moog modular vcf?
Page 3 of 5 [101 Posts]
numbertalk
PostPosted: Tue Sep 02, 2008 1:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
So, at the risk of sounding like an idiot, for those bass patch sounds like TD, Michael Hoenig, etc have used.....is it not at all possible to even begin to *approximate* *similar* sounds with, say, a Prophet 08, putting all ideas of getting the "pure" sound aside? It seems as though it would be possible to somewhat approximate. I can understand how the wave shapes being different/unique (and drifting) would effect the harmonic content/balance and then the character the filter would add on top of that, not to mention the other modules in the signal path, but again, without a ton of experience, so please forgive me, if it's possible to come close with another analog synth, how would you patch this? I've tried using saw-tri waves on my P08 and have not been able to come close, but I would attribute that more to my own inability. What I come up with either sounds too "buzzy" or at the other end the cutoff freq is set so low it's too muddy and muted. And if not with a P08, with, say, Yusynth's Minimoog VCF clone and a non-901/non-Moog Modular oscillator. Maybe it just honestly isn't possible, but again, I'm coming at this as not a 100% purist and even not wanting to really 100% copy such a recognizable sound, but more to know how to do this, just to learn more about patching, and even as a starting point for maybe a similar sound or something.
yusynth
PostPosted: Tue Sep 02, 2008 1:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
neandrewthal wrote:
Sorry, for the OT, but what is the module with one knob/two jacks and why the heck is it on a double wide panel Confused
You mean the one at the right of 914 Fixed Filter bank in the lower left cabinet ?
If so it's a spring reverb module 905, why is it a 2U panel, well I guess that's what Bob Moog had at hand when he designed the module and then he did not bother to change the panel to a smaller one...
Yves
Peake
PostPosted: Tue Sep 02, 2008 1:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
synthetic wrote:
Peake wrote:
Regarding Synthetic's troll regarding the need to buy something and Juergen's design and my wanting drift
After "Snort- Then why do you still own a Voyager if it is killed by something else? (That's as rhetorical as your statement is silly- I won't be looking for a reply.)" I figured it was safe to come out from under the bridge. The drift comment was meant to be ironical, as I don't think filters actually drift that much, or that the drift would be noticeable. But since the 490 has the wrong vintage caps and Paul was involved then I guess it's crap.
The page you linked calls the 490 "A faithful copy of the 904A to capture the irregularities of the old transistors in the ladder. Sounds great and available now."
Saw a reprint of your post in another and had to laugh. It's still NOT DIY. This is a DIY forum. Even the COTK/MOS-LABs comments and pics are welcome as they provide empetus and concepts to anyone interested in trying to =build= The Filter. Do you have any interest in building The Filter or offering DIY advice to anyone who does? Again, that is rhetorical. Many of your clique just like to be belligerent and lower the signal level in threads like this by parading your own items, when it contributes nothing. Very low class. Even worse, to do so in order to be irritating. If you're not aware that it's irritating, you are now, and have a ready-made path to higher standards of community behaviour.
I once posted a non-DIY commercial module in another thread, but apologetically, to propose certain benefits which might be considered by those interested in the project they'd posted. You are just spamming commercial product in addition to trolling, which is expected, yet still negative, so stop.
One thing that bothers me about the site I linked to (and I knew that you wouldn't be able to resist posting that quote, thanks for doing so), is that he seems to like EVERY one of the filters that he listed. I wonder if the noise in the otherwise brilliant .com version would have caused him pause- It's a deal-breaker to me. I wish Roger would change that. And many 904a "clones" have very different resonance characteristics. They're not the same.
What are you gonna do (that's rhetorical as well).
Peake
PostPosted: Tue Sep 02, 2008 1:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Have you ever used an SEM and a Pro-One together? It's obvious which one is bigger-sounding in general. I imagine that a P08 would fare as well against a pair of 901bs into The Filter.
The P08 is a shiny, clean, clear-sounding synth. It's not very large-sounding, which has the side benefit of likely easily fitting into mixes. I played with one a while back next to a Little Phatty, etc. and the differences were clear. Also, the Moog filter has a purr somewhere in there which isn't evident in others. The Selector filter comes close to the 904a, without using any resonance.
