roland jv-1080 and cubase sx
Page 1 of 1 [5 Posts]
ste swindell
PostPosted: Tue Sep 30, 2008 3:21 am    Post subject: roland jv-1080 and cubase sx
Subject description: multiple patches
i have tried everything driving me mad. i have loaded the jv in midi device manager.opened the track selected the patch played the keyboard everything great.when i open another midi track to do another patch both midi tracks play the same patch,i thought i would be able to use this like a vsti different patches on each midi track. can someone give me a step by step answer i know its got something to do with program change messages i have opened the multiple presets folder but when i click on program change a list of program messages appear this is chinese to me.i am no midi marvel still learning.[ help pls)
EdisonRex
Audio files: 172
PostPosted: Wed Oct 01, 2008 1:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
You've hit the blue "Perform" switch in order to get it into multi program mode, right?
Or maybe I'm misreading your problem. I have had a JV-1080 for over 10 years and I've been using it with multiple midi channels and multiple outputs for the entire time. If you don't hit Perform though, it won't work right.
Garret: It's so retro.
ste swindell
PostPosted: Thu Oct 02, 2008 2:19 am    Post subject: reply Reply with quote  Mark this post and the followings unread
so i can load different patches into say midi channel 1 patch 001,midi channel 2 patch 003,and so on.the jv will play all the different patches together. at the moment when i change midi channels with another patch i can only get it to play 1 patch at a time
EdisonRex
Audio files: 172
PostPosted: Fri Oct 03, 2008 12:27 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't understand. I use Digital Performer and the way it works for me is each track is its own midi stream (which in the case of the JV-1080 goes out one particular pipe). Program changes in any particular track work fine, so long as the JV is in performance mode. Maybe you have one of the performance mode parameters set wrong. I'll check mine when I get a chance next and post back.
ste swindell
PostPosted: Fri Oct 03, 2008 4:39 am    Post subject:  thanks Reply with quote  Mark this post and the followings unread
that would be great to see what your parmeters are set at .i am a novice with the jv only had it for a couple of week.i have had another blogg on the roland forum. another reason i was going wrong was i was in patch mode (doh)
