So I get nice high resonance *without* oscillation with the knob pushed in, and screaming oscillation when pulled out.
You can also wire this up with an ordinary pot and switch, of course.
JH.
yusynth
PostPosted: Mon Dec 10, 2007 10:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Jürgen
Thanks for the tips.
Yves
Yves
eframp
PostPosted: Sun Jan 20, 2008 3:24 pm    Post subject: Troubleshooting and calibrating Reply with quote  Mark this post and the followings unread
So I finally got my Tau Pipe put together, and I've found a few things that I can't figure out.
The unit is cleanly passing audio, except...
First, the LFO doesn't seem to work. The Tau will sweep if I hook an external LFO up to it, but not otherwise. Without the external LFO hooked up, if I move the Rate pot, the board will sweep to a new position (slightly), but then settles down and won't move again unless I move the pot.
Second, when hooked up to the external LFO (my MOTM one), when the LFO goes negative in output, the Aux Out on the Tau Pipe goes crazy, while the Main Out doesn't. There's a huge variation in level there, too. This is when set to Phasing, not vibrato.
Lastly, is there a post (or a document somewhere) that describes how we should calibrate this thing for optimum performance, aside from the 1V/Oct calibration?
thanks, y'all.
eric
jhaible
PostPosted: Mon Jan 21, 2008 3:06 pm    Post subject: Re: Troubleshooting and calibrating Reply with quote  Mark this post and the followings unread
thanks, y'all.
eric
Sounds like two different faults at least.
Have you checked supply voltages at Opamps (+/-15V)?
Any different components than on the BOM?
Checked all solder joints?
JH.
ericcoleridge
PostPosted: Tue Jan 22, 2008 9:57 am    Post subject: Reply with quote  Mark this post and the followings unread
I had a similar results so far with my Tau Pipe. It passes audio, but no phasing and no LFO. Actually it might be phasing, it sounds like the audio is filtered--but no movement. A couple times when I powered it up initially, it would give a burst of "swoosh", and the LEDs would blink, but then it immediately stops.
I checked the power, cap and chip orientation, etc, but am at a loss. So, I sent it to a friend to take a look at. I probably overlooked something very obvious.
eframp
PostPosted: Tue Jan 22, 2008 10:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Bingo. That's what I'm seeing here. Nice clean +/-15V, all the controls work, all the jacks accept CV's and do the correct things with them, there's nice strong phasing (boy does it sound good!), but no sweep unless I give it an external LFO or sweep the Pitch pot manually. Or move the Rate pot, but then it settles back down again and doesn't actually keep moving.
jhaible
PostPosted: Tue Jan 22, 2008 12:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Are the two LEDs taking turns in glowing?
Are all the diodes soldered in with the right orientation?
(If D2 in http://www.jhaible.heim.at/tau/jh_tau_sch_page3_control.pdf is reversed, the LFO would oscillate, but with an offset where it would be blocked by D1 ...)
If the LFO does not oscillate, what are the voltages on all 8 pins of U6 (the TL071 closest to the voltage regulators) ?
JH.
eframp
PostPosted: Tue Jan 22, 2008 3:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
On mine, the "Down" LED is stuck on.
The bands match the silkscreening.
1: 0.135
2: 0.006
3: 0
4: -15.11
5: 0.134
6: gnd
7: 14.61
8: 15.14
jhaible
PostPosted: Tue Jan 22, 2008 4:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
eframp wrote:
1: 0.135
2: 0.006
3: 0
4: -15.11
5: 0.134
6: gnd
7: 14.61
8: 15.14
That looks like a perfectly valid condition within an ordinary LFO cycle.
Pin 1 should further ramp down, and when it crosses 0V, Pin 7 should jump to -14V, causing pin 1 to ramp up.
Strange that apparently it doesn't.
In that state you described, the center pin of the "Rate" connector should be positive. Is it? (If you turn the Rate potentiometer all the way clockwise, it should be about +14V.)
Another thought: Could C54 be leaking? It should be a 470nF polyester cap - you don't have an electrolytic cap here, no? (Just to be sure.)
JH.
jhaible
PostPosted: Wed Jan 23, 2008 1:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Is it around +14V when the pot is fully cw?