My experience is that most don't care about anything more than approximations. If you heard the difference, you might desire it. I work in sound and synthesis full-time, so these things are extremely important to me. This passion for excellence made me an early adopter of the now-legendary ADAM monitor line; it has me hooked on Moog and Buchla. What I've found might or might not interest others. It all depends upon where you place your passion in life Laughing
synthetic
PostPosted: Tue Sep 02, 2008 3:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
I built my 490 filter. I bought the board, panel and some parts from Synthtech. I went on Mouser and ordered the resistors, caps, diodes, etc. I soldered it together and tested it. I don't see how it's any different from buying a board from someone else on this forum. I think it absolutely counts as DIY.
How is this not DIY?
http://www.wiseguysynth.com/larry/motm/490/490.htm
What's the cutoff for being called DIY? Printing and drilling your own boards and panels? Winding your own transformers? Please, Dr. Peake, let us lowly beginners know so that we will not waste your time again.
Peake
PostPosted: Tue Sep 02, 2008 5:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
I had read long ago that they don't offer kits anymore. Hence, no DIY. Thank you for your attitude and lowering the quality of this thread through attitude and continuous product placement/branding. It certainly does not endear me any further to you, or to the items you are representing. I prefer the positive; you cannot provide it.
Enough of your thread-degenerating attitude. Obviously you and many of your group are -unable- to not waste time and money upon me, so I'll provide the positive example: Let's talk about The Filter instead.
Neh?
urbanscallywag
PostPosted: Tue Sep 02, 2008 6:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
They still sell boards...
Scott Stites
Audio files: 96
PostPosted: Tue Sep 02, 2008 6:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, please, let's do. I think we all know what DIY is, and I think we all know what we like. Personal preference extends to all - one man's drift is another man's poo and by the same token one man's need for accuracy is another man's idea of the devolution of modular synthesis, regardless of life experience. You might as well argue which is the one true deity, it's the same damn thing, as passionate as people can be about their instruments.
This forum, being a DIY forum, means you can have both/either/or without stepping on anyone's toes or hurting anyone's feelings. If you like the filter, build it. If you don't, then don't. Ain't DIY something?
I'm interested in why people think this filter rocks (and I'm certain it does), but derision of those who think it could be better or derision of those who think it should be a perfect clone is a subject best covered somewhere else.
Thanks,
Scott
My Site
Peake
PostPosted: Tue Sep 02, 2008 7:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
There's a subtle growl there, even in the openness. It seems to "cut the mustard" better than say an SSM2044, which seems to be slightly puffy/less "closed" than the Moog (which is why I was asking after thoughts on changing the fourth, odd-value cap in the 2044 in a thread here a while back, due to the extreme availability of the 2044...) The Minimoog oscillators and filter sound more "closed" or "tight" than the Modular, which has more openness, cleanliness and less "spit" than the older Minis. Especially if you bypass the 902 VCA.
I've owned several Moog Modulars over the years and all of the filters sounded different. I don't know if that's from changes in the capacitors over time, or from better/worse matching in the trannies, etc. I've also heard plenty of 904a "clones" and only the .com satisfies, but has that objectionable noise...hence my own desire for the absolute original, which means mylar caps in the ladder. I'm interested in whether this will allow for drift in the Fc, or if most of that was from the early power supplies I'd had in a few of the systems I'd had through my studio... (The one Moog I couldn't wait to get rid of, and wouldn't want back, was a System 35 in excellent shape- had been gone through, calibrated, new pots, mods, etc. Same with a "newer" Mini- boringly stable...)
But as Juergen encouraged the gent who cloned one, whose site I'd linked, to get as close as possible to the original- I've heard clones, and some have different resonance, which just isn't the same. I'm interested in hearing the MOS-LAB with the THAT arrays in it, with their tight matching... The original trannies Moog used aren't expensive at all, but there are many matched pairs in the design, I believe Yves said that there are three THAT ICs in the MOS-LAB clone, just so people are aware of that aspect of the item. It's worth considering if you want to build a clone.
