| Want to see schematics? |
| Yes, I want to build a Lunetta myself |
86% |
[ 66 ] |
| Yes, but I'm just curious; probably won't build |
10% |
[ 8 ] |
| No, spare Mosc the work of remembering. |
2% |
[ 2 ] |
| Total Votes : 76 |
sdcurtin
Posted: Wed Jan 16, 2008 8:03 pm Post subject:
Stanley Lunetta - This topic was the first one - Wow! Subject description: information requested |
Hi Howard-
Welcome to MySpace, from that other Mills MFA. I saw in your MySpace blurb that Stanley Lunetta was your mentor and that you worked on a digital synthesizer with him- can you say more about this? He's one of the more interesting instrument builders out there.
Thanks,
Steve C
curtin.emf.org
myspace/stevencurtin
[added poll - mosc Feb 10,2008]
Subject changed by mosc - july 14, 2011 |
Joined: Apr 03, 2004 Posts: 24666 Location: The Netherlands, Enschede
Posted: Thu Jan 17, 2008 5:17 pm Post subject:
For as long as Howard doesn't kick in ... there are some posts here on the forum mentioning Lunetta, you'll find them using the search function. To me those have been interesting. _________________ Jan
Joined: Jan 31, 2003 Posts: 18308 Location: Durham, NC
Audio files: 235
Posted: Fri Feb 08, 2008 3:49 pm Post subject:
Sorry, I didn't see this.
Stan taught us about the joy of the surplus electronics stores, and he was into building really simple digital circuits that clocked at audio rates. For example, you make simple oscillators using digital inverters with RC networks. If you uses NAND gates instead of inverters, you get some sort of neat modulation when you hook up another oscillator to one of the free gate inputs. Run the osc into a modulo-N converter and you can get different pitches based on the code you put on the four inputs.
All these simple circuits, usually just one "naked" IC, are hooked up to banna jacks so you can make patches.
Shift registers were used a lot as were up/down counters, filp flops, and whatever we could find in the surpluss stores. We started with RTL, moved to TTL and then CMOS. Experimentation was the only rule.
Stan was always miffed that we called these instruments Lunettas. He said he felt honored, but he really wasn't the designer of them. He's great attitude made us want to call them Lunettas even more.
Most Lunettas probably don't exist any more because by their very nature they were never finished, but I still have mine. This was one of the fancy ones, included a lot of lights - means buffers - and even had built in stereo amp. Woo woo...
| Mosc's Lunetta - circa 1971 |
2.21 MB |
| Viewed: |
1103 Time(s) |
_________________ --Howard
my music and other stuff |
Danno Gee Ray
Joined: Sep 25, 2005 Posts: 1351 Location: Telford, PA USA
Posted: Sat Feb 09, 2008 8:57 pm Post subject:
| Any way you could share some of the circuit schematics with us? It sounds fascinating. |
Audio files: 235
Posted: Sun Feb 10, 2008 9:55 am Post subject:
Schematics?
We ain't got no stinkin' schematics!
I'll be glad to post something in more detail in the DIY forum if people are sincerely interested. I'd have to draw all the circuits from memory, but they are so very simple it will be easy. Maybe, I'll move this to the DIY forum and see if there is any interest.
Maybe some of the better designers here will get in the spirit of this once they see how it works. The possibilities are pretty unlimited. _________________ --Howard
Danno Gee Ray
Posted: Sun Feb 10, 2008 10:37 am Post subject:
| That would be wonderful! |
Audio files: 235
Posted: Sun Feb 10, 2008 12:01 pm Post subject:
Fill in the poll at the top of this topic to motivate me. I'd like to see people start building these things. Maybe we could eventually motivate Stan Lunetta to chime in. _________________ --Howard
GlassX
Posted: Sun Feb 10, 2008 12:45 pm Post subject:
I don't know about building, but I'll probably breadboard some stuff - I have a profound love for simple circuits made with simple parts.
