today> Twyndyllyngs Chez Mosc
 Forum index » Clavia Nord Modular » G2 Patches - Completed » Acoustic
Plucked String
Page 1 of 1 [13 Posts]
Tim Kleinert
G2 patch files: 236
PostPosted: Thu Mar 23, 2006 4:52 am    Post subject: Plucked String
Subject description: physical model
Here's an elaborate plucked string model. The controls are pretty self-explanatory.
plucking: transient shape, force, stiffness, position
string: tuning, loss, absorption, harmonics
damper (on key release): speed (with optional release velocity sensitivity, yes sir Cool), stiffness, HF and LF damping
The nice thing is that many of these parameters should be controlled by keyboard tracking and/or velocity. And here's where the G2 shines: just hit those morph buttons and tweak away! Smile
I used comb filters instead of log-tracking delays. The extra DSP usage doesn't matter, because I would hit the memory headroom otherwise anyway. And the bonus is: zero tuning issues Cool. A voice uses half a DSP, both in cycles and in memory, so that's 15 voices from an expanded G2, or 7 from an unexpanded one.
There are some nice tricks in there, like filling the delay line with exactly one cycle of the excitation signal, and using delays as allpass filters to induce spectral dispersion on the strings (the "harmonx" parameters). The benefit compared to using "real" allpass filters is that the tuning remains constant (...mostly Wink). There are some nice inharmonic dispersions you cannot get with this, but as the G2 lacks real allpass filters anyway, it's the only solution. (Robs allpass filter and the MultiFilter allpass mode both have unity gain issues Confused)
All variations filled, and optimised for keyboard performance (which is where the joy of physical modelling lies anyway Wink.)
Enjoy.
best,
tim
PluckedString TK.pch2
elaborate plucked string physical model
 Filename:  PluckedString TK.pch2
 Filesize:  3.86 KB
 Downloaded:  3172 Time(s)
cebec
G2 patch files: 31
PostPosted: Thu Mar 23, 2006 11:20 am    Post subject: Reply with quote  Mark this post and the followings unread
nice job, tim!!!
also, isn't the 6 dB BP output of the 'Filter Multi-mode' a real allpass?
Tim Kleinert
G2 patch files: 236
PostPosted: Thu Mar 23, 2006 12:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
I only know that it is unusable for spectral dispersion within a waveguide, because it isn't exactly unity gain. It's a tad more, making feedback loops blow up in a nasty and painful way.
I attached a small demonstration patch: An allpass-mode MutliFilter in a feeback loop (inverted, because the allpass output, for some reason, is inverted too).
Inject a short pulse into it to make it blow up: "Eeee!". Watch your ears!
I don't know if this is 'correct' allpass filter behaviour. I doubt it.
Robs neat allpass is much better. It's actually "usable" in a waveguide. But its output is a tiny tiny tad below unity gain, so it dulls out the resonation somewhat.
Using this kind of allpass filter (instead of a delay line) produces more inharmonic dispersion, which can be nice for more "ethnic" sounding stuff. But it mucks up the tuning too.
allpass funk.pch2
watch your ears!
 Filename:  allpass funk.pch2
 Filesize:  1022 Bytes
 Downloaded:  2532 Time(s)
Chet
G2 patch files: 35
PostPosted: Mon Mar 27, 2006 6:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for posting this. I'm gonna have to take a look at that allpass filter; it sounds really good, and like you said, doesn't mess up the gain. I was able to make a neat-sounding marimba with only a couple of knob twists.
jamos
G2 patch files: 41
PostPosted: Mon Mar 27, 2006 8:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is amazing, Tim. Good polyphony, too - thanks!
Audio files: 235
PostPosted: Tue Mar 28, 2006 7:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Excellent. Thanks, Tim...
Chet
G2 patch files: 35
PostPosted: Tue Apr 11, 2006 10:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Tim, can you tell me where I can find a description or example of Rob's allpass filter? I'd like to experiment with it.
Audio files: 235
PostPosted: Tue Apr 11, 2006 11:02 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm not Tim, but, nonetheless, try this topic, http://electro-music.com/forum/topic-5684.html
Chet
G2 patch files: 35
PostPosted: Tue Apr 11, 2006 12:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, Howard. I tried it out and it does what Tim described, although the gain was sometimes appeared a little more than unity. But it's definitely much better-behaved than the Clavia-supplied allpass filter.
I can easily get some neat ethnic sounds out of it. But like Tim said, it tends to skew the tuning of fundamental pitch, so some compensation is necessary.
Thanks again.
seanwayland
PostPosted: Tue Oct 28, 2008 7:13 pm    Post subject: guitar Reply with quote  Mark this post and the followings unread
Hi tim ,
excellent werk . Is it possible to set a velocity threshold somehow. Below the threshold keystrokes just "detune" the patch , above the threshold it " replucks" the string . That way you could possibly control playing legato and staccato . Another option would be for it to work like a hammond organ and "detect" legato playing ( when a key is pressed while another key is still down ) . I will work on this . It would work only work in mono I guess ...
cheers
sean
kara
G2 patch files: 5
PostPosted: Wed Oct 29, 2008 1:02 am    Post subject: Reply with quote  Mark this post and the followings unread
This sounds excelent !
It's way above my knowledge of programming the G2X, so thank you very much for sharing this.
k
Free samples, Vsti's and Artist hosting at www.kara-moon.com
Music forum at www.kara-moon.com/forum
seanwayland
PostPosted: Fri Jul 03, 2009 7:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
hi tim ,
Hope all is well. I have been experimenting with your guitar patch . I put an ADSR at the end to make it legato . At this point if a key is held down the next note pressed plays staccato without the ADSR. Is there a way to reverse this which would make more sense from an articulation point of view . I want to be able to play legato or staccato with lines ... please email me seanwayland@gmail.com thanks
best regards
sean
wheel att guitar.prf2
 Filename:  wheel att guitar.prf2
 Filesize:  9.82 KB
 Downloaded:  1805 Time(s)
Tim Kleinert
G2 patch files: 236
PostPosted: Sat Jul 04, 2009 4:18 am    Post subject: Reply with quote  Mark this post and the followings unread
I emailed you.
