Buying a G2 key :-) question...
Page 1 of 1 [23 Posts]
nuriel77
PostPosted: Mon Apr 14, 2008 7:14 pm    Post subject:  Buying a G2 key :-) question...
Subject description: Should I already get the expansion board?
Hi!
I am so glad, I finally decided to get a G2 key version. I managed to find a second hand one for 1000,- euro, and I am going to check it out later today (see if it works 100%).
I was also offered to buy the expansion board, but didnt know if I should save on the money and wait with it, as i can always get one.
I am currently still using the NM1, so I guess upgrading to the G2 will already be a world of difference for me, so would it be recommended to get the expansion board together with the G2 or wait a little ? (As I would like to save on the money...)
fac
PostPosted: Wed Apr 16, 2008 6:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think you may answer your own question, given your experience with the NM1.
Is your NM1 expanded? If not, have you always wanted the expansion for more polyphony?
Do you plan to keep your NM1 or sell it after getting the G2? If you plan to keep it, you may not need the expansion so badly, otherwise, you can sell the NM1 and buy the expansion.
The advantage of the G2 is that the expansion board not only expands the polyphony, but it also gives you more power for more complex designs because you can transfer audio between slots, and you can also use 100% CPU for the polyphonic section, and another 100% for the monophonic section, thus each slot can actually use 200% CPU. Therefore, if you like to make ultra complex patches, you will probably want the expansion sooner or later.
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Thu Apr 17, 2008 7:56 am    Post subject: Reply with quote  Mark this post and the followings unread
keep in mind that with an expanded G2 you can get more complex patches (% wise) than in an expanded NM1.
Here is what you can do with an expanded G2
Slot A Voice area 100% / FX/Common Area 100%
Slot B Voice area 100% / FX/Common Area 100%
Slot C Voice area 100% / FX/Common Area 100%
Slot D Voice area 100% / FX/Common Area 100%
I don't recall you can do this in a NM1, you get more polyphony
/Dasz
nuriel77
PostPosted: Thu May 15, 2008 10:10 am    Post subject:  well i got it... :-) Reply with quote  Mark this post and the followings unread
yes. you were right, I did need the expansion board sooner rather than later... Smile
I do still have the NM1, but it has to go back to its original owners Sad ...
(I am trying to buy it off him! since i connected the G2 and the NM1 and it will be hard to disconnect them now!)
However I do realize that the G2 whole system kind of gets kind of slow when heavy patches are loaded. Do you also experience this?
Or am I having some problem thus?
Actually there is no crashes or audio not playing (as I used to experience the first days before i expanded the G2).
What I notice is that when a performance is heavely loaded, either the graphics in the editor becomes kind of slow or the text on the lcd screens when switching pages for example. But again, not a major thing as there are no problems with audio at all.
Chrono
Audio files: 37
G2 patch files: 38
PostPosted: Wed May 21, 2008 7:51 am    Post subject: Reply with quote  Mark this post and the followings unread
mine is currently shipping back to clavia, and a new one with expansion will fulfill my needs.
After a couple days i feld its limitation.. in my opinion the only thing missing when it ships back to me is unison and granular fx and math options. (my eyes did see a math section on a picture of the g1 editor tough!?) It's no problem for me to use the modular as sampler fx for the mpc1000.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed May 21, 2008 8:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sneiter wrote:
... (my eyes did see a math section on a picture of the g1 editor tough!?) ...
I don't think so...
Wout
Chrono
Audio files: 37
G2 patch files: 38
PostPosted: Thu May 22, 2008 3:23 am    Post subject: Reply with quote  Mark this post and the followings unread
then what is this (red circle and arrow)? :O
wich modular is suported with that editor? the picturename says G2 as i googled it, Source = Harmony Central.
 Filesize:  342.75 KB
 Viewed:  253 Time(s)
egw
G2 patch files: 8
PostPosted: Thu May 22, 2008 4:40 am    Post subject: Reply with quote  Mark this post and the followings unread
I think that picture was just an early peek at the user inteface for the G2 under development.
If you download the current editor, you will find that it is different - no "math" category, the modules are different, etc.
But many basic math functions can be done other ways.
www.gregwaltzer.com
Audio files: 227
PostPosted: Thu May 22, 2008 5:41 am    Post subject: Re: well i got it... :-) Reply with quote  Mark this post and the followings unread
With large patches there is no slow down. If the patch gets too big it won't work at all. It's an all or nothing type thing.
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Thu May 22, 2008 7:39 am    Post subject: Reply with quote  Mark this post and the followings unread
I remember that screen shot and how much excitement is brought.
we don't have a synth tab either. or the quad modules or ...
