The site will be down to cut over to a new server on Tuesday, May 26, at 10 PM EDT (May 27, at 2 AM GMT)
We will be down for about 2 hours. Check back and you see a message in red indicating we are on the new server.
I finally got around to calibrating the klee this morning. Did it twice.
You know, all this "debugging" and/or brain adjustment I've been doing would go a lot smoother if I'd just read the manual. Neither of my previous questions would have come up! Anyway, NOW I've done all the testing, and everything is hunky dory (whatever that means).
I had to calibrate twice because I screwed it up the first time. When I was checking the ranges after the first calibration, I found most of the ranges to be pretty close, but not as close as I thought they'd be considering the accuracy of the voltages I'd set. I realized that I must have screwed up the zero offset calibration, and running through the process in my head, realized I'd done it without setting the first bit active - when you set the zero offset readings that way, you get a nice big .000 no matter where you set the trimmers. BTW Scott, this isn't mentioned in the manual, to make sure that the first bit is active, although I suspect I'm one of the few people that'll get caught by this - I did the check out section last night, and the calibration part this morning - if you do the whole thing in one session it's not an issue.
I couldn't get the third trimmer to .583v - only to .566, which is pretty close anyway, I suspect I can live with it.
Anyway, time to put the knobs on, and then go play!
Audio files: 96
Posted: Tue Aug 12, 2008 10:17 am Post subject:
Nice to hear that it's working! Not sure why your zero adjust wouldn't work without a bit on - the offset trims apply voltage directly to the U8/U9 op amp inverting inputs, and whether a bit is on or not shouldn't affect it (as long as the pot controlling the bit is turned all to zero, if it's on). I guess I'll have to think about that.
But, don't worry about that - as long as it's working. If you get to the point where you want to tune that range to .583, you could tack solder a resistor on top of R28 (in parallel with it). A 330K resistor would work fine, I'd think. That would move the expected max adjustment to 884 mV. The original 150K resistor value should give you a max range on that adjustment of around 625 mV, but could be resistor tolerance is working against you.
Nope, 1/4in switchcraft jacks. Maybe I should add that I turned the thing on it's back, powered it on, and calibrated it - so I didn't even press the load button at all the first time - maybe the big chips need to be initialized? I don't know, but it made a difference - the first time I thought I must be alright, as the dvm read .000 and turning the trimpot didn't make any difference, so I just moved on without thinking about it much.
here are some new pictures of my klee. i recently finished it completely, say: i replaced the switching PSU by a linear PSU and incorporated marc barreille's midi 2 clock converter...
Joined: Feb 07, 2007 Posts: 351 Location: Zagreb, Croatia
G2 patch files: 4
Posted: Tue Sep 16, 2008 5:47 am Post subject:
calibration of range switch
I've noticed that my klee is decalibrated somehow. When range switch is on position 5 (1V) reading I get when only one bit (step1) active is around 1.2V. This reading is on A output. So my question before I open cabinet and get thru rats nest is: Is voltage on pin1 of U8 also 1.2 when range switch on position 5?
Thnx
Audio files: 96
Posted: Tue Sep 16, 2008 11:42 am Post subject:
No, sorry - if it reads 1.2V on a single bit with a single pot cranked up, then it would read -1.2V at that point.
IOW, it should read the range value for 1 bit and one cranked pot at that point. Only negative. So, for 1V range, with one active bit, and the LED for that pot turned on, it should read -1V at pin 1 of U8.
Theoretically, the PS shouldn't affect it - the voltage is derived from a regulated voltage. I suppose a change in grounding could? _________________ My Site
Posted: Thu Sep 18, 2008 6:47 pm Post subject:
Looks very nice Fonik. You do fantastic work. I love the rack cabinet !!! Any reason why you switched power supply types from Switch Mode Power Supply [SMPS] to a linear one? Had using a switcher been a problem? I use one in mine and it's works great .. Just curious ....
Posted: Thu Sep 18, 2008 6:54 pm Post subject:
Is it also bad on the SUM A+B, 1.2V ?? Is is just on "A" CV out? This could help isolate your trouble. If yes, and ALL the ranges are skewed, make sure the 10V reference is reading 10V +/- 5%. Also, if there IS a ground problem, that will most likely cause havoc with the regulator.
hello bill,
thank you for your kind words.
and yes, i replaced the switching PSU for a reason. it was realy noisy. the VCOs controlled by the klee sounded a little bit like they were modulated by a fast LFO! i did not feel like to evaluate the frequency and to calculate the correct filter caps size (would have thaught me something, though), so i etched myself a PCB using ken stones advanced PSU circuit. now everything is fine. _________________
Posted: Fri Sep 19, 2008 8:46 am Post subject:
OK, yes, it would be apparent that some SMPS's are better than others I have been purchasing brand new Astrodyne switchers and have good luck with them. You made a good move then especially if you had a liner haning around in need of a home .... Bill
Joined: Aug 14, 2005 Posts: 1307 Location: Björkvik, Sweden
Posted: Tue Oct 07, 2008 2:45 am Post subject:
I was on a Norwegian synth meeting this weekend and I brought the Klee of course.
When I tried to explain how it works I found that it was really hard. I should have printed the instructions from the Doc-thread and made an overview or something.
Anyway, there were lots of people that were interested in the Klee and I recommended them to check out EM for more info.
Audio files: 96
Posted: Tue Oct 07, 2008 11:03 am Post subject:
Indeed, I enjoyed the hell out of it. What was that track?
The best quick explanation of a Klee goes like this: "You know how a sequencer has that one dot that moves along? The Klee can move more dots at the same time." _________________ My Site
Posted: Tue Oct 07, 2008 4:02 pm Post subject:
Pehr,
Thanks for the slide show and great music. Don't feel bad about explaining the Klee, I stumbled a bit myself doing a talk at a synthesizer convention last spring Thanks again for posting the show, I enjoyed that ....