JH.
eframp
PostPosted: Wed Jan 23, 2008 8:19 am    Post subject: Reply with quote  Mark this post and the followings unread
JH -
Between center pin and either side is 0V. Between center pin and ground is about 0.006V.
And the cap is indeed a poly, not electrolytic.
Sad
e
eframp
PostPosted: Wed Jan 23, 2008 9:37 am    Post subject: Reply with quote  Mark this post and the followings unread
And if a picture is worth a thousand words (well, probably closer to 15 words in today's economy)
http://www.ericframpton.com/clients/Phaser%20PCB.jpg
jhaible
PostPosted: Wed Jan 23, 2008 5:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
eframp wrote:
JH -
Sad
e
All right - I think I have figured it out:
The clockwise end of the pot (red wire in your picture) must have the same voltage as Pin 7 of the TL072. Which also must be the same at the right end of the 12k resistor (near the "LM317" silkscreening).
If it's not the same, you have a broken connection along that way.
Let me know what you find. Broken wire, bad solder joint, or broken copper trace, or bad IC socket.
JH.
eframp
PostPosted: Thu Jan 24, 2008 2:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
You called it right. Turns out it was the pad of pin 7 that I'd inadvertently pulled off the board from an earlier soldering mistake. Some bus-wire from the pin to the resistor, et voila, oscillation! It seemed so obvious after you pointed it out... <sigh>
Thanks for designing a cool module, and for your extra help getting mine going.
e
Techman
PostPosted: Tue Jan 29, 2008 6:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's a rough demo of my completed Tau board. Sorry for the size of the file. It's a bit noisy, as the wires to the pots an jacks are just lashed up and not screened, but it sounds great. Very Happy The source is an Alesis Drum machine, and I am using both the Tau internal LFO and an external CV via a P3 sequencer and a PolyDAC.
It's using the MOTM supply variation, and the next step is to have a front panel made and get it mounted in my modular.
Andy
Tau demo1.mp3
Tau Demo 1
 Filename:  Tau demo1.mp3
 Filesize:  4.37 MB
 Downloaded:  680 Time(s)
funkyfarm
PostPosted: Wed Jan 30, 2008 2:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Spectacular !
but i guess i can hear some clicks when you use an "external CV via a P3 sequencer and a PolyDAC"
Did you try the smooth function ? (or is it another matter ?)
Techman
PostPosted: Wed Jan 30, 2008 6:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Funkyfarm,
I guess you're talking about the clicks starting around 1'35" ? It's possible this is just going from one extreme of CV to another. I was just randomly turning the pots on the sequencer. The smooth function was, indeed, off at the time.
I've attached a picture of the board as it was when the recording was made. Note that this versions uses the CA3046 in the array.
Andy
Testing the Tau
 Filesize:  317.59 KB
 Viewed:  188 Time(s)
yusynth
PostPosted: Thu Jan 31, 2008 12:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have finished the Tau-Phase Shifter module for my YUSYNTH modular. Here is a photo of the finished module.
Yves
v8pete
PostPosted: Thu Jan 31, 2008 2:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Juergen - as a newbie to this site, I've just discovered this great little project of yours! - must have missed it somehow on your main site. You've probably been asked this a lot, but do you happen to have any more PCBs available as I'd love to get one!
Hey, is that a double exponential in the control circuit? - with the two series transistors for temp compensation - can't quite figure out exactly what's going on!
Keep up the excellent work!
Pete.
BTW - I also take my hat off to you for that rather marvellous voltage controlled ADSR design of yours on the website - inspirational stuff !! Shocked
jhaible
PostPosted: Thu Jan 31, 2008 3:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
These are sold out, I'm afraid.
But I'm getting more and more requests, so maybe I'll get enough for another run at some time.
If you want to be put on my waiting list, please send me an official order form email (scroll back in this thread to find it) - and mention that you're doing so to get on the waiting list.
It's tricky. It's a circuit that has an exponential input and a 1/x input.
Thank you! I hope this will appear as an official MOTM module some day.
I have licenced it to synthtech.com for that purpose some years ago.
If Paul should not want to make use of this (but currently I think he still wants), it will be one of the first things I'd make a PCB for, myself.
(I didn't give away any rights, but I had, and still have, the best and most satisfying relation with synthtech, so I rather wait another year or two than just offering it as a PCB myself.)
JH.
