 Forum index » Clavia Nord Modular » Nomad - NM1 Open Source Editor
second
Page 1 of 1 [5 Posts]
consam
PostPosted: Wed Apr 23, 2008 1:41 pm    Post subject: second
Subject description: midi timeout
is there anybody out there ?
problem is the same : micro mod still not working. found people who inside linux, but not inside music . found people who inside music but not in linux.
the problem: nomad 3.02 runniing, no changes to make how it called on the website where i've loaded down. ok. (past version which will also send miditimeout)
so now facts are: after running nomad become a midi time out, same as many users before
but nothing found which helps by using ubuntu studio,
maudio 4x4 maudio delta 1010lt, amd 64, no midi connection, is it an java fault ?
want to make music
untill now i want to make it on an linux sys,
so die hoffnung stirbt zuletzt
greetings sam
consam
PostPosted: Thu Apr 24, 2008 1:42 am    Post subject:
Subject description: for whome are interested
high,
the circumstances for today are: nomad running on ubuntu studio amd64.
(and i thought it makes only a sense running US the realtime kernel, not i386, don't know if it's possible)l
yes you can get connection to a micro modular via midisport. but it's more a
roulette if it works or not, conclusion for today is: if you wanna work with your micro editor better do it not on an amd 64 linux sys. why that? when im well informed (for other knowledge i will be very thankfull) there is an java program called tritonus found on (http://www.tritonus.org/plugins.html)
which will implement your alsa sounddevices midi and audio whithin java applications. but it only works on i 386 systhems. so what to do is write an java app. for amd 64bit ! for god sake i'm not the right one for this ! so if there are other possibilities please mail. read ya
consam
julien
PostPosted: Thu Apr 24, 2008 2:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello,
Which version of java do you use ?
Under ubuntu should use the sun version of java:
Try running that command in a terminal:
Code:
 sudo apt-get install sun-java6-jre
It will install the sun jdk.
Then run:
Code:
 sudo update-alternatives --config java
And select the jdk having something like sun-java-6 in its name.
Tell me if it helps,
Julien
consam
PostPosted: Thu Apr 24, 2008 6:51 am    Post subject: Reply with quote  Mark this post and the followings unread
high julian,
java version is ok : 1.6.03. or sun java 6 called in synaptic.
And after installing the previous version of nomad and connect over the midisport4x4 not over maudio delta 1010 lt , set midiclock ext in another editor /win 9Cool i got him. and after this nomad 3.02 found the micro too puhh...,
at the moment just have to find out how to save patches in the micro, loaded in nomad (and a lot of other details but for this have to consider help in other forums). first thanxx
sam
julien
PostPosted: Thu Apr 24, 2008 7:44 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm glad it works Smile
