PS3100 Resonators 2008
Page 2 of 7 [175 Posts]
bronti23
PostPosted: Fri Feb 29, 2008 2:32 am    Post subject: Reply with quote  Mark this post and the followings unread
2 for me ..........thanks
vtl5c3
PostPosted: Sat Mar 01, 2008 7:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
You could try putting a switch across the charge capacitor, like a JFET maybe... Not sure how well that would work. I think the Korg MonoPoly LFO's reset was done that way.
fonik wrote:
sound wrote:
Is it possible to add a gate to the LFO ? I mean restart the cycle with a pulse or trigg.
this is a very simple LFO. i wouldn't know where to insert the sync signal. in fact i would have to do some research on this matter (which oscillator core is syncable and how?)...
prophei
PostPosted: Sat Mar 01, 2008 10:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
1 for me, thank you!
/mr
PostPosted: Sun Mar 02, 2008 6:20 am    Post subject: Reply with quote  Mark this post and the followings unread
MG2 (the arpeggiator LFO) on the Mono/Poly uses an NPN transistor to discharge the cap. This is done when pressing a key that restarts the arpeggiator clock.
However, the LFO core is a triangle oscillator, and I expected such a discharge to reset the LFO to either 0 or 180 degrees of its period, whichever is closest (see my previous post in this thread). But it seems to reset to 0 degrees every time, just as it should be done in this application. Can anybody explain why? Smile
The M/P MG2 schematics are attached.
Korg Mono/Poly MG2 schematics
 Filesize:  27.21 KB
 Viewed:  12083 Time(s)
Photon
PostPosted: Sun Mar 02, 2008 11:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Sounds great. Count me in for 1.
Peter
chriswilliams
PostPosted: Sun Mar 02, 2008 6:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Please count me in for 2 - thanks for doing a re-run, as I missed the first! Very Happy
PostPosted: Mon Mar 03, 2008 2:13 am    Post subject: Reply with quote  Mark this post and the followings unread
i received enough advance-orders for a 2nd run according to our Recommendations for PCB offers on electro-music. again thank you all for your interest, i am truly overwhelmed.
I'LL TAKE ORDERS UNTIL Fri 7 MAR 08 13:00 UTC
i'll send the files to the manufacturer then. it will take two more weeks to the PCBs arrival and then i will have to populate and test one. if the PCBs are fine i will PM you concerning payment (paypal preferred). if not, i will have some realy nice and fancy beermats Wink ) anticipated date of delivery is last week of march.
the new documentation will hopefully be done this week.
PostPosted: Mon Mar 03, 2008 6:27 am    Post subject: Reply with quote  Mark this post and the followings unread
everyone who contacted me so far (using PM, email or post in the thread) is put on the list. i just wanted to let you know, that i have not had the time to PM everyone who placed an order yet.
i will confirm your orders the next days.
norman phay
PostPosted: Mon Mar 03, 2008 11:43 am    Post subject: Reply with quote  Mark this post and the followings unread
If you could bung me down for a couple of these as well, Matthias, that would be great.
Many thanks.
PostPosted: Mon Mar 03, 2008 11:46 am    Post subject: Reply with quote  Mark this post and the followings unread
the privilege and pleasure is mine...
vtl5c3
PostPosted: Mon Mar 03, 2008 12:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Has anyone modded their PS3100 clone so that:
- Each filter stage has its own audio output?
- All filter stages can be controlled by one CV?
/mr
PostPosted: Mon Mar 03, 2008 12:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
I surely will, when it arrives. Smile
All good mods like these would be interesting to hear about.
vtl5c3
PostPosted: Mon Mar 03, 2008 1:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Looking at the schematic, the three individual outputs are easy to do: just add a 1K resistor to each filter opamp's output (i.e. where the left side of the 10K resistor connects on the schematic).
This would be a nice mod since it would allow panning each filter section in a different part of the stereo field.
I think that for the summed CV input, you should be able to just add another 270K resistor to the base of each NPN transistor (Q1, Q3 and Q5) and connect the other ends of the resistors to an (attenuated) input jack. I think that this is how the MOTM 410 does it.
PostPosted: Mon Mar 03, 2008 1:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
<snip>
if you take a look at the building docs you will see that i just used and recommended switching jack sockets (kind of multiple). actually each filter stage has it's own cv in. you can achieve different options by different wiring...
vtl5c3
PostPosted: Mon Mar 03, 2008 2:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah. you're right. I see it now. Very clever! Wink
fonik wrote:
<snip>
PostPosted: Mon Mar 03, 2008 3:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
all credits go to Scott Stites, the master of switching jack sockets!
PostPosted: Tue Mar 04, 2008 7:41 am    Post subject: Reply with quote  Mark this post and the followings unread
everyone who placed an advance order should have received a PM, now. check your PM inbox. i just wanted to let you know that i received your order and put you on the list. you don't have to reply these PMs unless the info is not correct.
PostPosted: Fri Mar 07, 2008 12:54 am    Post subject: Reply with quote  Mark this post and the followings unread
last call...
(i will order some spare PCBs anyway).
PostPosted: Fri Mar 07, 2008 6:31 am    Post subject: Reply with quote  Mark this post and the followings unread
PCBs ordered.
i am still taking advance orders since i ordered a view spares...
PostPosted: Mon Mar 17, 2008 4:42 am    Post subject: Reply with quote  Mark this post and the followings unread
FYI
manufacturer shipped the PCBs. they will hopefully arrive before easter.
emmaker
PostPosted: Mon Mar 17, 2008 3:25 pm    Post subject: Reserved 3? Reply with quote  Mark this post and the followings unread
Matthias,
Either on the 6th or 7th tried PM a request for 3 units. Do not know if it went through or not.
So I'd like to reserve 3 if they have not already done so.
Thanks much.
Jay S./emmaker
ericcoleridge
PostPosted: Mon Mar 17, 2008 11:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
I was wondering if anyone has tried to build this circuit with different frequency ranges, like a small filter bank/graphic equalizer? Would this be a worthwhile pursuit?
What do you think Matthias? Is this a pointless idea?
I guess it would be a matter of changing capacitor values on each stage, and then perhaps taping the individual outputs. But I'm not sure how one would go about calculating (roughly) the values of each cap/stage in order to produce various frequency bands/ranges.
PostPosted: Tue Mar 18, 2008 12:01 am    Post subject: Re: Reserved 3? Reply with quote  Mark this post and the followings unread
emmaker wrote:
Matthias,
Thanks much.
Jay S./emmaker
it didn't went through!? anyways, i put you down for 3 PCBs now.
PostPosted: Tue Mar 18, 2008 12:08 am    Post subject: Reply with quote  Mark this post and the followings unread
i don't think it's worth it (just my two pence). they already provide variable center frequency. the three filters are voltage controlled using vactrols. that's the clue and it would be a very expensive solution for a filter bank.
for a smaller fixed filter bank i'd used a simpler circuit. you may want to take a look at analog devices interactive filter designer tool:
http://www.analog.com/Analog_Root/static/techSupport/designTools/interactiveTools/filter/filter.html
/mr
PostPosted: Tue Mar 18, 2008 5:03 am    Post subject: Reply with quote  Mark this post and the followings unread
A graphic eq doesn't make much sense, as the resonator is more similar to a parametric eq. But it would be very interesting to add some adjustable parameters like Q and boost/cut to the circuit - and turn it into a voltage controlled parametric eq. I'll definitely look into these possibilities.
Regarding frequency ranges, try with different capacitor values. I can't find the formulas for this particular BPF configuration, but... if somebody has them or calculates them, please shout. Smile
