Interested in Tau Pipe Phaser / Flanger boards ?
Page 19 of 26 [640 Posts]
Goto page: Previous 1, 2, 3, ..., 17, 18, 19, 20, 21, ..., 24, 25, 26 Next
PostPosted: Sat Jun 28, 2008 11:00 am    Post subject: Reply with quote  Mark this post and the followings unread
funkyfarm wrote:
I have a stupid question about LFO RATE Leds (green/red) and clicks in audio path...
Not stupid at all, the causes for clicks can be pretty hard to find.
What makes the clicks audible ?
putting some LEDs onto frontpanel ?
or LFO circuitry itself (lying next to audio circuit) ?
I mean : if no LED, no click ?
Could be that removing the LEDs gets rid of the clicks, you'll have to try that.
Other causes can indeed be audio wires running close to the LFO circuit or wires, this could maybe be tested by moving the wires around to see if things change.
Also it is possible that the clicks ripple through the power supply, for that it would be best to get in some isolation with a couple of small resistors (like 22E) in the power lines of the LFO circuit together with some 100n or so caps to ground - best on the side that goes to the supply.
But you'll have to experiment Wink
jhaible
PostPosted: Sun Jun 29, 2008 5:21 am    Post subject: Reply with quote  Mark this post and the followings unread
funkyfarm wrote:
(everybody can see my awfull and temporary setup in Photos of what you've built with JH PCBs thread...)
thank you,
ff
Do you have a click in the audio (I'd be surprised if you did!), or are you just asking for precautions not to end up with clicks ?
JH.
funkyfarm
PostPosted: Sun Jun 29, 2008 12:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
(I'm not afraid at all but) yes, i guess i can hear some clicks, when lfo Rate reaches a certain point...
I'm sure that with some more careful wiring everything will be alright.
But i've started wondering what causes clicks in the audio path (how silly I am) : LED itself (brief current load ? small drop voltage or else ?) or the presence of the lfo circuitry (next to audio).
BlueHell, i've put 22R/22uF network for power supply, i even get some ferrite beads recently (if needed).
As I know i'm guilty on this project, consider this request as precautions not to end up with clicks. Smile
jhaible
PostPosted: Sun Jun 29, 2008 2:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
At the low end of the sweep range, the ladder is rather high-impedance.
so it would be a good idea to keep LED wires away from the ladder to avoid capacitive coupling.
But you can check this by temporarily disconnecting the LEDs (on the PCB side!).
If the wires to the LED are what causes the click, and you don't have enough room to place them far enough from the transitor arrays & capacitors, you could still shield these wires.
JH.
funkyfarm
PostPosted: Sun Jun 29, 2008 2:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
that's a real scoop for me.
really appreciated.
(i use no shielded wire, and understand clicks can come from lfo, led and even wires from pcb to LED ; that's a lot of possibilities for a simple click. this scares me now Very Happy )
Funky40
G2 patch files: 5
PostPosted: Sun Jul 13, 2008 12:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi there,
i wired up my Tau last Weekend, but i thought it is not running good.
But now it seems to be ok.
Not really finished all, but close to.......
stuppidly the Frontpanel was drawn with a up-down switch.
I was thinking that this makes no sense, but i had no other Iedea what up-down could mean, hehe Embarassed
Later i had a look at Jürgens Page......
The new Frontpanel, mainly for the Tau Nr.2 is drawn allready.
I will omitt the Output attenuators ( they are anyway not wired for now ) and i will omit the 1V/oct muteswitch.
Yesss, my first Phaser....... Very Happy
and also my First Jürgen Haible Module.
Query:
the 33PF caps: can they be ceramic ? I mean the cheap wheels......scheiben.
It's the only part i miss to finish the second
My first Jürgen Haible Module: The Tau Phaser
 Filesize:  90.75 KB
 Viewed:  363 Time(s)
jhaible
PostPosted: Sun Jul 13, 2008 11:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, they are meant to be ceramic. They just roll of the very high frequencies and help keeping the opamps stable.
JH.
haima
PostPosted: Sun Aug 03, 2008 9:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Jürgen - i don't know if this is the right place to ask, but do you have any tau boards left?
if not, you are planning on making a "core tau board" for the dim TD project aren't you - so i suppose i could use those?
thanks, and sorry to bother you with these kinds of questions!
haima
jhaible
PostPosted: Sun Aug 03, 2008 1:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes - please send me an email using the order form I've posted.
http://electro-music.com/forum/post-199231.html#199231
(Just added here, where it's easier to find than scrolling thru a long thread)
JH.
numbertalk
PostPosted: Wed Aug 20, 2008 1:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Juergen,
For the Compact Phasing clone you mention if using an 18VAC wall wart to up the 470uf caps to 1000uf/50V - does the same need to be done if using a wall wart for the Tau?
Also any tips on setting the 3 trimmers?
Thanks.
jhaible
PostPosted: Wed Aug 20, 2008 4:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
numbertalk wrote:
Hi Juergen,
No. I even ran my Tau from a Wallwart with less than (nominal) 15V AC.
Haven't tested it on mains undervoltage, though.
JH.
numbertalk
PostPosted: Thu Aug 21, 2008 7:50 am    Post subject: Reply with quote  Mark this post and the followings unread
jhaible wrote:
In my Tau, I'm using a 100k "Pull Pot" for resonance.
