Sound Maniac
Posted: Tue Nov 04, 2008 8:12 am Post subject:
it works all time but when i stop button and wait for 2-5min
i get that blue screen :/ but ill try solve it my self if i dont ill msg here.. |
DrJustice
Joined: Sep 13, 2004 Posts: 2112 Location: Morokulien
Posted: Tue Nov 04, 2008 1:17 pm Post subject:
Good to hear you have it working now
Hope you get that blue screen sorted too...
| Sound Maniac wrote: | | I was at musikborsen i bought TSM Midi Audio cables |
Was that MIDI or audio cables? What did you do to make it work? I'm curious
DJ
Sound Maniac
Posted: Wed Nov 05, 2008 4:57 am Post subject:
Midi Cables did make it work, I know what you've thinking about i have 2 audio jack cables not one in the pic theres only one..
I will formate the pc today, and ill see if it works too fix that with the blue screen.. |
Sound Maniac
Posted: Wed Nov 05, 2008 6:19 am Post subject:
| im just scared too use my knowledge sometimes i need to get rid of that.. |
Sound Maniac
Posted: Wed Nov 05, 2008 6:20 am Post subject:
| Sound Maniac wrote: | | im just scared too use my knowledge sometimes i need to get rid of that.. im formating my pc now ill see if it gets better now.. |
Sound Maniac
Posted: Wed Nov 05, 2008 6:23 am Post subject:
| Sound Maniac wrote: | | Sound Maniac wrote: | | im just scared too use my knowledge sometimes i need to get rid of that.. im formating my pc now ill see if it gets better now.. |
| but it is midi cables for sure |
Sound Maniac
Posted: Wed Nov 05, 2008 6:56 am Post subject:
| will i have some problems with the modular g2 if i install Servervice Pack 3 ???!?! maybe its why i got blue screen |
Sound Maniac
Posted: Wed Nov 05, 2008 7:09 am Post subject:
| Sound Maniac wrote: | | will i have some problems with the modular g2 if i install Servervice Pack 3 ???!?! maybe its why i got blue screen |
I mean does Service Pack 3 affect Modular G2? |
ark
G2 patch files: 31
Posted: Wed Nov 05, 2008 7:24 am Post subject:
I've been using Service Pack 3 with my G2 since it came out, with no problems at all.
I would be more inclined to suspect the drivers for your sound card, and would start by installing the latest versions of those drivers. |
Sound Maniac
Posted: Wed Nov 05, 2008 7:47 am Post subject:
| Sound Maniac wrote: | | Sound Maniac wrote: | | will i have some problems with the modular g2 if i install Servervice Pack 3 ???!?! maybe its why i got blue screen |
all works now, but only 1 midi if try add one more it works too add and it is signal but 2nd dont have any sound.. ?? really this shit is driving me crazy.. |
Sound Maniac
Posted: Wed Nov 05, 2008 7:52 am Post subject:
| Sound Maniac wrote: | | Sound Maniac wrote: | | Sound Maniac wrote: | | will i have some problems with the modular g2 if i install Servervice Pack 3 ???!?! maybe its why i got blue screen |
My point is i can only use one sound, how does i add one more lead |
Joined: Apr 03, 2004 Posts: 24652 Location: The Netherlands, Enschede
Audio files: 326
Posted: Wed Nov 05, 2008 8:27 am Post subject:
| Sound Maniac wrote: | | all works now, but only 1 midi if try add one more it works too add and it is signal but 2nd dont have any sound.. ?? really this shit is driving me crazy.. |
Maybe set the voice count higher for the G2 patch. _________________ Jan
Sound Maniac
Posted: Wed Nov 05, 2008 8:52 am Post subject:
| hmm.. what do you mean? how does i do it? and what does it have with adding one more midi to do? |
Audio files: 326
Posted: Wed Nov 05, 2008 10:22 am Post subject:
Just click it up in the editor tool bar, likely it can be done from the keys version of the synth as well, but I don't know how. Anyway, it the voice count determines how many notes a patch can play simultaneously. _________________ Jan
Sound Maniac
Posted: Wed Nov 05, 2008 12:15 pm Post subject:
Ok i willl thanks man! but i want too add one more patch not add more notes.. and have them running on same time.. |
ark
G2 patch files: 31
Posted: Wed Nov 05, 2008 12:23 pm Post subject:
Hold down the gray "Shift" button and, while you are doing that, press the button marked "B" under the "Keyboard Assign" label.
You should now have two Slots active. The one with the flashing LED is the one you can edit at the moment; you can switch between them by pressing the "A" and "B" buttons.
Select one patch for A and another for B. Now notes that you send to MIDI channel 1 should go to A and notes that you send to MIDI channel 2 should go to B. |
Sound Maniac
Posted: Wed Nov 05, 2008 12:34 pm Post subject:
| but if i want add more than 4 patches, alos more than A B C D.. how does i do after.. |
Sound Maniac
Posted: Wed Nov 05, 2008 12:35 pm Post subject:
| But what if i want to add more than 4 patches, also more than A B C D.. how does i do after.. |
Sound Maniac
Posted: Wed Nov 05, 2008 12:37 pm Post subject:
| But what if i want to add more than 4 patches, also more than A B C D.. how does i do after.. And i dont know to explain how greatfull i am and how much i apreciate this from you! Not much people who want too help and that put this much time too help! sry if im asking too much! |
ark
G2 patch files: 31
Posted: Wed Nov 05, 2008 12:43 pm Post subject:
| Sound Maniac wrote: | | but if i want add more than 4 patches, alos more than A B C D.. how does i do after.. |
You don't. A G2 can have only 4 patches loaded at one time, one each in slots A, B, C, and D. |
Sound Maniac
Posted: Tue Nov 11, 2008 2:17 am Post subject:
i just want to thank all for wonderfull help. PLUR ive been busy raping it too  |
Sound Maniac
Posted: Tue Nov 11, 2008 2:18 am Post subject:
i just want to thank all for wonderfull help. PLUR ive been busy raping it too the synth also! |