My .02VDC on the matter is that, having had several systems, you'd miss out if you made one and it had zero movement (although the original might even have had too much for my own aesthetic).
An interesting characteristic which deserves research are the two bumps in the noise floor in the bass region. If they produce amplitude bumps at those frequencies, it would be like having a pair of tight EQ bands built-in. Search flickr.com for my 904a test printout, and let me know if the response indicated would be audible.
Peake
PostPosted: Tue Sep 02, 2008 7:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
I was under the impression that this no longer happened, and had been the case for several years. It would have been easy for someone to have simply said so... Please also note my original response "go for it" way back in the thread.
paults
PostPosted: Tue Sep 02, 2008 7:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK folks, time for 'reality' to rain (yet again) on the Peake Parade Smile Grab yer popcorn and hide the children.
a) I also sold my Moog 55, fully restored to *exact, perfect* factory specs by not 1, not 2 but all 3 of the top Moog repair folks in the world. Why? It was TOO NOISY! The same reason I sold my Xpander (the Xpander was so noisy I thought the Noise Generator was bleeding through). The sound was very 'muffled' to me (like a blanket over the speakers sort of sound). I also owned Moog IIIc Serial #006 at one time (sold because the 901s drifted when I *walked* past them and air blew in the jack holes), and a Moog 15 as well. All 3 were sold because try as I could, the "glamour" of the machine was undone by the sound. Heck, I like my Yamaha FS1r better in that department.
And the Moog modular was the reason I switched from a chemistry degree to a EE degree (well 2 EE degrees). In 1972 I was writing Bob a fan letter every 4 months or so, which he answered every one.
b) but while I had it, I did a little R&D. I used the 2 904As in it, I had 5 other people send me their 904As and I ran all 6 of them on my super-whiz-bang Audio Precision Dual Domain tester. And what I found was
#1 - there is a definite non-linearity in the amplitude versus frequency response
#2 - there is a definite non-linearity in the frequency response versus Q
This got me thinking....hmmm...so I then looked the following "off the shelf" Moog Ladder designs:
Modcan
Doepfer
MoogerFooger 101
.COM
And running the SAME tests for these as the 904As, NONE OF THEM had these 2 particular non-linearities. BTW: the MF-101 was not a Bob Moog design, it was designed by a guy in Canada. It uses crappy CA3046 arrays. Ack!) But I digress.
Well, I thought that was interesting. Here are 4 supposedly clones that did not "measure up" so to speak with the original. So I started running PSPICE circuit simulations and I found the reason. And to confirm it, I just picked up the phone and talked to Bob and he verified my suspicions.
I then got with JH and we worked out how to get that same 'dip in the curve'. Sorry Mike, the caps, Mylar or otherwise, have *nothing* to do with why a 904A sounds the way it does. It's a "company secret" (although not that hard to figure out if you know what to look for and understand transistor theory) but it has to do with adjusting impedances with respect to input levels of the audio (think of it as a separate feedback path).
JH & I then designed the MOTM-490, and I build 10 prototypes with different date code parts to get what's called a Monte Carlo Spread of component values. And I used 3 different caps as well. Running the 10 through the AP, it was verified that the MOTM-490 is the *ONLY* available Moog Ladder VCF that accurately depicts the 904As unique sound.
c) the Mini-Moog VCF's sound depends on 3 things that are interactive:
#1 - the loading impedance of the following VCA, which is a differential amplifier with non-linear input impedance.
#2 - the negative supply is very noisy and the VCF has low PSRR (power supply rejection ratio)
#3 - the unique feedback in the 904A is not exactly the same in the Mini
Lessons learned:
a) careful and thoughtful engineering analysis can show why something sounds a specific way, without resorting to 'floobydust' explanations.
b) one can duplicate a certain audio timbre exactly, without duplicating the circuit *exactly*
c) audio gear designed in 1970 will be noiser than audio gear designed in 2008
If people wish to spend countless hours duplicating pc board traces, then the exact parts to get the exact sound, I say good luck with that. But PLEASE do not think that is the ONLY PATH. It is not.
