Schulte Compact A Phasing
Page 12 of 27 [660 Posts]
Goto page: Previous 1, 2, 3, ..., 10, 11, 12, 13, 14, ..., 25, 26, 27 Next
jhaible
PostPosted: Sat Feb 23, 2008 12:54 pm    Post subject: Re: 5W resistor Reply with quote  Mark this post and the followings unread
jaidee wrote:
How critical is the value of the 5W resistor?
120R is not readily available in the UK.
If it is possible to substitute a different value, which is better 100R or 150%?
Incidentally, RS Components do a nice PCB mounting MES E10 lamp holder with pins to go straight into the PCB rather than tags, Part no.171-2580, very modest cost but there is a minumum order number of 10.
I don't expect it to be overly critical.
My advice:
Buy a 150R 5 Watt
and a 560R 2 Watt
and connect them in parallel.
JH.
goodrevdoc
PostPosted: Sat Feb 23, 2008 7:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here are some Mouser part #'s for some stuff,
Heatsinks:
532-575002B00
120 ohm 5W resistor:
71-CW5-120
Relay:
655-V23105A5403A201
Fuse Holders:
534-3527
Fuses:
576-0239.200HXP
Here is a 6.3V 150mA screw type lamp that i plan to try, along with base,
Lamp:
606-CM40
Holder:
35LH010
A few questions. On the heatsink, the thermal resistance of the one listed above is 13.6 deg C/W. Is this adequate? This number is lower than the one spec'd in the BOM, but I seem to remember a lower number being "better".
-justin
stegoman
PostPosted: Sat Feb 23, 2008 8:04 pm    Post subject: Re: 5W resistor Reply with quote  Mark this post and the followings unread
Incidentally, RS Components do a nice PCB mounting MES E10 lamp holder with pins to go straight into the PCB rather than tags, Part no.171-2580, very modest cost but there is a minimum order number of 10.
Could you put up the actual link to the item? Also, since there is an attempt to get a USA group order up and running, it would be advantageous if we could get both the lamps and sockets from the same place. It would probably reduce the total shipping costs.
jhaible
PostPosted: Sun Feb 24, 2008 6:11 am    Post subject: Reply with quote  Mark this post and the followings unread
-justin
Lower is better. It's a (thermal) resistance, with the difference of temperature being the equivalent of a voltage, and the energy flow (=power dissipation) being the equivalent of a current.
Power ("current") is a given;
Temperature difference ("voltage") is lower for a lower (thermal) resistance.
JH.
23isgood
PostPosted: Sun Feb 24, 2008 1:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
The BOM calls for 741 op amps, could tl071's be used, or any other single op amp? I ordered the lamps from the link that was posted earlier. Thanks for the Mouser part numbers too!
pete
Check out my music
jhaible
PostPosted: Sun Feb 24, 2008 1:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
pete
TL071's can absolutely not be used.
You may find other opams that work, and I even have provided pads for bypass caps beneath each IC footprint for such experiments.
Here's some requirements for the opamps:
(1) Must work on heavy capacitive load.
(2) Must not have phase reversal when common mode range is exceeded.
(3) Must not do any other crazy stuff outside common mode range.
TL071 fails on (1) and (2).
I've seen expensive "audio" opamps that are advertised for not doing (2), but oscillate instead (3). (They wil work fine in many, many other circuits, but not here!)
IMO, the only reason to try other opamps than the 741 is to find out how it sounds without slew limiting. (Which means nothing else than the circuit distorts earlier for high frequencies than for low and midrange frequencies.) That kind of behaviour is part of the original Schulte Compact A - that's why I specified 741 opamps.
Some may want to try it without this behaviour - that's why I privided pads for bypass caps.
So, my recommndation:
Either go for 741 chips, or experiment with others, and post your results!
JH.
hachiman
PostPosted: Sun Feb 24, 2008 3:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
what about all the different 741 breeds ? like uA and the rest... I can obtain several vintage age 1980 uA 741s...
BTW Jürgen I sent you IBAN on thursday, deposit happened on friday actually , the 2x set .
TheAncientOne
PostPosted: Sun Feb 24, 2008 9:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
If anyone in the UK needs some lampholders, I got 10 from RS, and have 6, (3 sets) going spare - I'm keeping a pair, 'just in case'. PM me if it's of interest.
BTW - Jurgen. I believe I have a good original copy of 'In a Glass House' here - my brother and I were discussing your stamps the other day, (I did live sound work back in the 70's including at least 1 GG gig - have you ever tried mic'ing up a small pipe organ? and that was before they produced recorders - you know the wooden things you blow down). If I can find it, (it had the transparent 'glasshouse' front), then I'll trade it for credit on future PCB's
Mike
whomper
PostPosted: Sun Feb 24, 2008 9:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
jhaible wrote:
pete
JH.
Oh, so the reason for putting the 100nF SMD is only to change the above mentioned behavior.
In that case, if I want to be as near authentic as possible, I would not need to solder them, right?
Whomper
morbank
PostPosted: Mon Feb 25, 2008 3:01 pm    Post subject: BOM Questions? Reply with quote  Mark this post and the followings unread
Is the 100nF "u1" capacitor labeled "1u" on the PCB?
