logic environment
Page 1 of 1 [10 Posts]
nuriel77
PostPosted: Tue Apr 29, 2008 3:46 am    Post subject: logic environment
Subject description: where to be found?
hi!
I heard some of u managed to download a logic 7 or 8 environment for a nord modular (G2 i have...)
where can i find this download?
thanks!
Nuriel
Parkol
PostPosted: Thu Jun 12, 2008 12:26 am    Post subject: Reply with quote  Mark this post and the followings unread
I would like to have it too. Smile
https://www.instagram.com/parkol_design/
https://soundcloud.com/parkol
seraph
Editor
Editor
Audio files: 33
PostPosted: Thu Jun 12, 2008 3:09 am    Post subject: Reply with quote  Mark this post and the followings unread
what? the editor is not enough Question
Cool
Audio files: 299
PostPosted: Thu Jun 12, 2008 4:44 am    Post subject: Reply with quote  Mark this post and the followings unread
I moved this to the general NM discussion.
BobTheDog
PostPosted: Thu Jun 12, 2008 5:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Guys,
What exactly do you need in the environment?
Andy
Parkol
PostPosted: Fri Jun 13, 2008 3:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Name of patches and etc... as in Cuabse SX devide map.
There is a device map for Cubase where all patches are named.
For example Cuabse device map is here: http://www.dhoop.de/
Just put Clavia and you will see.
XML file.
There is a very short list of instruments in Logic 8.
BobTheDog
PostPosted: Fri Jun 13, 2008 4:06 am    Post subject: Reply with quote  Mark this post and the followings unread
But the patches will be different for each G2 won't they?
Parkol
PostPosted: Fri Jun 13, 2008 5:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, you are right...
But first 4 banks are similar I think...
Just learning Logic now and still couldn't make Nord sounds, it's flashing, that recieving MIDI but no sound... ughhh.
Logic 8 is more comfortable than Cubase SX 3 and better as I see...
BobTheDog
PostPosted: Fri Jun 13, 2008 6:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Yep Logic 8 is very nice.
I have a Logic 7 Environment with no patch names, but set up for multi-timbrel use of the G2 but it is not needed for version 8.
Andy
BobTheDog
PostPosted: Fri Jun 13, 2008 6:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Also for cubase I did this a while ago:
http://www.electro-music.com/forum/topic-7883.html
There is an app and instructions for getting patch-names out of your G2 and into Cubase.
I will look into how easy it is to change for Logic, but don't hold your breath as I am doing about a thousand other things at the moment.
Andy
