Alexander
G2 patch files: 4
Posted: Sat Nov 01, 2008 6:50 pm Post subject:
| Sound Maniac wrote: | | i have signal in the parameter/peakmeter or whatever to call it.. But dont hear the sound.. |
The peakmeter of the g2's audio out module?
If yes, your problem is in the audio settings of either your interface , you plugged some cables wrongor maybe, you haven't selected the right input in cubase.
If no, and you are talking about your peakmeter in cubase, the problem is your software sequencer's patching/routing of audio (or in a midi track, midi).
Check if the midi signal is going to the right midi port/channel and check the g2's midi led!
"i got sound everywhere, its only cubase when putting the notes no sound but signal.."
This is a very tricky one, you hear a lot so something should be ok with cubase!
But when you put some notes in a midi track in cubase, send them to the g2, and listen to the g2, you have no sound, but maybe you just see the peakmeter in your midi track indicating a midi out signal!?
Solutions:
You could plug some headphones in the g2 and check if it's an audio problem. If it works, check the interface, if that works, check cubase.
If it's midi, send notes to the g2 from a midi track in cubase, patch something simple and see if the notes are coming through. If this doesn't work some of the above might be wrong in your setup.
Shouldn't be a lot of work to solve this, but it is very very hard doing it online with not a lot of information to go with!
Good luck! _________________ http://husc-sound.com |
Sound Maniac
Posted: Sun Nov 02, 2008 6:32 am Post subject:
| I can use it everywhere and record everywhere.. But by add key notes on cubase when play no sound.. |
Alexander
G2 patch files: 4
Posted: Sun Nov 02, 2008 7:37 am Post subject:
| Sound Maniac wrote: | | I can use it everywhere and record everywhere.. But by add key notes on cubase when play no sound.. |
I know... it's a mystery! _________________ http://husc-sound.com |
ark
G2 patch files: 31
Posted: Sun Nov 02, 2008 9:00 am Post subject:
| So what happens if you use a different synth instead of the G2? |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Sun Nov 02, 2008 9:20 am Post subject:
| Sound Maniac wrote: | | I can use it everywhere and record everywhere.. But by add key notes on cubase when play no sound.. | Well, maybe this discussion will go much better if the writing isn't in 'short-hand' anymore. We take the time to read and think about your question, so, please, try to be as exact as you can be...
If you record your synth in CuBase you can hear the notes in Playback, right?
I use CuBase, although a very old version, and there is no command 'Add Key Notes'. I also searched the net (SoundOnSound) and the command isn't found. You don't want to use 'Record' to get your Midi Notes into CuBase, how do you expect to hear these being played as they aren't there? There are many ways to get some notes into CuBase:
1 play it on a keyboard which is connected by Midi and sends MidiNotes, but then you have to record it which you don't want to do;
2 import some existing Midi file from somewhere and
3 write or draw your notes in 'Edit mode'.
There is another way to make the sound which is using the keyboard in the Grid available in Edit mode, but this can't be recorded and you don't want to use the mouse, because you want to tweak the sound on the synth...
At the other hand, Sound Maniac, do you prefer to be helped off forum by somebody who can speak and write Swedish instead of English?
Wout |
DrJustice
Joined: Sep 13, 2004 Posts: 2112 Location: Morokulien
Posted: Sun Nov 02, 2008 10:05 am Post subject:
| Sound Maniac wrote: | | i have signal in the parameter/peakmeter or whatever to call it.. But don't hear the sound.. |
1 - So your computer running Cubase has its MIDI OUT port (possibly provided by an external MIDI interface) connected to the G2 MIDI IN port, right?
2 - I also assume that you have successfully entered some notes in the Cubase piano roll editor.
3 - The level meters in the Cubase tracks containing the MIDI notes shows activity when you play back your sequence.
Provided that all three points above are correct, then I can only see two possibilities (there may of course be something that I'm missing):
1 - the MIDI channel set for the Cubase track with the MIDI notes does not match the MIDI channel that the G2 is receiving on
2 - there is a defect MIDI interface (on either of G2 or the MIDI interface connected to the computer) or a defect cable
To any G2 owners (only got a classic here I'm afraid), is there a MIDI activity light on the G2?
DJ
Posted: Sun Nov 02, 2008 10:10 am Post subject:
| Wout Blommers wrote: |
Wout |
Or just write something in swedish here, if you think you can phrase it better - there are a fair amount of scandinavian members here...
Sound Maniac
Posted: Sun Nov 02, 2008 12:09 pm Post subject:
| Ill be back with exact Print Screens, that shows everything that have with the soundcard to do and the modular g2.. Ill zip them with winrar upload them to sendspace and post link here.. Big thanks to all of yah guys! PLUR |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Sun Nov 02, 2008 1:30 pm Post subject:
| DrJustice wrote: | | ... To any G2 owners (only got a classic here I'm afraid), is there a MIDI activity light on the G2? | Yes, on my G2X there is, right underneath the Mic Gain knob.
