 Forum index » Clavia Nord Modular » G2 Patches - Completed » Synth
UNISON SYNTH
Page 1 of 1 [20 Posts]
Chrono
Audio files: 37
G2 patch files: 38
PostPosted: Sun Aug 17, 2008 9:20 am    Post subject:  UNISON SYNTH Reply with quote  Mark this post and the followings unread
Finally i found out how to use the voices in unison mode.
Raise voices for more unison power!
this patch is set up with 8 variations for 10 voices.
i've updated this attachment
Unison Synth V2 is a couple posts below (32 voices with expanded g2)
Unison Synth.pch2
Unison Synth with pan spread
 Filename:  Unison Synth.pch2
 Filesize:  3.61 KB
 Downloaded:  2324 Time(s)
iPassenger
G2 patch files: 78
PostPosted: Mon Aug 18, 2008 12:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice patch but it didn't work properly when you hold one key and then play another and then release that second key.. the pitch should slide back down/up to the first note.. instead yr patch was holding that second note.
By moving the mono note module to the fx area and routing the control signal to the VA it works as it should. I also tweaked a couple of routings.
unison_syn_mod.pch2
 Filename:  unison_syn_mod.pch2
 Filesize:  3.46 KB
 Downloaded:  2339 Time(s)
iP (Ross)
Chrono
Audio files: 37
G2 patch files: 38
PostPosted: Mon Aug 18, 2008 1:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice patch
tnx
You can set the mono module to "Last" i think thats what your aiming for. i used it on "Hi" for special trigerring with the Lopass filter Very Happy
Chrono
Audio files: 37
G2 patch files: 38
PostPosted: Tue Aug 19, 2008 5:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Does anyone know how to make a polyfonic Unison patch with the "Poly Keyboard and Voice no." output?
PostPosted: Tue Aug 19, 2008 5:54 am    Post subject: Reply with quote  Mark this post and the followings unread
There are some patches I think ... right ...
http://electro-music.com/forum/viewtopic.php?highlight=polyphonic+unison&t=15359
and
http://electro-music.com/forum/viewtopic.php?highlight=polyphonic+unison&t=6389
Chrono
Audio files: 37
G2 patch files: 38
PostPosted: Tue Aug 19, 2008 6:36 am    Post subject: Reply with quote  Mark this post and the followings unread
i've listened to both, and these both are not real unison like a access virus, nord, ms20, microkorg etc handles unison. I really believe my patch does handles unison as it should. So the more voices you set in a particular slot on your nord the more (in this case)saw's your slot sends through the VA section. the OSC KBD tracking is off and the pitch is controlled with the mono keyboard note module. The detune is the voice no out to the osc pitch input.
But then i once read somewhere that it theoreticly wasnt possible to do polyfonic unison on old analog hardware. So in this case becouse the g2 represents a modular system to make analog emu's that this might also be the case with the g2?
i love the g2ian's patch though but isnt that more like "Chrous" "Ensemble" ?
i think unison should use a lot of voices. thats where it's for and especially for my hardcore leads its a must. the 22 voice unison sawlead(Screach) sounds are great with my unison synth patch and are better than my Access Virus A wich only has 12 max voices. The only thing is that my virus A allows me to play 2 polyfonic notes with 6 unison voices.
I hope we can figure that out on the g2.
i did some more testing and you are right i diddnt notice that yesterday! thanks for the fix Smile
iPassenger
G2 patch files: 78
PostPosted: Tue Aug 19, 2008 6:51 am    Post subject: Reply with quote  Mark this post and the followings unread
no worries.
I think you could achieve yr 2 note poly unison, if you used one slot to accept midi information (say slot A), set to two note poly and use the voice number to split the send of the control data between two internal busses, one to a slot (say B) for the first voice and one to a slot (say C) for the second. Then these slots (B + C) could be monophonic unison as in the original patch (e.g. set to say 6 note poly) but as you would have two independant versions they would give u 2 note poly.. Problem would be controlling both units in terms of the patch settings etc... as everything would need duplicating. + you would pretty much need to make this a performance rather than a series of patches.
iP (Ross)
iPassenger
G2 patch files: 78
PostPosted: Tue Aug 19, 2008 7:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Actually you can probably do it with two Slots.
If you send the voice 1/2 information from Slot A through the busses too it may well be possible to keep the unison synth (say in Slot B) in one slot but still have two voice poly. Though i am just thinking this out at work so no real idea if i am right here.
iP (Ross)
Chrono
Audio files: 37
G2 patch files: 38
PostPosted: Tue Aug 19, 2008 7:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Sounds interessesting, i'm not really sure how you would patch that but that might seem like a usefull idea!
Chrono
Audio files: 37
G2 patch files: 38
PostPosted: Tue Aug 19, 2008 12:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here is a fixed version for the Unison Synth
fixed:
volume settings
removed pre envelope
applied i passengers method
removed pan spread
About the pan spread, does anyone have an idea to get a good working nice Unison Pan Spread with this patch?
Unison Synth.pch2
Fix1 Unison Synth
 Filesize:  3.29 KB
 Downloaded:  2210 Time(s)
Chrono
Audio files: 37
G2 patch files: 38
PostPosted: Sun Aug 24, 2008 7:10 am    Post subject: Reply with quote  Mark this post and the followings unread
With some great help from iPassenger i fixed a good working pan spread.
