Joined: Apr 03, 2004 Posts: 24664 Location: The Netherlands, Enschede
Posted: Thu Jul 03, 2008 5:52 pm Post subject:
| richardc64 wrote: | | Simple. |
But ... but ... I mean ... I just wanted antman to not give up on this life yet  _________________ Jan
Dan Lavin
Joined: Nov 09, 2006 Posts: 649 Location: Spring Lake, Mi, USA
Audio files: 21
Posted: Fri Jul 04, 2008 6:13 am Post subject:
| Quote: | | But ... but ... I mean ... I just wanted antman to not give up on this life yet Shocked |
Unfortunately I forgot about a couple things, like finishing up my modular (3 modules left!) and ...........oh yeah!.............The GM Voice Part II! The upgraded, updated version. But don't hold your breath, This will probably be at least a year down the road. |
Posted: Fri Jul 04, 2008 11:34 am Post subject:
| antman49443 wrote: | | Unfortunately I forgot about a couple things |
Good  _________________ Jan
Posted: Sat Jul 05, 2008 8:05 am Post subject:
i tried the new LM7805 regulators on the breadboarded circuit. same effect: the regulator immediately gets hot as does the protecting 22R resistor i use on the positive 12V power rail. the voltage on the +12V rail drops to about 8V.
as soon as i use a stand alone PSU for the 5V everythings going well. i am still puzzled.
where does the heat come from? why does the protecting 22R resistor get hot? could the +/-12V PSU be the cause? i believe not. i tried two different: the power one from my modular and my small switching PSU from my working bench (never have had any problems with both). what would happen if they could not provide enough current?
absolutely clueless.
should i replace the ICs one by one? _________________
Tech Buddy at Random*Source |
Posted: Sat Jul 05, 2008 8:36 am Post subject:
Matthias this is nuts ...
could you draw it as a schematic? _________________ Jan
Posted: Sat Jul 05, 2008 9:41 am Post subject:
jan, thank you so much for taking care. i will surely provide you with a schematic tomorrow.
actually i used thomas circuitry without the PSU. i wanted to derive the 5V from the 12V rail (as done before) by using a LM7805. on the current breadboard i bypass the input with a 100uF to GND and the output with a 100n cap to GND. _________________
Posted: Sat Jul 05, 2008 10:18 am Post subject:
You know of course that those regulators can't all be defective, so there must b e some thinking error somewhere, or an unexpected connection, something like that ... or maybe a HF oscillation involved pulling you a leg. Do you have a scope? _________________ Jan
Posted: Sun Jul 06, 2008 3:54 am Post subject:
hello jan, thank you so much for taking care.
i do have a digital scope. unfortunately my workbench is far from my desktop pc since our move to the new house. i will install the scope software on an old laptop today.
i will draw a schematic of my breadboarded circuit, too.
what i really don't get, and i have no idea about this: with no db50xg installed everything works fine even with the 5V regulators. as soon as i connect one of my three db50xg boards the 7805 regulator and the protecting 22R get hot and the 12V rail drops to about 8V (the circuit actually works at this stage, i can use it for a few minutes before it gets too hot).
OTH with the db50xg installed everything is working fine as long as i use an separate PSU for the 5V.
these observations apply to the PCB i etched and to the circuit on the breadboard as well.
so the circuit is actually working, the db50xg boards and regulators are okay.
so give me just a day or two to draw a sketch of the schematic/setup and to install the scopes software (hope it works on this old pentium II 300 machine). _________________
Posted: Sun Jul 06, 2008 5:29 am Post subject:
this is not my day!?
tried to install the scope on my old laptop using the parallel port. i used the same parameters for base address and interrupt, plug and play and such as on my desktop. i took care not to use an IRQ allready in use. the software does not recognize the scope! as soon as i plug it into my desktop it works! my new toshiba laptop does not have a parallel port anymore!
what is going on here? i shall not have a Gmvoice? i shall not have an oszilloscope at my workbench (but two floors above)?
sigh...
i stop for now and take a walk in the woods. my wife will appreciate it. _________________
Posted: Sun Jul 06, 2008 7:30 am Post subject:
| fonik wrote: | | this is not my day!? [...] i stop for now and take a walk in the woods. my wife will appreciate it. |
It might just be a day for doing different things  _________________ Jan
Posted: Thu Jul 10, 2008 8:19 am Post subject:
hello jan,
still no oscilloscope working, but here are the two schematics.
1st the schematic as i breadboarded the GMvoice.
2nd the schematic according to the board i etched.
since it is actually working it has something to do with the PSU, i think. again, the 22R protecting resistor R100 and the regulator are getting really hot. i have to shut the circuit down in order to prevent them from smoking...
any ideas?
i hopefully i will build a wallwart based PSU (ray wilsons design) soon and try that one.
Posted: Thu Jul 10, 2008 2:00 pm Post subject:
From one of your earlier posts :
| Quote: | as soon as i replace the laboratory PSU by a LM7805 regulator, the voltage on the positive rail (12 or 15V) drops by approx. 20% and the LM7805 gets hot.
the power consumption is about 120mA on the 5V rail and about 270mA on the 12V rail, which seems reasonable to me. |
When that's still correct and when looking at the bottom schematic there is 390 mA running through the 22R, when I interpret the measurements correctly that is ... anyway .. if so that means you're loosing 8.6 V over R100, and it has to dissipate about 4 Watt - that means HOT HOT HOT ... also it means that the 12V will drop probably, you said you started at 15V so that would leave about 5V before the 12V regulator.
