Stanley Lunetta - This topic was the first one - Wow!
Page 2 of 3 [51 Posts]
Want to see schematics?
Yes, I want to build a Lunetta myself
86%
 86%  [ 66 ]
Yes, but I'm just curious; probably won't build
10%
 10%  [ 8 ]
No, spare Mosc the work of remembering.
2%
 2%  [ 2 ]
Total Votes : 76
loss1234
PostPosted: Wed Feb 13, 2008 4:55 am    Post subject: Reply with quote  Mark this post and the followings unread
uncle
could you explain your r2r idea in a little more detail
i am intrigued but dont quite follow the method!
thanks
bugbrand
PostPosted: Wed Feb 13, 2008 5:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Have a read about R-2R ladders on Wikipedia - basis of simple Digital to Analog conversion.
http://www.bugbrand.co.uk
PostPosted: Wed Feb 13, 2008 5:59 am    Post subject: Reply with quote  Mark this post and the followings unread
An R/2R ladder is a type of Digital to Analogue converter. It's not hard to build a basic one of your own, and I thought it would be cool to have one on a Lunetta 'cos you could then patch up any array of changing digital signals and hear them transformed into a 4, 6, maybe even 8 bit analogue output. You can buy R/2R networks built into a chip, but I think it would be more fun to build your own. I've attached an R/2R network which I found in Ray's scanning matrix keyboard encoder.
The data is applied to the inputs on the left, the bits are "added" to produce a voltage at the output of the buffer. The value of the resistors need to be pretty much spot on to keep it accurate, (it doesn't need to be accurate to work) (I don't know why Ray went for 1M and 499K? Confused )
 Filesize:  4.76 KB
 Viewed:  23680 Time(s)
loss1234
PostPosted: Wed Feb 13, 2008 6:42 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks uncle. now do were you saying this could be done with a lunetta?
richardc64
Audio files: 26
PostPosted: Wed Feb 13, 2008 12:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
If I may...
I think The K is saying that instead of the normal use of an R/2R, getting its inputs from one device, such as a 6- or 8-bit latch or counter, the inputs could each be from various Lunetta modules: 2 oscillators not sync'ed and a couple of shift register outputs clocked by a 3rd oscillator, or any combination of other signals.
Interesting idea.
fluxmonkey
PostPosted: Wed Feb 13, 2008 1:47 pm    Post subject:
Subject description: SL interview from Ear Magazine
from EAR, Vol. 9, Number 1, 1981, Editor: Loren Means
EARInterview: STANLEY LUNETTA by Loren Means
LM: So the Moosack machine was dismantled in 1970?
SL: that's right. Since then I've continued to build more Machines, based on the Moosack Machines. In fact, I tend to call them all Moosack machines just because I think it's a nice name. some of them are meant to be performance Machines, in other words a synthesizer, and others are meant to be self-contained compositions that you don't perform on, you must turn them on and they play.
The performance Machine started out as a simple combination of pieces of equipment that I had built, and as I started adding more to it, it became more or less an integrated system. It's a digital music-making Machine. It makes as many as sixteen polyphonic lines, or you can have keyboard-activated things form it. It has its own memory system, so you can either set it to play or you can set it to do things on its own, or you can perform on it as a performer. It makes live electronic music, right there.
LM: Is this the only machine that can achieve this much complexity in real time?
SL: I don't know. I don't think it should be...
LM: A Moog won't do this, will it?
SL: I don't think so, but I haven't worked with a large Moog system in a long time. What my machine has is sixteen separate voices. Of those sixteen separate parts, eight of them have a choice of eight separate voices. So there are sixteen voices, eight of which are the same voice doing whatever it does, and each of the other eight have a choice of one of eight voices.And the choice changes all the time. Like on channels 1 through 8 you might get sounds S through Z, but you might get sound S on three of the channels and Y on one and X on the other, and the next second you'd have sound V and W coming through all of them.
LM: How are the sounds generated?
SL: It makes pitches through binary relationships. It counts to a number, and when it reaches that number it goes back and counts to that number again, and then it goes back and counts to that number again, and the rate at which it goes back and counts again is the frequency of the pitch. As long as it counts to the same number over and over again, you'll get that same pitch. Now if it counts to a high number it gets a lower pitch than if it counts to a low number, because it takes more time to count to 200 and go back and do it again than it does to count to 2. If you read that out in logical fashion, from the smallest number to the largest number, the pitch will go from high to low.