I can't find where the 22uF and 100uF electrolytic caps go on the PCB. There isn't a quantity specified either. Are these caps meant as alternatives to the 10uF tantal and 47uF electrolytic caps?
Thanks, Clay
jhaible
PostPosted: Tue Feb 26, 2008 10:25 am    Post subject: Re: BOM Questions? Reply with quote  Mark this post and the followings unread
1u = 1uF - should really be what it says.
Seems the entries weren't deleted when I was re-using the table, and copying and pasting.
No quantity = 0.
So, these go into your drawer if you have already bought them. Sorry.
JH.
morbank
PostPosted: Tue Feb 26, 2008 11:26 am    Post subject: BOM Questions? Reply with quote  Mark this post and the followings unread
[url]1u = 1uF - should really be what it says. [/url]
I was just thrown off by the ("u1") on the BOM after the 100nF Cap. So there is no "u1" on the PCB then?
[url]Seems the entries weren't deleted when I was re-using the table, and copying and pasting.
No quantity = 0.
So, these go into your drawer if you have already bought them. Sorry. [/url]
No biggie, just double checking.
-Clay
jhaible
PostPosted: Tue Feb 26, 2008 11:34 am    Post subject: Re: BOM Questions? Reply with quote  Mark this post and the followings unread
The 100nF is near the 4007 IC. Yes, even marked as 100n and not as u1.
The only reason I'm sometimes using "u1" is because it saves board space. (You have to keep 12 mil distance to pads, or whatever design rules you're working with.) Here, enough space - more common labeling as "100n".
Might even have printed "100nF". Smile
JH.
qwave
PostPosted: Tue Feb 26, 2008 11:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Finally I heard the Compact Clone a friendly forum member soldered for me solder-iron-beginner so quick.
The sound is _very_ close to the memories of the original phaser I had here about 4 weeks ago.
I spend nearly 30 minutes doing manual sweeps with some Mellotron vs. Roland M-VS1 only recording
Now I have to wait for the 19" rack to arrive. I will "stuff" the board and the transformer into a 2 unit high rack housing. I will take this phaser also on stage for the next berlin school live gig. And I really prefer a pre cabled rack than a stomp-box with an external power supply.
I will upload a picture of the finished CC when its in his housing.
Thanks to Jürgen for his well known quality R&D and selling the PCBs with LDRs to us.
And thanks to b-funk for nice, tidy and fast soldering.
Your two names will be on the front panel !!!
keep on turning these knobs
Till "Qwave" Kopper
http://www.till-kopper.de
morbank
PostPosted: Tue Feb 26, 2008 12:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Makes sense to me. Thanks for clarifying.
-Clay
b-funk
PostPosted: Tue Feb 26, 2008 2:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks for the props, qwave...
now i´m a bit ashamed... Embarassed
23isgood
PostPosted: Thu Feb 28, 2008 1:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Here are some part numbers for rack mount cases and the solid lid from Mouser. These are the cases im going to order.
http://www.mouser.com/Search/ProductDetail.aspx?R=CH-14401virtualkey56310000virtualkey563-CH-14401
http://www.mouser.com/Search/ProductDetail.aspx?R=C-14441virtualkey56310000virtualkey563-C14441
Check out my music
jhaible
PostPosted: Thu Feb 28, 2008 2:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
whomper wrote:
jhaible wrote:
pete
JH.
Whomper
If you're using 741 opamps, I don't expect the bypass caps to make any difference. I haven't soldered them in on my own boards.
JH.
23isgood
PostPosted: Thu Feb 28, 2008 8:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh, I just realized that the lamps may not fit in those 1U rack cases. Is it possible to get measurements of the height of the pcb with lamps installed? Just want to make sure I get the right case.
Check out my music
jhaible
PostPosted: Thu Feb 28, 2008 11:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
You need about 5cm.
If you want it rackmounted, you need 2U at least.
JH.
23isgood
PostPosted: Fri Feb 29, 2008 12:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks! Here is the 2U rack,
http://www.mouser.com/Search/ProductDetail.aspx?R=CH-14403virtualkey56310000virtualkey563-CH-14403
Check out my music
Usine Karate
PostPosted: Mon Mar 03, 2008 4:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi jurgen,
I'm just about to commence getting parts for the phaser and wondered which parts to omit if I want to run it off 15v modular supply, I notice you have been kind enough to supply these details for the Tau and the Solina, will you be doing the same for all your projects?
Usine
jhaible
PostPosted: Mon Mar 03, 2008 11:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Usine Karate wrote:
Hi jurgen,
Usine
Hi Usine,
that's pointed out in the schematics:
http://www.jhaible.heim.at/compact_clone/jh_krautrock_phaser_sch.pdf
Omit all the parts within the frame "standalone version only", and solder in that MOTM connector instead.
Best Regards,
JH.
Usine Karate
PostPosted: Tue Mar 04, 2008 1:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Jurgen,
Sorry, I hadn't even looked at schematics yet Embarassed
Usine
austrohungaro
PostPosted: Tue Mar 04, 2008 4:05 am    Post subject: 5w resistors Reply with quote  Mark this post and the followings unread
I cant find 5W resistors Vertical Mount
I only found axial but leads are too short (or body too tall) to fin in the PCB
Where did you find them?
Is is important to be exactly 5W??
Any link, supplier, advice?
Thanks
