The site will be down to cut over to a new server on Tuesday, May 26, at 10 PM EDT (May 27, at 2 AM GMT)
We will be down for about 2 hours. Check back and you see a message in red indicating we are on the new server.
You had some disable code in ProtocolReceiver that I uncommented, involving the "closed" variable.
The simple patch was loaded again.
In ProtocolReceiver.send() I do not get an IllegalStateException( "receiver closed") and I do not get reception, so there is definitely no reply on the IAmMessage.
Could it be that the IAm is being sent too soon after the MidiPort was opened?
Edit : and close() is not being called. _________________ Jan
9 3 4 .. erm .. not 13 then? .. hmm, ah eight! .. yeah yeah as in 8647 .. 47 is an 88 .. pwew .. numbles! Last edited by blue hell on Sat Apr 05, 2008 4:39 pm; edited 2 times in total
I tried to implement retries on the IAm, but that code didn't work Ok, I'm going to look further into that now. _________________ Jan
This problem is really really strange (and persistent).
Do you have a way to find out if the IAMmessage sent by Nomad actually makes its way to the synth ? Perhaps use some tool to intercept the messages outside of the Java VM / Nomad.
You can use http://www.midiox.com/ to create virtual midi devices and use them to intercept the messages, but I don't know if the tool works in vista.
P.S.: I am going to bed now. _________________ ----------------------
http://nmedit.sf.net
You were right the delay does not help, 5000 ms neither, it cant be that slow ...
The MIDI out light on the MIDI interface never lits up ...
hadn't seen your message when I typed this
I should be doing something else tomorrow, but will come back on it. When you have any ideas please post 'm.
Sleep well, and thank you! _________________ Jan
Joined: Dec 24, 2004 Posts: 2508 Location: San Jose, California
Posted: Sat Apr 05, 2008 6:15 pm Post subject:
Do you mean MidiYoke? It is on the same website as Midiox,
but Midi Yoke is a driver, not an application. The system needs to be rebooted after installation.
It works great on XP
BTW- there was an update to MidiYoke NT release in Sept 2007- it now supports up to 16 virtual midi interfaces, instead of the previous 8. _________________ Free Tibet. Release the Panchen Lama from prison. Let the Dalai Lama return to his home.
yes yoke would be the thing to use. The midi-ox pages say nothing about vista compatibility BTW, so probably, as it's a driver, it will not work.
Not a problem though in this case as I have 3 midi ports working so I can just plug in two midi splitters for midi debugging Erm .. and they should be .. some . where .. if only ..
Still I'll try midi yoke later, as indeed it's a great tool, and I use it all the time ...
BTW PS OT .. i got the G2 beta working ok on vista, and the clavia nm editor works ok as well. _________________ Jan
Hey come on, I'm not that blind it's clearly visible when seen ! and it's in a box, somewhere in this room or another!
The G2 update is just a driver thing.
And bad news .. the Bang thing as it was doesn't exist anymore I was told, it was sold to someone else and he didn't seem to bother to build it up again after the winter (each winter these beach things are torn down to be rebuilt in spring, a weird legislation thing .. don't ask). _________________ Jan
Posted: Sat Apr 05, 2008 7:38 pm Post subject:
How disappointing- for me at least. I know there are a lot of Vista victims out there who will be happy though, that was the primary reason for this anyway.
Clavia's Swan Song for the G2
And bad news .. the Bang thing as it was doesn't exist anymore I was told, it [/quote]
well, at least I have some pictures (and memories)
There's a great little place in SF ...... _________________ Free Tibet. Release the Panchen Lama from prison. Let the Dalai Lama return to his home.
One day ... hopefully with ships being involved ... I like flying, but not that long really ... _________________ Jan
Posted: Sat Apr 05, 2008 7:56 pm Post subject:
I'm off to Japan next week- but they put us in Bus. class- so that makes it a bit more comfortable. Will take a micro with me, but after 12+ hours @ work + after hours dinners, I may not be able to see the editor screen (even with my reading glasses on) _________________ Free Tibet. Release the Panchen Lama from prison. Let the Dalai Lama return to his home.
have fun in Japan, with or without the micro ... ! _________________ Jan
I have no idea what I changed ... or did wrong before ... but I screwed up everything and then just reloaded all from SF, redid the whole configuration thing, and now it just connects even with the complicated patch ....
