frequency shifter
Page 13 of 23 [574 Posts]
Goto page: Previous 1, 2, 3, ..., 11, 12, 13, 14, 15, ..., 21, 22, 23 Next
urbanscallywag
PostPosted: Fri Oct 10, 2008 11:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah, sounds interesting.
I was imagining making a stripped down FS1A and patching in modules to do mixing and switching like that but I seem to have underestimated a stand alone unit (which also makes sense from a power point of view).
urbanscallywag
PostPosted: Tue Oct 21, 2008 6:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
My FS1A is almost entirely populated! I'm waiting on tempcos that will probably be here by the time I finish wiring the FS1A, and I left regulators out so I can run it on the bench before putting it into an enclosure. I need to get a flux pen to do the surface mount capacitors too.
Some building tips:
Mind the resistors near the connectors, try to mount them pushed away from the connector. I am using MTA100 headers and I had to push the resistors over a bit.
In the dome filter mount the resistors before the resistor arrays or else it might be a bit of a squeeze for your iron. I would do the resistors, then the arrays, then the IC sockets (optional), then the (apparently heat sensitive) polystyrene capacitors.
Make sure you buy narrow/tall 22uF capacitors if available. Mine are fat/short and they are a little bit of a tight squeeze when mounted next to each other.
Pay attention (as mentioned on the BOM) to the single versus multi-turn pot footprints. Specifically you cannot use single turn with the inline pin out (oops).
JH's FS1A is very well documented. I like the actual component values on the PCB, it saves a lot of work/time. I hope the calibration goes as smoothly.
On to cables and calibration! Cool
toppobrillo
PostPosted: Wed Nov 05, 2008 2:19 am    Post subject: Reply with quote  Mark this post and the followings unread
finished finally over the weekend.. working well as expected! thanks for this project. now i gotta make a panel so i can use it...
 Filesize:  433.98 KB
 Viewed:  462 Time(s)
urbanscallywag
PostPosted: Sat Nov 08, 2008 11:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool. That's a nice Panavise you've got there. Shocked
I just have to wire the switches. Wish I had time. Sad
toppobrillo
PostPosted: Sun Nov 09, 2008 5:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
yeah the vise is indispensable.. here is a rough layout i made of a serge-style panel design. the bottom half will be moved around some i just wanted to see how i could fit everything, and maybe leave room for the 'big knob' too. fun stuff!
 Filesize:  31.36 KB
 Viewed:  14872 Time(s)
urbanscallywag
PostPosted: Sun Nov 09, 2008 5:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow, you've got the Serge thing down. Cool
What is the signal on the VCO jack?
toppobrillo
PostPosted: Sun Nov 09, 2008 9:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
hey, yeah i think i do Cool ... um the 0 and 90 are the quadrature vco outputs. jurgen has a direction input on his FS-1, i thought that was a cool idea, to switch it electronically, so once i get it wired up better i may try and add that functionality to mine since i have an extra space.
urbanscallywag
PostPosted: Sun Nov 09, 2008 10:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
I understand the 0 and 90 degree outputs, but what's the purple jack for?
Luka
PostPosted: Sun Nov 09, 2008 10:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
finally i template to design my FS-1 from
looks great too
thanks josh, good work Smile
problemchild
melbourne australia
jhaible
PostPosted: Mon Nov 10, 2008 2:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Love the look of this Serge panel, and it gives me a very special feeling to see one of my circuits in that format:
The Serge catalogue with its module descriptions was a main source of inspiration for me when I started to design my own JH-3 synthesizer.
JH.
toppobrillo
PostPosted: Mon Nov 10, 2008 5:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
the 'direction' input i was talking about below, assuming i get it to work Cool
thx jurgen, and again thank you for such a great project. it went very smoothly from start to calibration time, which went as described too..
the first sounds to come through this FS was the first cassette i found laying around- i had no idea the B-52s could sound so terrifying! Laughing
josh
urbanscallywag
PostPosted: Mon Nov 10, 2008 7:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
I see, I didn't connect the two. Smile
urbanscallywag
PostPosted: Thu Nov 13, 2008 10:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
A new frequency shifter on the market to compare to, Buchla 285e!
jhaible
PostPosted: Tue Nov 18, 2008 12:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, there are connectors that are slightly larger than Reichelt's PSK series. Thanks for sharing this hint.
And even with the PSK connectors, it's a good idea to solder the connector in first, and then the neighbouring resistors. (You don't have to bend the resistors away from the connectors in that case, but you have to make sure they are not bent towards the connectors.)
JH.
mono-poly
PostPosted: Tue Nov 18, 2008 2:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
I love that Serge inspired design!
cbm
PostPosted: Tue Nov 18, 2008 3:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
I spoke to Don about this, and he thinks it's a better unit than the original 285, and that's saying something. I can't wait to get one.
Chris Muir
http://www.eardrill.com <– My jobby (more than a hobby, less than a job)
urbanscallywag
PostPosted: Tue Nov 18, 2008 9:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool
At first glance it doesn't appear to be able to do extremely small shifts like JH's design. Seems like there are two dome filters since you can shift using an external signal. The question is the internal oscillator quadrature (possibly the only way to do sub-audio shifts with this design)?
[edit: not an appropriate place for Buchla worship Smile]
urbanscallywag
PostPosted: Tue Nov 18, 2008 9:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
JH.
I normally like to solder plastic things later to avoid melting them while soldering things like resistors but in this case it makes sense.
My FS1A is just waiting on switches. I wanted to design something using analog switches but I don't have the time lately.
zthee
PostPosted: Fri Nov 21, 2008 12:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Topp, Great panel! I think that design made me decide that I need to build one! Wink
toppobrillo
PostPosted: Fri Nov 21, 2008 8:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks! whoever the graphics person is that worked on the later serge panels is very talented. Smile
been busy lately and haven't had time to think about it much more.. i'd love to see your panel design by the way. oh, did you ever describe the way you made the panels for your synth? sorry if it has been discussed elswhere..
Luka
PostPosted: Sun Nov 23, 2008 4:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
has anyone not bought the parts kit from bfunk when building this board?
what sort of processes am i going to put myself through to get the desired values for the dome filter? should i just stock up on every value of cap and resistor,,, or can i roughly follow the BOM and just buy a lot around those numbers
problemchild
melbourne australia
/mr
PostPosted: Sun Nov 23, 2008 5:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yep, I sourced them myself for me and three friends.
No...
I ordered 1% capacitors and the resistor values that Jürgen's Excel sheet gave me for my chosen cap values. Quite easy, really.
If you choose caps with less precision you'll have to measure them first, then put this data into the Excel sheet and then buy the desired resistors...
Luka
PostPosted: Sun Nov 23, 2008 5:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
ok thanks
looks like my next order will be entirely for JH projects Smile
problemchild
melbourne australia
urbanscallywag
PostPosted: Sun Nov 23, 2008 6:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
I self sourced the parts for my FS1A. I was able to match my dome filter using the JH's Excel sheet pretty well with resistors I have in stock but I did have to order maybe 6 odd resistor values on my next order to meet <1% tolerance of the time constants.
davebr
PostPosted: Sat Dec 06, 2008 10:39 am    Post subject: Frequency Shifter
Subject description: Panel Design
I've received my PCBs and am starting to organize to build them. I've done a preliminary panel design. A larger image is on my web site.
http://modularsynthesis.com/jhaible/shifter/jhshifter.htm
I'd appreciate feedback as I'm still trying to figure out the controls that I need. I've eliminated the output attenuators so I could fit it reasonably on a 2U panel. (Note - I've since finished this module and updated the photo)
