Schulte Compact A Phasing
Page 11 of 27 [660 Posts]
Goto page: Previous 1, 2, 3, ..., 9, 10, 11, 12, 13, ..., 25, 26, 27 Next
jhaible
PostPosted: Sun Feb 17, 2008 1:37 pm    Post subject: Re: To 'C' or not to 'C' Reply with quote  Mark this post and the followings unread
whomper wrote:
Well, went in to the store today and found a replacement:
BD239C -> BD241C
You can use it if the beta (hFE, current gain) is high enough.
Guaranteed specs are worse on the 241 than for the 239, so better buy a couple more in case you run int one that's on th elow end of the spec.
BC560C -> BC557C
Yes.
JH.
Now playing: Mike Oldfield, Five Miles Out
23isgood
PostPosted: Mon Feb 18, 2008 1:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi, im just wondering if this is the right transformer for this project,
http://www.mouser.com/Search/Refine.aspx?Ntt=*266J16*&N=1323038&Ntx=mode%2bmatchall&Ns=P_SField&OriginalKeyword=266J16&Ntk=Mouser_Wildcards
thanks
pete
Check out my music
jhaible
PostPosted: Mon Feb 18, 2008 3:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks
pete
No, you need two windings with 16 ... 18V *each*,
or a center tapped winding with 32V ... 36V *total*.
JH.
Now playing: Leonard Cohen, Various Positions
23isgood
PostPosted: Mon Feb 18, 2008 9:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yikes, well does anyone have a Mouser part number for the transformer we need for this project? Apparently it is a challenge to find the right transformer.
thanks
pete
Check out my music
jhaible
PostPosted: Tue Feb 19, 2008 12:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Certainly not. 2 x 18V is a very common type.
JH.
etaoin
PostPosted: Tue Feb 19, 2008 12:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Indeed, they sell it everywhere here.
But odd enough, 23isgood's got a point. Mouser doesn't seem to list any:
No 2 x 18 V ?
 Filesize:  7.39 KB
 Viewed:  17285 Time(s)
http://www.casia.org/modular/
jhaible
PostPosted: Tue Feb 19, 2008 12:47 am    Post subject: Reply with quote  Mark this post and the followings unread
http://www.mouser.com/catalog/633/1866.pdf
Several 2x18V types (described as "36V CT")
The smallest one will do:
http://www.mouser.com/Search/Refine.aspx?Ntt=546-185C36%09
JH.
23isgood
PostPosted: Tue Feb 19, 2008 2:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool thanks. This project requires parts that im not familiar with. I hope I don't drive you guys nuts with my questions, im still trying to find the lamps, lamp socket and relay through Mouser.
Check out my music
morbank
PostPosted: Tue Feb 19, 2008 5:27 pm    Post subject: Lamps, lamp socket and relay. Reply with quote  Mark this post and the followings unread
Hi 23isgood, I'm in the states as well and also had a hard time finding parts online. Here are some places for the parts you asked about. I haven't found sockets that don't cost less than $25 to ship to the US! But like Jurgen said, you can always solder the lamps straight to the board with short stiff wires.
-Clay
Lamp:
http://www.elektronica-online.com/target/content_details.php?id=5428
Lamp Socket:
http://www.hqvideo.hu/info/en/lamp-e10_p.html
Or here:
http://www.francelampes.com/pro/catalog/shopping_cart.php?osCsid=0b762521ee8b77f735347c074fa6e78a
Tobias found this relay:
http://banzaieffects.com/Finder-Relay-30.22-12V-pr-16251.html
morbank
PostPosted: Tue Feb 19, 2008 8:21 pm    Post subject: Lamps, lamp socket and relay. Reply with quote  Mark this post and the followings unread
Well I just received some lamp sockets so I guess I did find them for under $25 shipping! The company is www.greenweld.co.uk, they are located in the UK but shipping was a bit cheaper at $7. The minimum order is a 10 pack for $7.60. Page link below (part ref. #OP1019)
-Clay
http://www.greenweld.co.uk/cgi-bin/sh000001.pl?REFPAGE=http%3a%2f%2fwww%2egreenweld%2eco%2euk%2f&WD=op1019&SHOP=%20&PN=Shop_Bulbs_199%2ehtml%23aOP1019#aOP1019
stegoman
PostPosted: Wed Feb 20, 2008 10:14 pm    Post subject: Re: Lamps, lamp socket and relay. Reply with quote  Mark this post and the followings unread
-Clay
On the same page, Greenweld sells 6v 0.1A bulbs. Would these likely work in place of the 7v 0.1A bulbs called for in the BOM?
It would be great if I could order bulbs and sockets at the same time. And since they are both packages of 10, I could probably split the cost with one or two others here in the USA if there is any interest.
etaoin
PostPosted: Wed Feb 20, 2008 11:31 pm    Post subject: Re: Lamps, lamp socket and relay. Reply with quote  Mark this post and the followings unread
I think you might want to have some spares if they are that difficult for you to get...