Otoh, when I interpret things wrong, it would still mean 270 mA over 22 R -> 5V over R100 -> leaving 10 V before the 12V regulator and a dissipation in R100 of about 1.25W it would get HOT.
So I'd say .. just remove the 22R resistors  _________________ Jan
Posted: Fri Jul 11, 2008 4:01 am Post subject:
removed the 22R and got rid of the voltage drop! great. again you saved my day, jan.
simply maths. unfortunately this is exactly what i am missing
however i am now in need for a appropriate heatsink.
P = V * A, am i right?
how do i calculate the Watt dissipating at LM7805 when sucking 150mA from 15V? Watt = (15V-5V) * 0.150A = 1.5W ?
this question may be silly, but i don't know much about these things. the maths of electronics is still a kind of holy grail for me... _________________
Posted: Fri Jul 11, 2008 4:24 am Post subject:
Good, glad it works now
And your calculations are correct. _________________ Jan
RF
Audio files: 28
Posted: Fri Jul 11, 2008 4:38 am Post subject:
Good call, Jan  |
Posted: Fri Jul 11, 2008 8:39 am Post subject:
thank you very much, jan.
i had never thought a 22R resistor could cause such problems. i will have to learn more about the maths and general rules and definitions. that's clear to me but i still fear it... _________________
expanoncolin
Posted: Mon Jul 14, 2008 5:53 pm Post subject:
Hey folks, I swear I had an account here but maybe it disappeared. Anyways - I really want to build one of these, and am having a bit of trouble finding an appropriate daughter board. Aside from this:
link
I haven't been able to find any daughter boards, or even a sound card with one attached. Based on the descriptions from the wiki article:
http://en.wikipedia.org/wiki/Sound_blaster
I tried to narrow down the sound cards I'm searching for, just to the ones with the wave blaster connector:
link
Still nothing though (I looked at all the pictures for daughter boards and didn't see one). Any other tips? Ideally I'd like to get a couple because I want to try to mess with them a bit to get some stranger sounds, and may fry it. I know that I might be missing some with the quotes, but I wanted to do a description search in case they just called it a sound blaster in the title. Any tips? Is there a list somewhere of which sound card model #'s have the connector? Anywhere I can buy the daughter boards online for a fixed price (hopefully less than $40 ea shipped)?
-Colin Last edited by expanoncolin on Mon Jul 14, 2008 5:57 pm; edited 1 time in total |
Posted: Mon Jul 14, 2008 7:07 pm Post subject:
| expanoncolin wrote: | | Hey folks, I swear I had an account here but maybe it disappeared. |
hmm, back of course ... and I hope I didn't do anything wrong ... do you remember the user name? _________________ Jan
expanoncolin
Posted: Mon Jul 14, 2008 7:17 pm Post subject:
| Blue Hell wrote: | | expanoncolin wrote: | | Hey folks, I swear I had an account here but maybe it disappeared. |
hmm, back of course ... and I hope I didn't do anything wrong ... do you remember the user name? |
You know I looked through my emails and only have one confirmation email (from today), so I probably just had a lot oftimes where I was about to register, when reading this thread or that (longtime lurker). My username probably would have been expanoncolin, had I signed up before.
-Colin |
Posted: Mon Jul 14, 2008 7:27 pm Post subject:
| expanoncolin wrote: | | My username probably would have been expanoncolin, had I signed up before. |
I did a search on parts of your name, parts of your email address and the IP you are currently using - I could find no signs of me deleting or banning anything like it ... so probably there was nothing but I've been a bit on an anti spam mission the last couple of days and did ban an awful lot and it's easy to make a mistake there. Well, I'm glad you landed here anyway. _________________ Jan
expanoncolin
Posted: Mon Jul 14, 2008 7:33 pm Post subject:
| Blue Hell wrote: | | expanoncolin wrote: | | My username probably would have been expanoncolin, had I signed up before. |
I did a search on parts of your name, parts of your email address and the IP you are currently using - I could find no signs of me deleting or banning anything like it ... so probably there was nothing but I've been a bit on an anti spam mission the last couple of days and did ban an awful lot and it's easy to make a mistake there. Well, I'm glad you landed here anyway. |
Yes indeed, me too - I didn't mean to imply that something bad had happened, like I said it was probably just due to absent mindedness on my part...
-Colin |
Dan Lavin
Audio files: 21
Posted: Mon Jul 14, 2008 7:55 pm Post subject:
Colin:
There's a guy in Shagnhai selling Yamaha db50XG daughterboards for US$25 each + US$15 for postage to the USA. I'm assuming you are in Columbus Ohio and not a Columbus in Latin America. HIs name is double-fish1981 for something simliar. Do an ebay search for db50XG under sound cards and he should pop up. A number of folks in the USA and Europe have gotten cards from him, so he seems dependable. |
expanoncolin
Posted: Mon Jul 14, 2008 7:57 pm Post subject:
| antman49443 wrote: | Colin:
I posted that link! It's the first link I posted. That's too much $$ if fI want to get a couple of them. I'd much rather find one from a scrap board for cheaper. Any tips? Thanks for your help.
-Colin |
expanoncolin
expanoncolin
Posted: Wed Jul 16, 2008 11:22 am Post subject:
Well, I still haven't found any cards with daughterboards at all. If the only daughterboard you can buy is $40, then this isn't really a good deal, since lots of MIDI modules are just a little more than that (and also include sequencers, often keyboards, etc). Still a very cool project and if I ever come across a soundboard with a daughterboard I am definitely putting one together.
-Colin |
