Coriolis
Joined: Apr 11, 2005 Posts: 616 Location: Stilling, Denmark
okvern
Joined: Feb 05, 2008 Posts: 78 Location: Seattle, Washington
Coriolis
Posted: Fri Jul 25, 2008 2:10 pm Post subject:
Just beautiful!
Well, at least you have had the opportunity to play with a Buchla - I don't even think are any in my country...
C _________________ Some Rubber Stamp Sound Effects - and other sound effects |
mono-poly
Joined: Jul 07, 2004 Posts: 937 Location: Rotterdam, Netherlands
Posted: Sat Jul 26, 2008 2:27 am Post subject:
European countrys with old Buchla are:
- Sweden
- Belgium
- Netherllands
As far as i know. |
ericcoleridge
Posted: Sat Jul 26, 2008 2:38 am Post subject:
Check this out; Posted on matrixsynth: this guy is building synth modules with cut cardboard enclosures, and most interesting, control surfaces from "special conductive paint"!
This is the control surface I've been looking for; I'm imagining a plastic Shaeffer panel, with key sized etchings that could be filled in with this silver conductive paint. This would be so freakin cool!
http://noisedesign.blogspot.com/
http://www.youtube.com/watch?v=kYAyX5DWkdo
http://youtube.com/watch?v=9wU7DUODM5Q
Description: |
Filesize: |
18.78 KB |
Viewed: |
25688 Time(s) |
Description: |
Filesize: |
16.64 KB |
Viewed: |
25688 Time(s) |
Posted: Mon Jul 28, 2008 9:28 am Post subject:
actually off topic, but:
what about using analog switch ICs (like the MAX323). the switch is on whenever logic in is at 0V. so couldn't i just selt the logic low by grounding it's input with my finger?
these switches could then control a diode matrix which has to be scanned...
such a keyboard would not provide any touch sensivity but it would be still nice for playing glissandos. _________________
Tech Buddy at Random*Source |
ericcoleridge
Posted: Mon Jul 28, 2008 11:29 am Post subject:
fonik wrote: | actually off topic, but:
such a keyboard would not provide any touch sensivity but it would be still nice for playing glissandos. |
Don't you like the Synapse circuit? Or is it not suited for what you want? |
Posted: Mon Jul 28, 2008 11:54 am Post subject:
ericcoleridge wrote: | Don't you like the Synapse circuit? Or is it not suited for what you want? |
you are right. i should try the synapse circuit. OTH thiese would require a lot of parts. that alone would not be that bad, but i have a lot of other projects still going on. so i thought the CMOS diode matrix scanner circuit would be easy and fast to build...?
i don't know. it was just an idea. when i have finished the most urgent open projects (vocal filter and PSU/MIDI for the klee2) i will probably give the synapse circuit a go... _________________
widdly
Posted: Mon Jul 28, 2008 6:58 pm Post subject:
If you don't need the pressure output, Mr Clack published a very simple touch switch here... http://electro-music.com/forum/topic-24011.html
I haven't tried it but it does look very simple. Last edited by widdly on Thu Aug 05, 2010 10:10 pm; edited 1 time in total |
CJ Miller
Posted: Wed Jul 30, 2008 6:33 am Post subject:
I just got home from work a couple of hours ago, and am busy at building my 12-pad Synapse-style Serge keyboard. It is getting close to being done! Can't find those 430pF timing caps I bought a few weeks ago... Soon though, maybe I can have it all connected, cleaned, and dryed by the weekend so I can test it out. I am sure it'll be fun.
I do also want to check out the more complex Serge keyboard and the Buchlas in more detail later. Maybe once I finally make a few of my own PCBs. Even laying out a Buchla keyboard on (a very large piece of!) perfboard doesn't look to hard if one thinks strategy ahead of time. There are a lot of possibilities here to explore.
I'll get a little more done now before I've got to get to sleep |
Posted: Wed Jul 30, 2008 6:52 am Post subject:
i am curious how important the shape of the keypads amy be? do you plan to test several shapes then? _________________
CJ Miller
Posted: Wed Jul 30, 2008 7:49 am Post subject:
fonik wrote: | i am curious how important the shape of the keypads amy be? do you plan to test several shapes then? |
Still awake!
The shape supposedly isn't too crucial. I doubt if many have been tried though, I have seen only circles, ovals, squares, and rectangles of various sorts. Photos of Serge pads seem to indicate that they are only circular pads which are separate from a large ground plane. So there's a small solder pad which comes off of the touch plate for affixing a wire behind it, and a single ground connection for the rest of it.
The Buchla keyboards appear to use several rectilinear patterns. I have seen keys which are nested "U" shaped figures, perhaps alternating signal and ground. As I recall now, pictures of the Music Easel had shown touch plates in the shape of miniature piano-like keys. Here are some pics.
I like how Buchla expanded the idea with more touch button surfaces and psuedo ribbon controllers. I don't know anything about RF electronics but it appears that there is a lot we can try here.