Wout |
Sound Maniac
Posted: Sun Nov 02, 2008 3:33 pm Post subject:
| jag förstår engelska har inga problem med det men förlorar aldrig på ett försök kanske något jag missar |
Posted: Mon Nov 03, 2008 4:12 am Post subject:
| Sound Maniac wrote: | | jag förstår engelska har inga problem med det men förlorar aldrig på ett försök kanske något jag missar |
Öh, ok.
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Mon Nov 03, 2008 4:21 am Post subject:
| Sound Maniac wrote: | | jag förstår engelska har inga problem med det men förlorar aldrig på ett försök kanske något jag missar | Well...?
We all want to learn...!?!
Wout |
iPassenger
Joined: Jan 27, 2007 Posts: 1070 Location: Sheffield, UK
G2 patch files: 78
Posted: Mon Nov 03, 2008 6:13 am Post subject:
| Quote: |
Well...?
Wout
Yeah tell us Stefan, what is it he is trying to do?
I had my money on a midi communication issue.. but judging by the various responses looks like everyone has had their own spin on this "issue".
Language barriers sure are fun.  _________________ iP (Ross)
Posted: Mon Nov 03, 2008 9:03 am Post subject:
It's just a comment saying that he understands english ok but there's nothing to lose by trying.
I'm guessing there may be another post on the way.
Sound Maniac: if you don't feel like going swedish here it's ok to PM me.
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Mon Nov 03, 2008 10:14 am Post subject:
So...
jag = I
förstår = understand
engelska = English
har inga = ? (have no?)
problem = problems
med = with
det men förlorar aldrig på ett försök = ? (beat me )
kanske = chance
något jag = something with I
missar = to lose
Jag förstår svenska = I understand Swedish?
Wout |
Posted: Mon Nov 03, 2008 12:36 pm Post subject:
Pretty close. Well done!
det men förlorar aldrig på ett försök = that but never lose (literally: lose never) on a try
kanske = maybe
något jag = something (that) I
missar = am missing
| Wout Blommers wrote: | So...
jag = I
engelska = English
problem = problems
med = with
kanske = chance
missar = to lose
Wout |
Sound Maniac
Posted: Mon Nov 03, 2008 4:43 pm Post subject:
| jag vill kunna lägga ut noter i midi ist för att spela in samples hela tiden och har hamnat i knipa.. Ljudet funkar överallt förutom när jag lägger ut midi noter.. Men för varje not som spelas ser jag signal i parametern/peakmeter/db meter eller vad man nu ska kalla det.. till slut hamna jag här.. |
Sound Maniac
Posted: Tue Nov 04, 2008 4:14 am Post subject:
| Sound Maniac wrote: | | jag vill kunna lägga ut noter i midi ist för att spela in samples hela tiden och har hamnat i knipa.. Ljudet funkar överallt förutom när jag lägger ut midi noter.. Men för varje not som spelas ser jag signal i parametern/peakmeter/db meter eller vad man nu ska kalla det.. till slut hamna jag här.. |
OK, so you see the peak meter in Cubase light up, but you can't hear anything? Do you see the MIDI LED on the G2 hardware light up? If you put an envelope module in a patch and look at it in the editor (with KB set to On), do you see the green gate square light up?
DrJustice
ark
G2 patch files: 31
Posted: Tue Nov 04, 2008 6:45 am Post subject:
| In the image you posted, you have not connected the G2's audio outputs to anything! Of course you are not getting any sound! |
Sound Maniac
Posted: Tue Nov 04, 2008 7:24 am Post subject:
theres too audio cables connected output 1/2 connected to Rme Fireface Channel 3/4.. I figure it out before, but i thought if the modular g2 editor works its not have to be a problem i just came from a music store with 2 new midi cables.. i came thru the door to the pc.. will try now with 2 new midi cables connected to the soundcard  |
Wout Blommers
Audio files: 123
G2 patch files: 12
| ark wrote: | | In the image you posted, you have not connected the G2's audio outputs to anything! Of course you are not getting any sound! | If true, one picture tells more then 1000 words, even in Swedish
Wout |
Sound Maniac
Posted: Tue Nov 04, 2008 7:28 am Post subject:
I was at musikborsen i bought TSM Midi Audio cables i just gonna eat get some energy and ill try them and ill be here to write if they work or not PLUR BIG THX FOR EVERYTHING APRECIATE ALL! |
Sound Maniac
Posted: Tue Nov 04, 2008 8:10 am Post subject:
it work but got any other problem by the pc now
i get windows blue screen and pc restart, same thing happend long long time ago every time i pressed the on Enable Midi Controll, In fireface mixer |