LM: so you don't mind how mathematical that all is?
SL: The interesting thing to me philosophically about binary processes is that they seem to be nature. We hear in an exponential curve. The difference between A 110 and A 220 is double. Likewise between A 220 and A 440. But the difference between A 110 and A 220 is 110 cycles, while the difference between A 440 and A 880 is 440 cycles, so there are more cycles between those upper two octaves as than there are between the lower two octaves. That's exactly what goes on in the digital process in the Machine. The difference between the Machine and a computer is that there's no interface between me and the machine, as there is in a computer--I don't have to put things on a punch card.
As far as electronic music is concerned, my way of doing it is based on the fact that I have to make the instruments to be able to do the music. I can't conceive of working on a Buchla or a Moog or an ARP, even though they have capabilities that my instrument doesn't have. Mine also has capabilities that theirs don't have. I doubt if the others have a four minute sixteen second glissando.
LM: Back in 1973 I heard the piece you did with the Sacramento Symphony called "The Unseen Force." I understand you got a National Endowment for the Arts grant to finish the piece in 1975. How did the piece come about?
SL: I was the tympanist for the Sacramento Symphony from 1963 to last year. One day in 1972, the conductor, Harry Newstone, commissioned a piece from me. No, you either write a piece because you have suddenly a strong desire to write a certain piece, or else someone asks you to write a piece, and you start thinking how you're going to do it. In the case of this one, I couldn't get started for a long time. And then one day I was sitting in my studio at home and I thought "Oh boy, this is really awful." I'd started several orchestra pieces by then, and they were all stinko, and then one of my friends said, "Why don't you just turn the Machine on and let it play, and then transcribe that for orchestra?"
So we had a couple of yuks over that, and then I thought, "Well, what the hell, I'll turn the Machine on and see what it's playing right now." I had patched this in and that in, and I didn't know what I had it set up at. So I put it on, and it was playing something real simple on one of the voices, a little binary-encoded sixteen note melody, and it was sort of cute.
I listened to it, and I though, "Gee, that's a nice little melody." So I slowed it down and went over to the piano, and tried to accompany it. I found out it was in the key of D, a strange little melody in the key of D, four measures long.
So I transcribed that, and then I made a similar hookup on another part of the Machine and it got a second melody, and I thought,"Gee, these are both really nice," and they each had similar chord progressions, one in the key of D and one sort of in the key of D.
so those melodies became the end of the composition. Then I wrote the rest of the piece backward in time from the ending which the Machine had written, so that the whole orchestra piece is sort of an obscure sent of variations on a theme written by a machine.
LM: do you put the Machine in improvising situations with live musicians?
SL: Sure. I intended the Machine to be used as a live performance type of instrument. so I formed a group called Amra Arma, which we call a "hyborean" performance group. It consists of four drummers, one keyboard-reed instrument, one bass player, and the electronic Machine. I'm one of the drummers, and I get the electronic machine going, but it mainly plays on its own. The group takes its musical impetus from what the machine does.
LM:When the group plays, does the machine decide what they're going to play?
SL: We have developed a series of ways that we work. One is to have the group accompany whatever the Machine does. We do a piece we call our "ritual piece," where I set the Machine up in advance to some setting, then I go through a sort of ritual with the Machine where I work with what it has and try to produce a sort of joint composition with it and myself. Then the other members of the group, once they find what direction I have gone, respond to the Machine, and the Machine through me responds to them, and we get a whole piece. Other times we have the Machine do specific things to go with specific things that the other musicians play. Then at times I adjust the Machine so that it is sensitive to sound that it hears, so that when the drummers play, the Machine accompanies them. So we run the whole gamut, from the live musicians responding to the Machine to the Machine responding to the live musicians, and all the in between areas.
LM: Do you feel you're expressing yourself through the Machine?
SL: Oh, yes.
LM: How does your self relate to a machine?