/Dasz
ark
G2 patch files: 31
PostPosted: Thu May 22, 2008 7:56 am    Post subject: Reply with quote  Mark this post and the followings unread
We can hope -- look at the real level meters in the FX area, and the small user-interface improvements in the oscillators (for example, the narrow lines surrounding groups of controls that belong together), and the SyncOsc module, and DodeShift, whatever that is, etc.
Chrono
Audio files: 37
G2 patch files: 38
PostPosted: Thu May 22, 2008 11:11 am    Post subject: Reply with quote  Mark this post and the followings unread
That diode thing looks like the rectifier if im not wrong.. that bode device looks cool , and do i notice that there is a different reverb? at least the module looks different.
dasz how long ago did you see that screenshot?
if thats a long time ago did they decrease the options?
i know you can do some math other ways thats great, but now im very curious whats at the synth tab, and the other tabs..
i do think some other interface stuff looks more old. And at the top bar the 1.4 editor says Nord Modular G2 Editor, and this one only says Nord Modular Editor
and! i cant see slot A, B , C, D.
PostPosted: Thu May 22, 2008 1:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
The screenshot is of a very early G2 proto (it's from before 2003-07-16), the features were changed quite a lot indeed.
The bode shifter is just the frequency shifter (which is a Bode frequency shifter still) but the sine/cosine outputs were removed although the first public versions still had that ... too bad really.
PostPosted: Thu May 22, 2008 2:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's what happens when no synth is connected, for each extra synyth (up to four) a new set of ABCD buttons appears.
Some old pics overlaid with a recent beta :
some history.
 Filesize:  576.3 KB
 Viewed:  185 Time(s)
Chrono
Audio files: 37
G2 patch files: 38
PostPosted: Thu May 22, 2008 5:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
as i can see on your screenshots you have some editors wich i dont have :p
are these older editors still availeble for download somewhere? if not can you upload them for me Laughing
I see you too dont like they decreased some in the newer version :p As it was for me i would leave every early stage possibility open, but heck those things might give them to much trouble for further releases.
im no programmer it think thats pretty boring writing that code stuff Very Happy
PostPosted: Thu May 22, 2008 5:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
They have never been, I have screen shots Rolling Eyes
Anyway they are of historic interest only.
As to the changes, well those are Clavia's decisions, it is what it is, there will not be too many exciting new developments, you got to love it as is, or not.
Chrono
Audio files: 37
G2 patch files: 38
PostPosted: Fri May 23, 2008 4:18 am    Post subject: Reply with quote  Mark this post and the followings unread
I see, ill have a good look there!
I do love it as it is. I hope i can realise all my ideas. Otherwise another laptop must run reaktor becides the g2 for more possibilities. The main idea was to get rid of the laptop.
mother misty
G2 patch files: 130
PostPosted: Fri May 23, 2008 10:11 am    Post subject: Re: well i got it... :-) Reply with quote  Mark this post and the followings unread
What kind of version of the OS is installed?
(earlier versions of the OS had that probleem indeed)
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Fri May 23, 2008 10:52 am    Post subject: Reply with quote  Mark this post and the followings unread
I still have some sentiments about not realizing the Polar Pan and Polar Fade... Crying or Very sad
Wout
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Fri May 23, 2008 2:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
me too. BUt is it possible with a zero Hz OSC, phase shifted to reflect the angle, someone did do it.
I think using many polar pans feeding other polar pans would have been trippy. I think these kinds of modules are like drumsynth, FM OP and ENv, they are more specialized.
I think Clavia prioritized the pan out since simpler modules, thus more flexible (in general) must have been higher up there.
Oh well, all this rambling, and no patching ... I gotta get back to v1.40 editor Smile
/Dasz
nuriel77
PostPosted: Fri May 23, 2008 5:50 pm    Post subject: Re: well i got it... :-) Reply with quote  Mark this post and the followings unread
I am using 1.40 with an expanded G2 key version.
I think this happened since I got the expansion.
I am wondering because someone here said it is either work or dont work (when heavy patches for example). I dont seem to have any problems either than that, audio is streaming just fine.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Fri May 23, 2008 10:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yep, sometimes it happens...
Try another computer, because I think it is the combination of USB and computer. I have a computer which won't load Performances. As soon I try it, the Editor crashes away...
On another computer no problem at all.
Wout
nuriel77
PostPosted: Sat May 24, 2008 1:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Wout
Well it seems to do much better. My mac doesnt run the editor software 100% ok, however i use my pc laptop to run the editor and now the software runs smooth.
thanks!