Description: |
Filesize: |
38.15 KB |
Viewed: |
382 Time(s) |
Description: |
Filesize: |
46.81 KB |
Viewed: |
366 Time(s) |
Description: |
Filesize: |
46.14 KB |
Viewed: |
388 Time(s) |
ericcoleridge
Posted: Wed Jul 30, 2008 7:52 am Post subject:
Blue Hell posted a link to this open source, capacitance-touch sensing application, microchip mTouch sensing solutions
Although much of what is there is beyond my understanding, there's a document there called Layout and Physical Design Guidelines for Capacitive Sensing, that describes design issues like pad size and spacing. |
Coriolis
Posted: Wed Jul 30, 2008 12:39 pm Post subject:
CJ - it's very exciting that you are trying out the Synapse circuits, do keep us posted...
dar303
Posted: Sun Aug 03, 2008 12:04 pm Post subject:
I would recommend the Serge TKB circuit for anyone that wants to build a complex touchcontroller with good feel and easy interfacing to sequencers or other logic circuits. Is should be available somewhere on the net, I found it over 10 years ago!
It is constructed of quite common CMOS chips with only one TTL chip (74150 if I remember correctly) that needs to be the exact type used in the schematic to get the touch sense to work.
The Buchla 221 is a beast, I actually have one in my pile of stuff to fix but it is a very big and scary project!
I managed to repair another one about a year ago but it was hard. The schematic (wich I cannot share, sorry!) is hand drawn by Don across several pages. It has very complex logic due to the fact that is was meant to be a programming interface for the 300 system.
It has several fun features like generating a control voltage from a lamp and a photocell when the front panel flexes from you finger pressure, four preset voltages with pots activated when you touch the pads to the upper right.
The
PCB touch plates looks tin plated and are protected with a layer of laquer and are separated by thin strips of aluminium that sits in pockets in the pcb. |
Posted: Sun Aug 03, 2008 11:53 pm Post subject:
CJ Miller wrote: | I just got home from work a couple of hours ago, and am busy at building my 12-pad Synapse-style Serge keyboard. It is getting close to being done! |
how did you connect the trigger out of the keyboard to the programmers input?
the programmer article states that "...the pushbutton may be replaced by hardwiring their lead connections to the pulse outputs of the Touch Sensitive Keyboard...".
would that mean to connect the trigger of the TSK to both sides of the diode of the programmer instead of a switch??? i don't get it.
the 470pF cap, the diode and the 47k resistor of the external pulse in can be omitted then, right?
why not just leave off the whole pushbutton circuitry of the programmer (including common pulse) and summing the triggers with diodes? the keyboard trigger could get connected to the external trigger in, then. _________________
Coriolis
Posted: Mon Aug 04, 2008 1:53 am Post subject:
Quote: | I would recommend the Serge TKB circuit for anyone that wants to build a complex touchcontroller with good feel |
I have those schems you are referring to.
The Synapse article (touch switch) hints at the production TKB having piezo-elements instead of capacitive plates - so are those actually piezos in that schem?
I'm not sure I should post the schem for reference...
dar303
Posted: Mon Aug 04, 2008 3:39 am Post subject:
There are no piezos in there, the scanning is built around a TTL multiplexer. |
CJ Miller
Posted: Mon Aug 04, 2008 5:22 am Post subject:
fonik wrote: | how did you connect the trigger out of the keyboard to the programmers input?
why not just leave off the whole pushbutton circuitry of the programmer (including common pulse) and summing the triggers with diodes? the keyboard trigger could get connected to the external trigger in, then. |
I haven't made a programmer yet. I have been thinking about making one for my portable system, but haven't decided how many rows or columns yet.
The Synapse keyboard has no piezo elements, it is purely capacitative. Without the programmer, it is nothing more than a generalized touch interface. A way to get triggers, gates, and voltages from a simple touch controller. Like any module, I can wire it into a programmer, step sequencer, or indeed anything else. As for replacing programmer pushbuttons, one could easily just connect a transistor, CMOS, or analog switch.
I don't really have any grand scheme for how to use this, my system is very basic at this stage. It's just a project that I have always wanted to play with. Years ago I did make a monophonic keyboard circuit, but the only keynoard I had was of poor quality, so the contacts always bent out of shape. What I have really wanted is a polyphonic keyboard that was tunable, and could output a voltage directly, based on some expressive gesture. This keyboard qualifies as such. The Buchla concepts are a bit more sophisticated, as they can also offer a regular voltage step per key, not unlike a bus keyboard, while still offering these other features.
Of my three day weekend, I spent about 60% of it sleeping, which is unusual for me. The insomnia caught up. So I am awake now for another 10 hours before I am due at work, and will try to get a few things done. |
buchlajoe
mono-poly
Posted: Tue Aug 05, 2008 2:21 am Post subject:
I love to use it with my system  |
CJ Miller
Posted: Tue Aug 05, 2008 3:10 am Post subject:
buchlajoe wrote: | hi.
i have this and i dont use it with my system .... i would be happy to photograph any part of it for you to help out with your project.
this is the 216 keyboard made for the CBS performance system. |
Wow, it's beautiful! And in great condition. Of course, any more photos would be more tham welcome! |
buchlajoe
scriptstyle
Posted: Thu Mar 05, 2009 10:21 pm Post subject:
I am currently in the middle breadboarding the touch responsive keyboard from the synapse article. What transistors did you guys use? im thinking i can just use 2n3904's? |
andrewF
Posted: Fri Mar 06, 2009 8:27 am Post subject:
should be fine
I tried it with C1815 which is about as general purpose as it gets |