Even I have six spares, and I can get the real 7V 100mA easily enough, at the moment. But I don't want to have to search again when the bulbs start dying.
jhaible
PostPosted: Thu Feb 21, 2008 12:24 am    Post subject: Re: Lamps, lamp socket and relay. Reply with quote  Mark this post and the followings unread
The Lamp voltage is quite crucial for the sweep waveform of this phaser. Part of the control shape is _formed_ in these incandescent lamps!
There is the possibility (untested!) to use more common 6.3V lamps and connect a 1N4002 diode in series: The diode's voltage drop of approx. 0.7V should add up to 7V with the lamp's 6.3V . (There are two wire bridges to be replaced with diodes: two diodes for two lamps.)
Fine tuning can be done with the 1k trimmer afterwards. But this really only allows *fine* funing. Th3 6.3V lamps should have similar power rating: Something in the range of 70mA to 150mA I'd say, for experiments.
But let me say it again: This is untested!
You could also experiment with your 6V lamps and put 3 diodes in series with them ("one and a half" diode per lamp Smile ).
It's pobably really woth experimenting with different lamps.
If you want a straight path to the original sound, 7V lamps are the best way, of course.
JH.
stegoman
PostPosted: Thu Feb 21, 2008 10:47 am    Post subject: Re: Lamps, lamp socket and relay. Reply with quote  Mark this post and the followings unread
It's probably really worth experimenting with different lamps.
JH.
Given the key that the bulbs are part of the waveform creation, has anyone found alternate sources for bulbs (or sockets)? Especially in the USA??? Who is the manufacturer of the Bulbs? Sockets? With company names and company part #'s, it will be much easier to search for alternate sources.
Thanks to all for any information!
vtl5c3
PostPosted: Thu Feb 21, 2008 11:15 am    Post subject: Reply with quote  Mark this post and the followings unread
How many people in the USA are building this phaser? Maybe it's time to look at a group purchase of bulbs and sockets.
stegoman
PostPosted: Thu Feb 21, 2008 11:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Count me in. I want a couple of extra bulbs so that, when these finally burn out, I don't have to look all over to get replacements! (Or worse, find out they don't exist 10-15 years from now!)
germaniac
PostPosted: Thu Feb 21, 2008 12:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'd be in for a group-buy of bulbs, since it's overcast here in LA. Wink
23isgood
PostPosted: Thu Feb 21, 2008 1:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Im in on a group buy. Anyone got a Mouser part number for the fuse holder?
How about the relay? Im trying to get as many parts as I can through Mouser, before having to get parts through another supplier.
pete
Check out my music
gavgomad
PostPosted: Thu Feb 21, 2008 1:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'd be in on a group buy as well all.... Dunno if there are any fellow canucks out there, but would those of us north of the border be welcome? Wink
Gavin.
ericcoleridge
PostPosted: Thu Feb 21, 2008 2:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'd like also like to get in on any group buys on rare or expensive components used here.
I haven't bought any parts for this board yet. I'm sort waiting/hoping for someone to document the project a little more (as Bill and Will did with with the Tau Pipe--which helped me to get thru that build).
numbernone
PostPosted: Thu Feb 21, 2008 5:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
I would also be interested in any group buys for the more unusual parts.
jhaible
PostPosted: Fri Feb 22, 2008 4:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's some information I got from Paolo (from Italy):
For the LDR, other than the mentioned Distrelec, I found this one:
http://www.banzaieffects.com/Photo-Cell-1-2k-500k-pr-17338.html
There is no datasheet but the resistance range seems similar to the
one you recommend.
There are a lot of other components used in your projects in this
shop, and also at low prices..
For the 7V 100mA lamp, I found it here:
http://www.calpedel.it/
with product code ME10T7V100
I have no idea how close that LDR is to the one I'm using - just wanted to pass the information on.
JH.
ziwzih
PostPosted: Fri Feb 22, 2008 8:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
I bought these lamps and paid $13.50 for 10 of them. They arrived here in California in a couple of weeks. It wasn't totally cheap but it was completely hassle free!
Luka
PostPosted: Sat Feb 23, 2008 6:31 am    Post subject: Re: Lamps, lamp socket and relay. Reply with quote  Mark this post and the followings unread
-Clay
if anybody in Australia wants lamp sockets or bulbs let me know by Friday next week (1st march i think)
problemchild
melbourne australia
jaidee
PostPosted: Sat Feb 23, 2008 12:45 pm    Post subject: 5W resistor Reply with quote  Mark this post and the followings unread
How critical is the value of the 5W resistor?
120R is not readily available in the UK.
If it is possible to substitute a different value, which is better 100R or 150%?
Incidentally, RS Components do a nice PCB mounting MES E10 lamp holder with pins to go straight into the PCB rather than tags, Part no.171-2580, very modest cost but there is a minumum order number of 10.
