 Forum index » Clavia Nord Modular » Nomad - NM1 Open Source Editor
Setting up a nomad debug environmment on windows (vista)
Page 3 of 3 [66 Posts]
Goto page: Previous 1, 2, 3
PostPosted: Sat Apr 05, 2008 4:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
You had some disable code in ProtocolReceiver that I uncommented, involving the "closed" variable.
The simple patch was loaded again.
In ProtocolReceiver.send() I do not get an IllegalStateException( "receiver closed") and I do not get reception, so there is definitely no reply on the IAmMessage.
Could it be that the IAm is being sent too soon after the MidiPort was opened?
Edit : and close() is not being called.
PostPosted: Sat Apr 05, 2008 4:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
I tried to implement retries on the IAm, but that code didn't work Ok, I'm going to look further into that now.
chresan
PostPosted: Sat Apr 05, 2008 4:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
I don't think so, but you can add in Nordmodular.connect()
Code:
            try
                Thread.sleep(2000); // time in ms
            catch (InterruptedException e)
                e.printStackTrace();
before
Code:
                protocol.send(new IAmMessage());
http://nmedit.sf.net
chresan
PostPosted: Sat Apr 05, 2008 4:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
What happens when you remove the code which sends/accepts the IAMMessage?
Code:
            multicaster.addProtocolListener(iamAcceptor);
            if (log.isInfoEnabled())
                log.info("sending "+IAmMessage.class.getName()+", expecting reply...");
            try
            catch (Exception e)
                if (log.isWarnEnabled())
                    log.warn("sending "+IAmMessage.class.getName()+" failed", e);
                throw new SynthException(e);
            final long timeout = 10000; // 10 seconds
            iamAcceptor.waitForReply(protocol, timeout);
            IAmMessage iam = iamAcceptor.getFirstMessage();
                log.info("received "+IAmMessage.class.getName()+": "+iam);
            validateVersion(iam, 3, 3);
            deviceId = iam.getDeviceId();
            serial = iam.getSerial();
            serial = 0;
            deviceId = IAmMessage.NORD_MODULAR_KEYBOARD;
chresan
PostPosted: Sat Apr 05, 2008 4:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
This problem is really really strange (and persistent).
Do you have a way to find out if the IAMmessage sent by Nomad actually makes its way to the synth ? Perhaps use some tool to intercept the messages outside of the Java VM / Nomad.
You can use http://www.midiox.com/ to create virtual midi devices and use them to intercept the messages, but I don't know if the tool works in vista.
P.S.: I am going to bed now. Shocked
PostPosted: Sat Apr 05, 2008 4:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
You were right Crying or Very sad the delay does not help, 5000 ms neither, it cant be that slow ...
The MIDI out light on the MIDI interface never lits up ...
Laughing hadn't seen your message when I typed this
I should be doing something else tomorrow, but will come back on it. When you have any ideas please post 'm.
Sleep well, and thank you!
chresan
PostPosted: Sat Apr 05, 2008 5:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
You were right Crying or Very sad The MIDI out light on the MIDI interface never lits up ...
At least we got a step closer to the real problem Laughing
... Sleep well
Thanks.
, and thank you!
No problem.
Good night
cappy2112
PostPosted: Sat Apr 05, 2008 6:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Do you mean MidiYoke? It is on the same website as Midiox,
but Midi Yoke is a driver, not an application. The system needs to be rebooted after installation.
It works great on XP
BTW- there was an update to MidiYoke NT release in Sept 2007- it now supports up to 16 virtual midi interfaces, instead of the previous 8.
PostPosted: Sat Apr 05, 2008 7:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Tony,
yes yoke would be the thing to use. The midi-ox pages say nothing about vista compatibility BTW, so probably, as it's a driver, it will not work.
Not a problem though in this case as I have 3 midi ports working so I can just plug in two midi splitters for midi debugging Very Happy Erm .. and they should be .. some . where .. if only .. Shocked Laughing
Still I'll try midi yoke later, as indeed it's a great tool, and I use it all the time ...
BTW PS OT .. i got the G2 beta working ok on vista, and the clavia nm editor works ok as well.
cappy2112
PostPosted: Sat Apr 05, 2008 7:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wanna borrow my reading glasses? Smile
The NM editor? Who would have thought...
G2beta-is this just a USB driver update or are there new features in the editor? In the OS? Modules?
Come one Jan-meet you at Bangs- I'm buying!
PostPosted: Sat Apr 05, 2008 7:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey come on, I'm not that blind Laughing it's clearly visible when seen ! and it's in a box, somewhere in this room or another!
The G2 update is just a driver thing.
And bad news .. the Bang thing as it was doesn't exist anymore I was told, it was sold to someone else and he didn't seem to bother to build it up again after the winter (each winter these beach things are torn down to be rebuilt in spring, a weird legislation thing .. don't ask).
cappy2112
PostPosted: Sat Apr 05, 2008 7:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
How disappointing- for me at least. I know there are a lot of Vista victims out there who will be happy though, that was the primary reason for this anyway.
Clavia's Swan Song for the G2
And bad news .. the Bang thing as it was doesn't exist anymore I was told, it [/quote]
well, at least I have some pictures (and memories)
There's a great little place in SF ......
PostPosted: Sat Apr 05, 2008 7:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
One day ... hopefully with ships being involved ... I like flying, but not that long really ...
cappy2112
PostPosted: Sat Apr 05, 2008 7:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm off to Japan next week- but they put us in Bus. class- so that makes it a bit more comfortable. Will take a micro with me, but after 12+ hours @ work + after hours dinners, I may not be able to see the editor screen (even with my reading glasses on) Wink
PostPosted: Sat Apr 05, 2008 8:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
One day brought me to one time ... Laughing
have fun in Japan, with or without the micro ... !
PostPosted: Mon Apr 07, 2008 3:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Christian,
I have no idea what I changed ... or did wrong before ... but I screwed up everything and then just reloaded all from SF, redid the whole configuration thing, and now it just connects Shocked even with the complicated patch ....
Twisted Evil
