today> Twyndyllyngs Chez Mosc
PS3100 Resonators 2008
Page 3 of 7 [175 Posts]
ericcoleridge
PostPosted: Tue Mar 18, 2008 10:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, I guess I chose my words poorly. Obviously, no one wants a graphic equalizer-- but rather, I was imagining something closer to the Moog Filter Bank module/String Filter/ Parametric EQ/ Etc.
I just don't know if there is any point in limiting the frequency range of the various stages of this design-- or if it would be a more functional design to leave it the way it is with three filters at full frequency range. I guess it depends on what one wants to use the design for. I don't think the extra cost of vactrols necessarily makes them a poor design choice for a parametric eq.
/mr
PostPosted: Tue Mar 18, 2008 10:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Did you really intend to limit the range, not to move it?
And how "full" is the peak frequency range to begin with? I guess it's not 20-20000 Hz, so using different capacitor values in order to shift them a bit to different ranges sounds imho more useful than having them at identical ranges.
Now I see in this SOS article that the resonator works over the range 100Hz-10kHz, that is just half the audible spectrum. Giving them ranges like
40Hz-4kHz
80Hz-8kHz
160Hz-16kHz
would probably be more useful when used more like a parametric eq.
No, definitely not. But for a graphic one. Smile
ericcoleridge
PostPosted: Tue Mar 18, 2008 10:58 am    Post subject: Reply with quote  Mark this post and the followings unread
40Hz-4kHz
80Hz-8kHz
160Hz-16kHz
Do you think that substituting cap values for various ranges as used in opamp feedback path of a filter bank like this, for instance, might be somewhat applicable to the Resonator?
/mr
PostPosted: Tue Mar 18, 2008 11:33 am    Post subject: Reply with quote  Mark this post and the followings unread
/mr wrote:
...just half the audible spectrum. Giving them ranges like
40Hz-4kHz
80Hz-8kHz
160Hz-16kHz
The filter topology is different, so it's hard to say directly...
but the R's and C's around the OPamp determine the frequency and Q.
Does anybody have the filter formulas for our PS resonator at hand?
I haven't been able to find them anywhere yet.
PostPosted: Wed Mar 19, 2008 2:27 am    Post subject: Reply with quote  Mark this post and the followings unread
i finished the building docs for the 2nd run PCBs:
http://www.modular.fonik.de/pdf/PS3100.pdf
i will have no access to internet or email for the next 2 weeks! Shocked we are moving and the provider is not able to move the wideband connection without downtime.
hopefully i will have some good news as soon as i am online again...
so have a nice one.
Tronato
PostPosted: Fri Mar 21, 2008 2:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello!
One for me please!
TRON
Peake
PostPosted: Sun Mar 23, 2008 12:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've always wanted 16 channels of VC BPF for resonation (fixed filters, unless using integrators, displease). One thought was to have a global CV input called Spread, which would, from a single CV, move all of the filters apart in frequency (the middle ones just a little, and the outer ones increasingly more and more, requiring trimmed inverting CV paths for half of the filters). Playing with the audio ins on the Andromeda, playing the 16 voice's filters via the keyboard and ribbon gives rise to this modular concept.
But now I'm reading that this design is only functional across half of the audio spectrum. Confused
mono71
PostPosted: Mon Mar 24, 2008 7:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Matthias,
is there place for one PCB reservation ?
If yes, please add mine.
Thanks
Gustavo.-
/mr
PostPosted: Tue Mar 25, 2008 8:23 am    Post subject: Reply with quote  Mark this post and the followings unread
VC but fixed? Wink (ok, just kidding, I see your point)
Yes, but would you really need ALL the bands to go over the WHOLE audio spectrum?
I wonder how wide the span could be made with this construction. Some filter formulas would be nice, hint hint. Smile
widdly
PostPosted: Tue Mar 25, 2008 7:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'd say it's much more than half the audio spectrum. 100Hz to 10kHz is more like 90% of the audio spectrum if you think in terms of octaves.
Filter formula would be nice. There are some formula for Single Op-Amp Bandpass Filter here.. http://ourworld.compuserve.com/homepages/Bill_Bowden/opamp.htm#bandpass.gif
.. but the topology looks a bit different from the ones here. Anyway I think those figures would be guesstimates considering the tolerance of vactrols.
/mr
PostPosted: Wed Mar 26, 2008 3:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Interesting... How do you explain the almost 2½ lost octaves between 20Hz and 100Hz, and the one above 10k? Wink
No, 100-10k is 6.6 octaves, which means 66% of the audio spectrum.