RF
Audio files: 28
PostPosted: Tue Sep 02, 2008 7:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow. salut Something explained.
Thank you.
bruce
JohnLRice
PostPosted: Tue Sep 02, 2008 7:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice info Paul, thanks!
Peake
PostPosted: Tue Sep 02, 2008 8:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm sorry, I can't hear you over my ADAM monitors, you know, the kind Sir Rupert Neve owns? That were used on the Beatles remix? For the Von Karajan box set? You know, the music thing? Wink
Paul, here is reality raining upon a parade: "Not with those oscillators." I hope that you'll get over it someday. I have accepted that you cannot and hope for the best, for you and yours. I'm sorry to E-M that you've made the forum your latest dumping ground. He follows me around, what can I do (make music using synthesizers?)
I'm going to build The Filter using both original transistors and THAT arrays and see what there is to see, and if appropriate, provide observations to the group (of course, no one cares, but I'll have my fun). Or most importantly, make music and have the actual Moog experience, which is both my goal and pleasure. And is sort of the entire point? Laughing Laughing Laughing
No more replies from me to such nonsense. Don't worry moderators, no fight here, this just gets so damn silly that you have to laugh at the lengths they go to in order to defend "Not with those oscillators" and an inability to answer "how do you make a string sound". Wink
I might even post DIY artwork to the forum, if anyone wants 901a/b oscillators. If anyone can stand the absolute and utter horror of an item that is notoriously without precision. Or, you could always purchase a set the vintage market. Unmusical items always go cheap Laughing
Peake
PostPosted: Tue Sep 02, 2008 8:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you.
bruce
I said that in the second post of this thread. Laughing Laughing Laughing
paults
PostPosted: Tue Sep 02, 2008 8:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
#1 reason should have read: frequency response versus amplitude
Meaning: if you set the Fc knob to a value (with resonance at '0') and then do a frequency response plot (ie plot the low-pass response), you will see that with different input amplitudes, the 'flat part' of the frequency response is not flat at all. There is a pronounced 'dip', and the intensity and shape of that dip varies with input signal level.
paults
PostPosted: Tue Sep 02, 2008 8:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Mike:
You only need matched pairs for the 'top pair' (where the output is tapped off) and suggest using the Analog Devices SSM parts over the THAT, because you will get better results. For the other 6 transistors, use BC550 or BC560s because they have 2-3 times the gain and 1/2 the noise of say 2n2222 or 2n3904s.
With regards to a 901:
a) use a polystyrene cap, or at the least do a 'dual footprint' on the pc board for each type (all you need to do is add 1 hole).
b) use RN55E resistors throughout. You can get these cheap enough at Mouser, they will not effect the sound 1 iota
(a) and (b) will NOT eliminate the drift, but it could make the thing useful over more than 2 octaves for more than 5min at a time Smile
paults
PostPosted: Tue Sep 02, 2008 8:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
One more little tidbit:
One of the 'great tricks' of the 904A is to use it *after* a VCA in a patch, not before. The input amplitude of the signal really has a great effect on the sound. Placing it in the 'traditional' spot after a VCO will only feed it a constant amplitude. You can get a bit of timbre shift by messing with the amplitude going in (a mixer in front), but a lot of really interesting tones can be had by using the VCF last.
The only downside is the possibility of more noise, assuming an 'off' VCA is quieter than a VCF sitting there with no input. The MOTM-490 is very quiet Smile
And Mike, I prefer my Mark Levinson 383 amp with the B&W speakers, thanks.
