Scott Stites
Audio files: 96
Posted: Tue Nov 25, 2008 8:47 pm Post subject:
| Quote: | | Wasn't that the secret "Holiday in the Bahamas" Easter Egg mistake Scott? |
Not Bahamas, exactly.....
Yes, plord wins an no-expense paid vacation to fabulous Wichita, KS, which is now entering its quaint and bucolic Winter Season. First he shall be entertained at the local Cowtown Museum, and presented with an aluminum encrusted buffalo chip. From there, he will be swept on a whirlwind tour of the local McDonald's and Taco Tico restaurants for a sampling of the fine dining Wichita is famous for. The local constabulary shall award mr. plord with an honorary (and totally real) speeding ticket for travelling at speeds imagined to be over the legal limit.
After that is promised a fine evening of square dancing and the obligatory shotgun wedding to the mayor's favored daughter, or else. The wedding tatoos shall be half-price, with a free piercing for every seven square inches of skin covered by ink. Anesthesia provided by Jack Daniels distillery.
After that, there'll be an old-time church-agoin' with the Reverend Fred Phelps describing the fires of hell plord so richly deserves for building something as demonic as the Klee sequencer. _________________ My Site |
mark_olson
Joined: Oct 26, 2006 Posts: 177 Location: Lawrence, Kansas
Posted: Tue Nov 25, 2008 8:58 pm Post subject:
You all probably think Scott is trying to be funny but he's not - everything he says about the Wichita experience is true.  |
Sound
Posted: Sat Nov 29, 2008 2:45 am Post subject:
Wiring my Klee, I have noticed, that I put an extra led in the frontpanel: The LOAD led.
I don't know why I did it, Well, my question is: It will work connecting the led to pin 10 of the U3 CD4071 through a 6,8K resistor? (schematics digital board page 3 of 4)
Scott Stites
Audio files: 96
Posted: Sat Nov 29, 2008 9:13 am Post subject:
I know the reason why you did it - because it makes sense. Not putting a Load LED in has long been one of those things that makes me want to kick myself. Actually, not putting in an External Load LED is the thing that makes me self-flagellate. It would be really useful to be able to see the rate of the re-load signal if one is doing that.
Putting the LED signal at pin 10 of U3 would probably not cause it to light at all - the external load and load pattern switch signals have been narrowed to an extremely narrow pulse at that point - and as soon as that point sees a gate bus load signal, *poof* it goes away as soon as the pattern loads, so that would be too quick, too.
However, if you put the tap point at the output of pin 1 of U1 (LM358), it would light every time the Klee received an external load signal - it would stay on as long as that signal was high. It wouldn't light with a manual load, or a gate bus 1 load, but an LED wouldn't be all that useful on those situations - with a manual load, you know you're pressing the key, and a gate bus 1 load is never going to illuminate for longer than a zillionth of a second without adding some stuff to slow it down. Putting it at pin 1 of U1 would give you the most useful info of all the load operations though, and that is it would tell you when the Klee was externally told to load, which is the visual info I flying-tiger kick myself daily for not putting in.
I'm thinking going straight through a resistor to the LED from pin 1 of U1 would not foul up the works. 6K8 might do it, or even 5K6, since the output at that point is somewhat lower than rail voltage. Haven't tried it, but now that you mention it, I think it would. That IC can supply enough current at that point. I say give it a whirl - I'd be very interested to know if it works (which I think it will).
Take care,
Posted: Sat Nov 29, 2008 3:30 pm Post subject:
Didn't I tell you Scott?!?
I said "If I've told you once I've told you a thousand times, why have a master gate bus LED and no external load LED? It doesn't make sense! Chewbacca,......... Endore,...... It doesn't make sense!!!!"
I did tell you that didn't I?
I'm sure I did.
Didn't I?
Maybe it was,..... ummmm,....... _________________ What makes a space ours, is what we put there, and what we do there. |
Scott Stites
Audio files: 96
Posted: Sat Nov 29, 2008 10:07 pm Post subject:
Hmmm....I remember you mentioning that the clock and gate bus 1 LED had essentially the same info; I didn't want to get rid of either because I use them both. I don't remember you mentioning anything about an external load LED, but that doesn't mean you didn't, I just don't recall it.