Unison Synth.pch2
added: Pan Spread
 Filesize:  3.61 KB
 Downloaded:  2075 Time(s)
iPassenger
G2 patch files: 78
PostPosted: Tue Aug 26, 2008 10:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Sounds pretty good, glad i could help.
iP (Ross)
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Tue Aug 26, 2008 2:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great sounding patch.
If you patch in a noteQuantizer as shown, you can knock the VA DSP% back to 22.5% which means you get more voices in the stack (29 on expanded G2).
It works by 'downsampling' the output of the 2 in module to control rate signal, letting the modules connected after optimise themselves.
 Filesize:  26.09 KB
 Viewed:  51875 Time(s)
iPassenger
G2 patch files: 78
PostPosted: Tue Aug 26, 2008 2:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Brilliant! Smile I never knew that.
iP (Ross)
Chrono
Audio files: 37
G2 patch files: 38
PostPosted: Tue Aug 26, 2008 3:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
about the quanitzer indeed very nice to know!!! Very Happy
here you go 32 voices! with Expanded G2
Unison Synth V2!
PAGE A1 OSCILATORS
OSC A> Wave | Semi | Fine | Shape | On / Off | Volume | (Main Pitch) Semi | Fine
PAGE A2
OSC B> Wave | Semi | Fine | On/ Off | Volume
PAGE A3
OSC C> Semi | Fine | On / Off | Volume
PAGE B1 LOW FREQUENCY OSCILATORS
LFO A> Wave | Rate | Shape | Phase | KBT | Range | OutType | Mode
PAGE B2
LFO B> Wave | Rate | KBT | Range | Mode | OutType
PAGE B3 (SEND TO)
PITCH> LFO A | LFO B | Filter1> LFO A | LFO B | Filter2> LFO A | LFO B | Stereo L | Stereo R
PAGE C1 VOLUME ENVELOPE
Volume> Attack | Decay | Sustain | Release | Shape | OutType | Reset | Synth Volume
PAGE C2 PITCH ENVELOPE
PITCH ENV> Attack | Decay | Type | Shape | OutType | Reset | Trigged | Pitch Amt
PAGE C3 FILTER ENVELOPE
FILTER ENVELOPE1> Attack | Decay | Sustain | Release | Shape | OutType | Reset | Filter Amt
PAGE D1 FILTER
Flt1L> Type | Flt1R Type | Flt1L> Db/Oct | Flt1R> Db/Oct | Flt1L> KBD | Flt1R> KBD | Flt2L> Type | Flt2R> Type
PAGE D2
Flt1L> GComp | Flt1R> GComp | Filter1> Vel Gain | Flt1L> Cutoff | Filt1R> Cutoff | Flt1L> Reso | Flt1R> Reso
PAGE D3 MAIN FILTER CONTROL & FILTER ENVELOPE 2
Cutoff | Reso | Cutoff 2 | Reso 2 | PAR / SER | Filter Envelope 2> Env Amt | Attack | Decay
PAGE E1 FX & UNISON CONTROL
Pitch> Noise | Glide | FX> Dist Dry/Wet | Type L | Type R | Unison> Detune | Pan Spread
PAGE E2
Delay> Time L | Time R | Time MD L | Time MD R | Filter L | Filter R | Dry/Wet L | Dry/Wet R
PAGE E3
EQ L Low | EQ L High | EQ R Low | EQ R High | Filter1L On/Off | Filter1R On/Off | Filter 2L On/Off | Filter 2R On/Off
routing scheme
3 OSC > 2 LFO > 3 Envelopes > 2x Stereo FILTER > Distortion > EQ > Delay > Compressor
1 Audio Demo for the demo users and curious ones about my awefull playing skills Twisted Evil
v2 synth finished after a long day work!
comments are really appreciated!!
Unison Synth v2.pch2
Unison Synth V2! [32 Voices with Expanded G2]
 Filename:  Unison Synth v2.pch2
 Filesize:  6.14 KB
 Downloaded:  2187 Time(s)
Nord Modular G2 Unison Synth V2.mp3
29 voice version audio demo!
 Filename:  Nord Modular G2 Unison Synth V2.mp3
 Filesize:  1.94 MB
 Downloaded:  1369 Time(s)
PostPosted: Tue Aug 26, 2008 4:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sneiterheadz wrote:
somehow the attachment did not upload...
You ran out of disc quota, please try again, I gave you some headroom.
Chrono
Audio files: 37
G2 patch files: 38
PostPosted: Tue Aug 26, 2008 4:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks!! still beeing up so late? Laughing
well in the meanwhile i've edited my last post 10 times :p the 32 voice version is up and running! enjoy...
(now the virus owners can be a little jalous) Cool Twisted Evil
dorremifasol
G2 patch files: 49
PostPosted: Mon Sep 01, 2008 2:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great patch! Smile thanks
Albert
G2egory
PostPosted: Mon Sep 01, 2008 3:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for sharing your great patch! Successfully programing 32 voices into a fine sounding patch is a substantial accomplishment. Variation 2 is one if the most exciting in-your-face lead patches I have heard in a while, especially if you play it with keyboard hold activated to drive the bass past. You stick that variation in the bridge of a song and folks are going to quickly realize you ain't playing no electric piano.
Gregory
Chrono
Audio files: 37
G2 patch files: 38
PostPosted: Tue Sep 02, 2008 3:02 am    Post subject:   Reply with quote  Mark this post and the followings unread
Thanks guys,
glad you like it happy smoker