And I'm really curious about this part: "Shift registers were used a lot as were up/down counters, filp flops"... this got my mind thinkin already!!! |
23isgood
Joined: Nov 18, 2006 Posts: 236 Location: San Francisco, CA bay area
Posted: Sun Feb 10, 2008 1:19 pm Post subject:
I'm very interested. The second I saw that box with all those bananas and led's and stuff, I was instantly intrigued. Please share the build info.
thanks
pete _________________ Check out my music |
Audio files: 235
Posted: Sun Feb 10, 2008 2:33 pm Post subject:
Wow, as of now, already 5 people said they were interested in building a Lunetta. That's splendid! That's enough for me. _________________ --Howard
RF
Audio files: 28
Posted: Sun Feb 10, 2008 3:48 pm Post subject:
Awesome, Mosc!
I look forward to seeing and building some of these circuits. |
Clack
Joined: Aug 08, 2005 Posts: 438 Location: Walthamstow - london
Posted: Sun Feb 10, 2008 5:30 pm Post subject:
Its quite hard to understand exactly what it involves, but it sounds interesting.
what kinds of things did you used to do with it?
did you ever record it? _________________ Clacktronics.co.uk |
Alienation
Posted: Sun Feb 10, 2008 7:19 pm Post subject:
Sounds interesting, would like to learn more about these.  |
fluxmonkey
Posted: Sun Feb 10, 2008 7:41 pm Post subject:
mosc,
would be greatful for your notes and rememberances.
from yr initial description, sounds similar to much of what Nic Collins presented in Handmade Electronic Music, and simlarly here. have you seen Nic's book?
at any rate, this is fertile ground. my breadboard's all warmed up, and i'm very much looking forward to seeing your examples and following along at home...
best
bbob |
Pehr
Joined: Aug 14, 2005 Posts: 1307 Location: Björkvik, Sweden
bugbrand
Tim Servo
Joined: Jul 16, 2006 Posts: 924 Location: Silicon Valley
Posted: Mon Feb 11, 2008 9:57 am Post subject:
Stanley Lunetta |
This looks like a fun thread. There's a LOT of fun sounds to be found in simple digital CMOS circuits. Another place to look for inspiration would be the Forrest Mims/Radio Shack "Engineer's Notebook" series.
http://www.amazon.com/Forrest-Mims-Engineers-Notebook/dp/1878707035
http://www.forrestmims.com/
And if you go to the Radio Shack site and look at their Electronics Learning Lab (which looks like it might be a great starting point for newbies), you can download the "Owner's Manual" (containing MANY circuits and breadboard layouts) for free!
http://www.radioshack.com/product/index.jsp?productId=2102913&cp
And while you're at it, check out Forrest Mims' personal site (just for grins)
http://www.forrestmims.org/
FINALLY, ONE THING TO REMEMBER ABOUT CMOS LOGIC CHIPS: ALL INPUTS MUST BE CONNECTED TO GND OR +V. DO NOT LEAVE CMOS INPUTS UNCONNECTED OR "FLOATING" AS THIS MAY DAMAGE THE CHIP!!
Sorry for the ALL CAPS, but this is a common mistake when dealing with logic-based sound gizmos. Sometimes it fries the chip, and sometimes it just makes the circuit misbehave and then you spend/waste all sorts of time trying to figure out what the heck went wrong.
Looking forward to seeing some illogical logic from all the new Lunettatics out there!
Tim (Lunettatics... get it?) Servo |
Audio files: 235
Posted: Mon Feb 11, 2008 11:02 am Post subject:
Yes, this is exactly the spirit. Lunettas are more about spirit that the actual circuits. So, I'm committed to going ahead with this thread. Since this is a sub-forum, I request that people start new topics when there is a new idea or question so people how newly come across this later will be better able to make sense out of what is happening.