SL: Hmmm. I don't know. I'd like to be a cyborg. I built a series of helmets for Amra Arma. When we perform we do a whole rite. It doesn't make sense for Amra Arma to perform music as music, because what we do is concerned with more than just music. Consequently we don't walk out and bow and wear tuxedos. There are some costumes, lighting, a fog machine--it's like some sort of a weird modernistic pagan rite. So to walk out and play an electronic music machine would make no sense at all. So my performance attire is integral with what it does. I couldn't perform in any other way. The original helmet looked something like a welder's mask, with lights on it and controls that went to the machine. The second helmet was more elaborate. It has tongue-activated keyboards inside. It's a whole different approach to performing. Instead of standing in front of the Machine like a scientist, I'm more like a priest calling on some sort of weird deity.
LM: last September you had a big show of your Sound Sculpture at the Crocker Museum. Could you describe some of the other Moosack machines you've made?
SL: Sure. The Sound Hat is one of the more fun-provoking ones. It's an Abe Lincoln hat, a little bit bigger, and it's got its own speaker and amplifier built in, battery operated. It's got a little logic system, and oscillators and octave dividers and modulators, which are run by the logic system. The logic system gets its controls from the presence of light and the tilt of the hat, so if it tilts a certain way and the light shines on it, you get a certain set of sounds. So in effect it's a mini-mini-computer that's programmed by its tilt and the amount of light.
Then there's the Dee-Daddle-Dee, that's the telephone Machine. the Dee-Daddle-Dee is a little box you plug in in place of your telephone and then you plug your telephone into it, and take the bell out of the phone. You et it and it'll play little mini-compositions every time the ring signal comes to your telephone. Instead of getting a bell, you get a little short piece. If you feel one way one day and a different way a different day, you can reprogram it to sound differently for each time.
I made a typewriter, which is a computer teletype keyboard, and I use it for several things. first of all, I use it to program memories for my performance Machine. Secondly, you can plug it directly into the performance machine and use it as a keyboard. Instead of a piano keyboard it's a typewriter keyboard, and it's really fun to play. And third, I built into it a little logic system with oscillator and amplifier speaker, so that it's just the size of a small typewriter, and you can take it someplace and plug it in and play compositions on it. you can play names, you don't even have to be able to type to play it, and it's got a simple sound system to play melodies.
then there's the Morthtar-Mat. I call my Chevrolet van a Morthtar. I built a system that's connected to the turn signals, the speedometer, the photoresistors, the doors, the lights, and everything. As you drive you get a composition based on what the car is doing. I used that when I went to North Shore Lake Tahoe to accompany Elvis Presley and Ann-Margaret.
Now I'm building an obelisk, which will be sort of a big performance machine/art object, somewhat like the Transamerica Building in shape. As an art work you'll put it on a particular setting and it's responsive to its environment. It has telephone inputs, altimeters, barometers, radio inputs, sensors for heat and wind direction, all that sort of thing.
LM: When the obelisk was at the Crocker, could the audience program what it played?
SL: When the obelisk is playing, the audience isn't able to overtly change it, but their presence has a lot to do with it. If the environment is too noisy, it makes softer sounds. Alvin Lucier had an idea of a piece where you'd make music that would improve the environment. If the environment was full of loud obnoxious sounds, it would take those sounds and make them more pleasant to your ear, by either softening them or playing around them so that they wouldn't be so loud and obnoxious. The concept of the obelsik is that if there are loud obnoxious sounds around it like people talking loud or shouting, it plays loud enough to cover these and then trough some program gradually diminuendo down to making pretty sounds, hopefully bringing the people along with it.
Its environmental responses and telephone hookup mean that if it's playing in, say, Denver, I can put on the helmet I use to interface with it, call it on the telephone, and respond to the people there through it.
The nicest thing that's happened with electronics is that I can make the music I want to make without having to make it be a commercial success. I can sit down in my studio and make the sounds I want--it's almost incestuous. But on the other hand it's enabling me to think very clearly about how I want my music to be. The ultimate personification of my ideas is the obelisk--it goes out and plays and I don't have to go to rehearsals anymore. Because the making of the Machine is really enjoyable, and when it's all made and it has all of its possibilities, then I can just take it places and have it play.
http://www.o-art.org/history/70's/Composers/Lunetta70s.html
Audio files: 299
PostPosted: Wed Feb 13, 2008 1:53 pm    Post subject:
When you go one page back into the past you'll see that I linked to that one and a few others as well Very Happy
loss1234
PostPosted: Wed Feb 13, 2008 2:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
very interesting.
id like to know more about the "memory system" he mentions and also more about the methods of making melodies out of counting. it actually sounds a lot more complex than a few simple cmos oscillators. or am i wrong about that?