I got it a bit wrong when I said it was just half the spectrum, I was thinking 100*100 instead of 100*10.
Not the tolerance, but the resistance span.
VTL5C3/2 has a rated ON resistance of 2 kohms (at 40 mA, ouch!) or 55 kohms (at 1 mA). Its OFF resistance is 10 Mohms (after 10 seconds). Between these values the span could get as big as 5000x (which means 12 octaves if the filter frequency is linearly dependant of the Vactrol resistance), but practical considerations in current and timing will limit the span quite a bit...
/mr
PostPosted: Wed Mar 26, 2008 4:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
A quickly calculated transfer function, to begin with... does it seem reasonable for a single resonator? Smile
Bedtime here now, so I'll pass the analysis along to other continents while sleeping.
schematic of one resonator
 Filesize:  8.42 KB
 Viewed:  13933 Time(s)
transfer function of one resonator
 Filesize:  21.02 KB
Cat-A-Tonic
PostPosted: Fri Mar 28, 2008 10:54 am    Post subject: Reply with quote  Mark this post and the followings unread
I would like a PS3100 PCB please.
Master of Circles
PostPosted: Sun Mar 30, 2008 2:25 am    Post subject: Reply with quote  Mark this post and the followings unread
as I wrote in the PM or was it an email??
Two Boards please.
PostPosted: Mon Mar 31, 2008 1:13 am    Post subject: Reply with quote  Mark this post and the followings unread
i am online again. still don't have net access at home, though.
PCBs have arrived and i will populate and test one this week. we moved to our new home last week and there is still a lot of work to do. however i started to arrange my new S-DIY workspace!
thanks to you all for your patience.
PostPosted: Fri Apr 04, 2008 3:59 am    Post subject: Reply with quote  Mark this post and the followings unread
finished the test PCB yesterday and it is resonating...
i will do some additional testing on weekend and review the original thread of the 1st run for additional info that might will be incorporated into the documentation.
await PMs containing payment info on monday. there are at least two projects going to be released this week on e-m (the buchla 281 clone will provide some nice functions for the resonators, i think) - so don't spend all your money on the weekends amusements Wink
/mr
PostPosted: Fri Apr 04, 2008 5:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Aaaahhhh, Buchla... and the 281 - one of the modules I was planning to clone! How good to hear! Very Happy
PostPosted: Fri Apr 04, 2008 5:42 am    Post subject: Reply with quote  Mark this post and the followings unread
yeah, i am realy keen on josh's b281 PCBs. he did an outstanding job on these. ...and my new cabinet will be filled faster then i wanted to...
PostPosted: Sun Apr 06, 2008 11:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
here are some pics of the new resonator:
the bare board
enough room for 500V silver mica caps
the populated PCB
testing
and last but not least my new workspace (i used to solder on my computers desk until now)
i will start to send out PMs later this day. i won't be able to PM everyone today, so just give me two days or three...
asafnetzer
PostPosted: Mon Apr 07, 2008 12:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Have just seen those pictures on flickr, looking great.
500V capacitors Shocked
/mr
PostPosted: Mon Apr 07, 2008 2:24 am    Post subject: Reply with quote  Mark this post and the followings unread
What does this voltage rating mean practically? For electrolytic caps, I've heard that one should choose a voltage rating near the voltage used in the actual construction. Does it matter at all for silver mica caps?
(I saw at Banzaieffects/Musikding that all capacitance values might not be available in lower voltage ratings.)
PostPosted: Mon Apr 07, 2008 3:29 am    Post subject: Reply with quote  Mark this post and the followings unread
these big caps just look so good. very impressing.
i've heard, the higher the voltage rating the lower the ESR. i don't think i would hear/experience any difference. in fact i actually don't know what difference i should or could experience Laughing
maybe one of the experts could chime in?
PostPosted: Tue Apr 08, 2008 4:05 am    Post subject: Reply with quote  Mark this post and the followings unread
everyone who expressed interest in one or more PCBs should have recieved a PM now. if not, don't hesitate to contact me.
PostPosted: Sat Apr 12, 2008 12:24 am    Post subject: Reply with quote  Mark this post and the followings unread
all PCBs are now spoken for. however i will start a waiting list in case not all ordered PCBs get sold in the end.
BTW the first PCBs reached destination.
i'd really like to see pictures of what you've done with them. i mean, last year i sold 100(!) Resonator PCBs and saw only 5 pictures of finished modules...
prophei
PostPosted: Sat Apr 12, 2008 5:28 am    Post subject: Reply with quote  Mark this post and the followings unread
i hope you got my paypal in time Smile