To be sure, anything goes here. Bugs post about the digital oscillator is choice, IMHO. Those little OSCs are perfect. I'm going to start a new topic about OSCs and we can post designs there. I'll move Bugs topic there. I think once you guys get the spirit of this, then there won't be too much for me to do. _________________ --Howard
andrewF
Posted: Mon Feb 11, 2008 3:37 pm Post subject:
Re: Stanley Lunetta |
| Tim Servo wrote: |
Very good point Tim
would std procedure around this be to have a pull-up or pull-down resistor, say 100K, on each input?
Mosc wrote they moved from TTL to CMOS, was there some problem with TTL? ...asks Andrew who has over 1000 TTL chips rusting away in the cupboard and would love to use them for something! |
Posted: Mon Feb 11, 2008 3:59 pm Post subject:
A link to Stanley Lunetta's Moosack machine : http://www.ubu.com/sound/source.html (nr 8, but there are some more classics there!). It does sound like coming from a Lunetta to me  _________________ Jan
danielwarner
Posted: Tue Feb 12, 2008 3:32 am Post subject:
| mosc wrote: | | Maybe we could eventually motivate Stan Lunetta to chime in. |
Hey, that'd be great! I just checked out his website and it looks like he's very active in the Sacramento area. Looking at his sculptures, I'm pretty sure I've seen one first hand, at the Crocker Art Museum there was this sculpture with a toggle switch with a spring return, you'd flip it and it would play a pre-recorded cat mew. |
para
Posted: Tue Feb 12, 2008 6:17 am Post subject:
| Quote: | LM: How does your self relate to a machine?
SL: Hmmm. I don't know. I'd like to be a cyborg. I built a series of helmets for Amra Arma. When we perform we do a whole rite. It doesn't make sense for Amra Arma to perform music as music, because what we do is concerned with more than just music. Consequently we don't walk out and bow and wear tuxedos. There are some costumes, lighting, a fog machine--it's like some sort of a weird modernistic pagan rite. So to walk out and play an electronic music machine would make no sense at all. So my performance attire is integral with what it does. I couldn't perform in any other way. The original helmet looked something like a welder's mask, with lights on it and controls that went to the machine. The second helmet was more elaborate. It has tongue-activated keyboards inside. It's a whole different approach to performing. Instead of standing in front of the Machine like a scientist, I'm more like a priest calling on some sort of weird deity. |
certainly an interesting fellow.
so am i missing something here. are there any firm "rules", is this ONLY logic / digital based? so even if we can get voltage control or shaping or something else that would cross the line? but then you also posted an analog ringmod, so i'm lost. also apparently things like LDR's are fine?
unless the goal is just simplicity. period.
steven |
Posted: Tue Feb 12, 2008 7:23 am Post subject:
The way I see it,
It's about making a box which makes it easy for anyone to play with patching various simple building blocks (mostly digital) into a complex sound generator. Sort of a "200 in 1 Electronic Music Project Kit". Of course the more robust and "foolproof" the better. So it needs to include protection from potentially damaging patch options. Some kind of graphic layout for the "modules" would be helpful too, but not mandatory. Lots of LEDs which show the state of the "nodes" would be cool. It follows that being able to switch the osc/clocks between audio and LFO rates would be good for experimenting and/or understanding what was going on.
Is that the tree to be barking up Howard?
BTW So it would be feasable that there could be a "standard" Lunetta device, or a standard "collection" of blocks in a Lunetta device, and then people could swap "patches".
BTBTW Some well designed input and output blocks would enable the Lunetta device to be patched into any modular synth. A way of doing digital micro engineering of a modular patch. _________________ What makes a space ours, is what we put there, and what we do there. |
Posted: Tue Feb 12, 2008 7:35 am Post subject:
I just thought of a section which could be an R/2R DAC.
"Okay, we take that bit there, that can be the MSB. Now this bit here, (patch, patch) that can be our LSB. Okay, now we take these outputs off those two shift registers, they can be bits 2, 3 and 5. And bit 4 can be the output of this LDR controlled Oscillator."
Man, this could be hella fun!  _________________ What makes a space ours, is what we put there, and what we do there. |
