see a message indicating we are on the new server.
Chord memory
Page 1 of 1 [6 Posts]
ark
G2 patch files: 31
PostPosted: Mon Jul 07, 2008 8:24 am    Post subject: Chord memory
Subject description: Play a chord with one finger
To use: While playing a chord, press and release the "learn switch" (button 1). After that, playing a single note will replay your chord rooted in that note.
Possible future variations: Add arpeggiation, quantize the chord into a given scale, send output to another Slot.
Chord memory.pch2
 Filename:  Chord memory.pch2
 Filesize:  1.46 KB
 Downloaded:  2193 Time(s)
Tim Kleinert
G2 patch files: 236
PostPosted: Tue Jul 22, 2008 1:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh, I missed out on this one, this is super! Smile
Am I mistaken, or couldn't you substitute a single Mix2-1B (with the inverter buttons) module for the inverting LevConv and Mix1-1A module? Also, an inverting LevConv module for the dual logic inverter? That would save two module outputs, making the circuit more mem%-efficient. Just a suggestion. I find patch economy an important factor for building blocks.
Anyway, thanks. This is a great solution. It's giving me some good ideas.
ark
G2 patch files: 31
PostPosted: Tue Jul 29, 2008 8:38 am    Post subject: Reply with quote  Mark this post and the followings unread
The Mix2-1B substitution is a good idea; revised patch attached.
I'm not quite sure what you have in mind for the inverting LevConv. Is that cheaper than using a logic inverter? The latter is surely a clearer expression of what I intend.
What I really want is a logic signal that is false while a button is being pressed. I don't think I can fake it by inverting the gates, for example, because I need that signal for the sample-and-hold.
Chord memory.pch2
 Filesize:  1.42 KB
 Downloaded:  2096 Time(s)
Neon Sega
PostPosted: Wed Oct 22, 2008 4:28 am    Post subject: Reply with quote  Mark this post and the followings unread
hTis solution is very useful, great^ Thanx for sharing
iPassenger
G2 patch files: 78
PostPosted: Wed Oct 22, 2008 5:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Keep forgetting to try this out, could be very useful to me.
iP (Ross)
iPassenger
G2 patch files: 78
PostPosted: Thu Oct 23, 2008 12:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice one.. i don't quite get it yet but it works really well.
iP (Ross)