The formerly 220k is changed to 180k on the board,
The 100k resonance pot has a 20k (final value tbd) resistor in series with its cw end. (i.e., cw end of pot goes to 20k resistor, 20k resistor goes to board connector.)
The switch of the pull pot is connected to short the 20k resistor, when the knob is pulled out. So I get nice high resonance *without* oscillation with the knob pushed in, and screaming oscillation when pulled out.
Sorry if this is a dumb question, but when you say you short the 20K resistor, you are somehow bypassing it with switch, when the knob is pulled out, correct? Could you tell me how exactly the switch part of this pot is wired - if a SPST what are the 2 switch lugs connected to (or not connected)?
Also, did you keep this as a 20K pot (you say final value tbd).
Thanks.
jhaible
PostPosted: Thu Aug 21, 2008 10:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks.
The cw end of the pot is not connected directly, but via a 20k resistor.
The Pull operation of the swich does bypass the 20k resistor.
JH.
numbertalk
PostPosted: Thu Aug 21, 2008 10:10 am    Post subject: Reply with quote  Mark this post and the followings unread
So, again, forgive me if I'm being a bit thick, but while I do understand the cw lug connecting to a 20K resistor and the other lead of that resistor connecting to the board where the cw lug originally connected to the board, but then how is that bypassed with the pot switch exactly? Is the cw lug also wired to one pole of the switch with the other pole connected to another point on the board? If so where on the board exactly? I've never actually used a switched pot before (but would like to as this seems an elegant way to do this) so this might be part of my problem - I'm imagining the switch works separately from the 3 pot lugs (that it doesn't do any switching between any of the 3 pot lugs) but does the switch actually switch between 1 or more lugs or something like that? Tried to find data sheets for switched pots or any explanations online but with no luck.
Thanks for the help.
jhaible
PostPosted: Thu Aug 21, 2008 1:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
You connect the switch parallel to the (off board) 20k resistor, such that closing the switch does bypass that resistor.
Doesn't matter whether this is a separate switch, or built into the potentiometer ...
JH.
numbertalk
PostPosted: Fri Aug 22, 2008 9:43 am    Post subject: Reply with quote  Mark this post and the followings unread
JH.
funkyfarm
PostPosted: Sat Aug 23, 2008 1:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think i will get a 2U panel for it.
Tau_Phaser_Panel_85_001.fpd
 Filename:  Tau_Phaser_Panel_85_001.fpd
 Filesize:  3.02 KB
 Downloaded:  195 Time(s)
numbertalk
PostPosted: Fri Sep 19, 2008 9:42 am    Post subject: Reply with quote  Mark this post and the followings unread
EDIT - Just found in the thread where you say you can use something like a 500R or 1K pot in series for the V/Oct adjustment - would this be linear taper?
I can't quite make it out on the page on your site (and it seems Bill & Will reference 2 different values for this - 1M and A10K) - could you tell me what value and taper of pot to use to fine tune CV in/V/Oct from the front panel? Looks like a 1K to me on your site but if so what taper?
Funky40
G2 patch files: 5
PostPosted: Sun Oct 12, 2008 10:27 am    Post subject: Reply with quote  Mark this post and the followings unread
In the meantime i have two Tau Phasers running and i got somewhat the hang for it.
FANTASTIC Module, i Love it !
It brought my Modularsynth one step further.
but it takes some time to know it good.
It reacts REALLY different to different sounds.
My first Phasers in my Synth, and the first Phaser i really like.
I'm very glad to have one, ...öhmmm two Wink
It makes IMO sense to have two btw.
Thanks Jürgen !
b-funk
PostPosted: Sun Oct 12, 2008 11:40 am    Post subject: Reply with quote  Mark this post and the followings unread
I told you so!!! Very Happy
jhaible
PostPosted: Mon Oct 13, 2008 2:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
numbertalk wrote:
1k linear taper.
JH.
numbertalk
PostPosted: Tue Oct 14, 2008 6:40 am    Post subject: Reply with quote  Mark this post and the followings unread
jhaible wrote:
numbertalk wrote:
1k linear taper.
JH.
Funky40
G2 patch files: 5
PostPosted: Wed Oct 22, 2008 3:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello Jürgen,
I like to modifie the LFO on my Tau.
The answer how to slow down i found here
The main point is that i like to close the modulation depth to zero ( or close to zereo ). It does not now.
the other point is that i not only like to have the LFO slower, i also like to have it faster.
How to do this ?
jhaible
PostPosted: Wed Oct 22, 2008 3:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Funky40 wrote:
Hello Jürgen,
How to do this ?
Referring to http://www.jhaible.heim.at/tau/jh_tau_sch_page3_control.pdf , to make the LFO faster, decrease R66 and/or C54. (This only shifts the whole range of LFO rates up to higher values.)
Then you probably want to extend the LFO rate range on the low side, by decreasing R67.
R67 can only be made smaller until you get offset problems from U6A.
You can then use a low offset FET-input opamp instead of the TL072.
(LF412, or something better.)
Don't bother to replace the opamp *unless* you actually run into offset problems from decreasing R67.
JH.
Funky40
G2 patch files: 5
PostPosted: Thu Oct 23, 2008 4:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks Jürgen, i will try.
Better than LF412 ? I assume the LT1013 would be one.
How about the modulation depth, how can i close this to Zero or minimise it.
Now i have by default allways a Modulation.
Perfect for common Phaser use, but not for modularsynth experiments.
