ste swindell
Posted: Tue Sep 30, 2008 3:21 am Post subject:
roland jv-1080 and cubase sx Subject description: multiple patches |
| i have tried everything driving me mad. i have loaded the jv in midi device manager.opened the track selected the patch played the keyboard everything great.when i open another midi track to do another patch both midi tracks play the same patch,i thought i would be able to use this like a vsti different patches on each midi track. can someone give me a step by step answer i know its got something to do with program change messages i have opened the multiple presets folder but when i click on program change a list of program messages appear this is chinese to me.i am no midi marvel still learning.[ help pls) |
EdisonRex
Audio files: 172
Posted: Wed Oct 01, 2008 1:37 pm Post subject:
You've hit the blue "Perform" switch in order to get it into multi program mode, right?
Or maybe I'm misreading your problem. I have had a JV-1080 for over 10 years and I've been using it with multiple midi channels and multiple outputs for the entire time. If you don't hit Perform though, it won't work right. _________________ Garret: It's so retro.
ste swindell
Posted: Thu Oct 02, 2008 2:19 am Post subject:
reply |
| so i can load different patches into say midi channel 1 patch 001,midi channel 2 patch 003,and so on.the jv will play all the different patches together. at the moment when i change midi channels with another patch i can only get it to play 1 patch at a time |
EdisonRex
Audio files: 172
Posted: Fri Oct 03, 2008 12:27 am Post subject:
| Quote: |
I don't understand. I use Digital Performer and the way it works for me is each track is its own midi stream (which in the case of the JV-1080 goes out one particular pipe). Program changes in any particular track work fine, so long as the JV is in performance mode. Maybe you have one of the performance mode parameters set wrong. I'll check mine when I get a chance next and post back. _________________ Garret: It's so retro.
ste swindell
Posted: Fri Oct 03, 2008 4:39 am Post subject:
thanks |
| that would be great to see what your parmeters are set at .i am a novice with the jv only had it for a couple of week.i have had another blogg on the roland forum. another reason i was going wrong was i was in patch mode (doh) |