thanks for the clarification of the R2R setup--cool idea. and then you could use the output of that to feed something else correct?
loss1234
PostPosted: Wed Feb 13, 2008 2:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
uncle- you say into a 4 6 0r 8 bit output. now this analog output, this would be for triggers and cv? (or would it be at an audio rate)
i love this idea.
thanks
Audio files: 229
PostPosted: Thu Feb 14, 2008 2:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
To get a better idea of the counters, see this topic. http://electro-music.com/forum/topic-23896.html
loss1234
PostPosted: Thu Feb 14, 2008 10:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks mosc
yeah i had read that topic...i guess i was still a little fuzzy on implementing it.
but i will try to get the concept around my head Wink
John Dinwiddie
PostPosted: Sun Mar 16, 2008 11:01 am    Post subject: Stanley Lunetta
Subject description: good guy
I landed in this website after having done a search on
Stanley Lunetta, just to see what was up with him these
days. I'm pleased to see that there are fans out there
of this remarkable musician whose home brew concoctions
have vexed the neat and tidy ever since his association
with Larry Austin. I doubt that Stan ever needed a mentor
to tell him that it was all right to be himself, but the
influence of David Tudor, who taught live electronic music
in performance at U.C. Davis in 1967, encouraged. David
was like Stan a pack rat who combed places like old
Pacific Stereo for low cost items that eventually found
their way into the soundscapes of the Merce Cunningham
Dance Company.
In my lucky if star crossed days as witness to all that
went down in those heady years at U.C. Davis, Stan Lunetta
stood out. He went into Stockhausen's composition seminar
as himself, came out still refusing to wear Birkenstocks.
Stockhausen admired him grudgingly, once said to me that
when it came to "parameters," Stanley was more interested
in collision than relationship.
I noticed that in the list of "notable students" of KHS that
some wag dismissed as a phone book, that list found in the Wikipedia
entry for Stockhausen, Stanley's name was absent. The above
could be a reason, but I doubt it since Rzewski was also overlooked.
So I'll put him on my list as a notable presence. That's an
understatement. Find out as much as you can about this eccentric,
brilliant man. It will be worth the trip, and you'll get a lot of
laughs along the way.
John Dinwiddie
Deep North Designs
Atonalanoa
Audio files: 299
PostPosted: Sun Mar 16, 2008 11:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Welcome John, thanks for the background info!
Audio files: 229
PostPosted: Mon Mar 17, 2008 1:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
John. Are you the same John D. I remember from when I was a student at M
Mills in the early 70s?
Mosc is short for Howard Moscovitz
Rykhaard
PostPosted: Sun Jun 22, 2008 8:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Uncle Krunkus wrote:
I just thought of a section which could be an R/2R DAC.
"Okay, we take that bit there, that can be the MSB. Now this bit here, (patch, patch) that can be our LSB. Okay, now we take these outputs off those two shift registers, they can be bits 2, 3 and 5. And bit 4 can be the output of this LDR controlled Oscillator."
Man, this could be hella fun! Very Happy Cool
Someone's gone liquid in the sheets,
A sudden smell of burning leaves.
Completely off subject - cool to see quoted lyrics from John Foxx (former, lead for Ultravox). Very Happy
Back to the subject ...... Lunetta related - my very FIRST synthesizer was built around the 4 NANDs in a CD4011. Smile I still somewhat regularly listen to a 1/2 hour long piece that I recorded with it, in 1990. Smile Just the unit played live, through a stack of FX units. One of the best `noise` pieces I`ve ever recorded.
(I can post a link to it if anyone`s innerested.)
RF
Audio files: 28
PostPosted: Sun Jun 22, 2008 8:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm innerested. bounce please post.
bruce
Peake
PostPosted: Sun Jun 22, 2008 8:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Seconded- and then get ready to post a schematic because we'll all want to build one as well Smile
Rykhaard
PostPosted: Sun Jun 22, 2008 9:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wha`! 2 responses that I didn`t expect to see so quickly! Very Happy Coolio. Wink
http://deathlehem.com/wsb4569662401/Samples/mp3/WanderingDepthsWonderingMinds1990.mp3
That`s all 1 url, no spaces. Please let me know if it doesn`t work and I`ll post it differently.