paults
PostPosted: Tue Sep 02, 2008 9:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
After reading all the posts, some final thoughts:
a) the MOTM-490 is not temperature compensated, as to be 'bad' in this regard as the Moog is. As a side comment, MOTM is the only company that does temperature compensate the VCFs, which is another discussion
b) the main reason a 901 has a different sound is the sawtooth is really a sort of distorted triangle, which then makes both the Sine and Triangle 'not perfect'. Pulse is pulse Smile Does this add something? Sure, but not to the extent people think. I will bet that the *output amplitude* of a 901 is different than a 921, and THAT makes the sound out of the 904As different
c) the CA3080 in the 921 is not used in a critical part of the VCO core. It's used as a differential amplifier. The improvements with respect to temperature drift would be
#1 - replace the LM308 op amp in the CV summer with a better part
#2 - replace all the LM741s with TL071s
#3 - use RN55E 0.1% 10ppm resistors in the CV summer
#4 - replace CA3086 with MAT02EH in the exponential converter
This is for a redesign, not to 'drop in' an existing 921. These changes will not alter the sound at all. but it will make it less drifty.
I like less drifty. Robert Rich has toured extensivedly with his 8 MOTM-300 VCOs and 6 MOTM-310s uVCOs and has stated several times that he can tune the system up at home in CA, put it in the back of the van, drive across the US to NYC, set it up on the stand and after a 10min warm up, *never have to touch a single VCO knob*. It's STILL IN TUNE.
d) I am in design of a DVCO (digital VCO) that has a temperature sensor on the board. There is a jumper option to allow ambient temperature 'to drift' the DVCO's pitch.
Scott Stites
Audio files: 96
PostPosted: Tue Sep 02, 2008 10:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's interesting! Are the AD parts spec'ed better or is there some other reason?
My Site
suitandtieguy
PostPosted: Tue Sep 02, 2008 11:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
looks like a saw to me, but i might just be a fat pig in a wheelchair.
the ringing at the top is caused by the A/D conversion and is unavoidable.
sawtooth from a rev 2 Moog 901B.
 Filesize:  87.33 KB
 Viewed:  241 Time(s)
frijitz
Audio files: 54
PostPosted: Wed Sep 03, 2008 2:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Laughing Those bumps look like line frequency hum to me. (60 Hz and 3 X 60 Hz). Rolling Eyes
elhardt
PostPosted: Wed Sep 03, 2008 9:09 am    Post subject: Reply with quote  Mark this post and the followings unread
The B.S. never ends. One of the biggest problems with these forums is that people don't seem to learn anything. We've been down this road several times. The Moog 901 waveforms don't look different than others, as I had Andrew Sanchez record some specifically for me to analyze. I also grabbed one or two that Mike Peake himself posted. I wanted to hear the magic he claims is there, but there was none. There were audio files posted comparing the Moog to the Arturia MMV for drift comparisons, I posted some comparing the Moog to the Technosaurus and a straight digitally generated sawtooth with measurements of cycle to cycle jitter down to the nanosecond range (another goofy theory that didn't pan out, since the Moog had 3 times less than the modern Technosaurus), and there was no magic. And it keeps being pointed out that drift can be patched in, as some of us do often, but they don't want to listen. In nature noise/drift is usually of the 1/f type. Nothing magical about that.
Go ahead and ask Peake or anyone who won't let go of the Moog osc dogma to post audio files where we can actually hear the Moog magic and you will see that they can't do it. It's all talk and nothing physical or aural to back it up.
I still have up online an audio file that switches back and forth between a 901 Moog sawtooth and one generated in Cool Edit Pro (link below). These are on the two opposite ends of the spectrum. They're as far away as I could possibly get, and still there is almost no difference at all. No magical interesting Moog waveforms, or magic power supply noise, or magic jitter here.
http://home.att.net/~elhardt2/Sawtooths.wav
-Elhardt
Peake
PostPosted: Wed Sep 03, 2008 12:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
I know that they are line-related frequencies, but are they actual weaknesses in the design allowing it through to such a degree, or are they bumps in the frequency response? Wish we'd done a spectral scan...and check the type of power supply we used in the test. I do not believe that it has any hum Smile
Plus, if the 904a is so very frail, why would anyone want it, much less offer it for sale?
Ken, I'm so happy that I can put you down for some DIY 901a/bs, using the original parts for original drift and inaccuracy. My first Customer! Swoon! Laughing
Peake
PostPosted: Wed Sep 03, 2008 1:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Need a drift consultant?