And the schematic ......
http://deathlehem.com/wsb4569662402/schematic.html
It`s the 2nd of the 2 of them on the page. The 1st one is for my Liquid Hihat, that I innovated late last year.
Doh! MISTAKE! I had made the synth. with TWO CD4011`s. Looking at the schematic just now, there was exactly TWO of what`s seen in the schematic. 4 controls and 4 switches. Smile
PostPosted: Mon Jun 23, 2008 6:37 am    Post subject: Reply with quote  Mark this post and the followings unread
i love this idea.
thanks
I was assuming an audio out, but I s'pose it would depend on how fast the bits were changing. I think it would sound better if the MSB end moved slower than the LSB end, but, as I haven't tried it, that may be wrong. I s'pose you could even take the output through a comparator and thereby take it back into the digital world before outputting further down the track. Man, I've gotta get some Lunetta fun happening! Cool
PostPosted: Mon Jun 23, 2008 6:42 am    Post subject: Reply with quote  Mark this post and the followings unread
I just thought what could be really cool would be to have a bank of shift registers "feeding" an R/2R network. Say 8 (or more! Twisted Evil ) running at differing or similar speeds. With their bits being modified by other Lunetta circuits. You could end up with an "endless wavetable" type of sound.
Pehr
PostPosted: Mon Jun 23, 2008 12:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ryk: Wow1 That's one mighty noise track there! Very Happy I guess the stack off effects does add a lot to it, but hey, the sounds are coming from two nand-chips! Wow! Impressive! I got to get myself a lunetta! Cool
YouTube channel
flickr photostream
http://loxodrom.blogspot.com
Rykhaard
PostPosted: Mon Jun 23, 2008 9:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
cyclops
Whoa! That's the best response that I've EVER seen for that track! Very Happy Much-o thank-o-loodies! Very Happy
I don't recall for SURE what each effect was in each unit, but I do have a rough idea:
Boss SE-50: multiple pitch shifting channels including 1 octave down; delay
ART DR-X: including chorus (possibly) and delay
Digitech DSP128: delay
1 of the units for sure, also provided distortion over the entire thing. The very opening with speech was through the SE-50's vocoder.
The only controls on the "Miller WD-12" (Last name; made Without a Drill (front panel) - 1st attempt; 2 oscillators) were:
- Pitch x 4
- Oscillator 1 modulating another 1 switch - ON/OFF
- Oscillator 2 modulating yet another 1 switch - ON/OFF
- 2 oscillators switches - ON/OFF
- (If no modulation is occurring, then you hear up to 4 oscillators, depending on which ones are audibly oscillating. A full clockwise turn, would bring the pitch up past human hearing - essentially 'turned off')
That was it. All manipulated live, directly into the effects units hooked up together, in serial format. Smile
As I'd said - it's still, 1 of my most favourite noise compositions ever! Smile
Much-o glad that you liked! Very Happy
All of this Lunetta talk, has SERIOUSLY brought me back to wondering at venturing back into the 'noise' angle of a few modules again, for the fun of it. Smile
Edit: If you have yourself a few effects units, just build a simple one like I did and jam away! That thing was fun as heck and spawned 6 more versions of itself after it. There're pieces from a few of them, in the My Tunes section of my rykhaard webpage, in my signature. Smile
Tronato
PostPosted: Sun Aug 10, 2008 7:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello!
Impressive Noise Piece!
If you were to rebuild this today, what would you add to the outputs (or anywhere else for that matter) in order to optimize it?
I just ordered 10 CD4011 IC's for this!
If I could only get a sound like that from my SN Voice (which is just sitting there looking at me like Wilson in Tom Hanks Survivor movie) I'd be a happy man! I don't know what to do with it!
TRON
loss1234
PostPosted: Sun Aug 10, 2008 8:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
tron
you could feed the outputs from a lunetta through an R2R, take the output and put it straight into the CV in of the sn voice.
the sn voice would be a great voice to modulate with all manner of lunetta stuff!! if i remember, it has a gate in, and at least one cv in, plus tunable noise...so plug lunetta action into every input you can and use the snvoice as a great output section.
johnyradio
PostPosted: Sat May 03, 2014 2:25 pm    Post subject: beer with Stanley Reply with quote  Mark this post and the followings unread
see Stanley himself demo his 1970's Sound Gun, in San Francisco 2014
http://electro-music.com/forum/topic-61785.html