Cheerios,
Posted: Sat Nov 29, 2008 11:28 pm Post subject:
Of course I didn't say anything about an external load LED!  _________________ What makes a space ours, is what we put there, and what we do there. |
Scott Stites
Audio files: 96
Posted: Sun Nov 30, 2008 7:12 pm Post subject:
| Quote: | | Of course I didn't say anything about an external load LED! |
What a relief. Now I have someone to blame!
| Quote: | | You all probably think Scott is trying to be funny but he's not - everything he says about the Wichita experience is true |
It's funny because it's true.
Sound
Posted: Mon Dec 01, 2008 2:43 am Post subject:
It works!!!
Some mistakes like the clock switch ON (ON) was reversed, the bus 3 is the 1 and the one is the 3.
Scott, the External load led is working from pin 1 of U1 through 5,6K resistor. The bright is the same that the other LED.
There is an inconvenience, is that due I strap wiring the front panel with non insulated wire, there is any short when I put the front panel in the case because the wires that connect the PCB with the front panel push the strap wires and some led don't illuminate. So I will demount it looking for a solution.
After that I will keep reading step by step, the chapter 9 "electro-music Klee Sequencer Bring-Up Procedure" of "Building the electro-music Klee Sequencer" documentation as I did with the rest of the chapters.
This documentation is very complete, clear and educative, and with it, a beginner like me is achieving build a Klee.
So, T H A N K Y O U ! ! !
Folding the case, with some clamps, woods and a hammer. Aluminum 1mm thick:
The Klee:
Posted: Mon Dec 01, 2008 3:28 am Post subject:
Beautiful job there Sound.  _________________ What makes a space ours, is what we put there, and what we do there. |
Scott Stites
Audio files: 96
Posted: Tue Dec 02, 2008 9:58 am Post subject:
No kidding, that is one smart panel and wiring job! How's the cal going? _________________ My Site |
vtl5c3
Posted: Tue Dec 02, 2008 10:22 am Post subject:
Can someone point me to the post that describes the A-B/B-A mod?
| Funky40 wrote: | i'm not shure if i should make my Klee panel with an additional row of LEDs which just would show which steps are active.
Does this makes sense or do you allready have enough optical feedback when looking to the blinking lights ?
I'm not shure after looking to the Videos.
@Scott
i have drawn the A-B/B-A circuit into a little Board while waiting for the Epoxy to dry.
I assume it would be ok to post it here, is it ?
http://electro-music.com/forum/phpbb-files/pimped_klee_ab_424.png |
Scott Stites
Audio files: 96
vtl5c3
Posted: Tue Dec 02, 2008 11:50 am Post subject:
Ahh... Thank you, sir!
Looks like a good mod. Too bad my panel space is all used up already.
EdisonRex
Audio files: 172
Posted: Tue Dec 02, 2008 1:57 pm Post subject:
I finally got around to (ie I got my confidence up enough to) getting the aluminium rack panel, drilling it, putting the graphics on, and mounting the components. It looks great, but I'm not going to post a pic until I have some backside work to show.
So next up is the wiring. I'm getting together some coloured wire (all I have is black and I don't think it's going to work). Although would ribbon cable work better? I have a lot of that to use and I was thinking it might be easier to manage.
Then it's just sorting out the PSU (I have the parts but need to put it together)... I might be a lot more motivated after wiring the mess.
Who has done ribbon cable instead of hookup wire? Pros/cons? _________________ Garret: It's so retro.
Posted: Tue Dec 02, 2008 2:30 pm Post subject:
I did ribbon cable on just about everything.
I used rainbow stuff where there were different types of signals/connections on the one molex, and standard grey IDE type ribbon for the buses. You only need to know which side is which on one of those, as they are sequential. It all worked out nice and neat. Mosc used the pic on the shopfront if you want to check it out. It's in one of the threads too, but I'm not sure where. _________________ What makes a space ours, is what we put there, and what we do there. |
EdisonRex
Audio files: 172
Posted: Tue Dec 02, 2008 2:36 pm Post subject:
Hmm, thanks for that. I like the ribbon cable idea, so I'll go find your pics. _________________ Garret: It's so retro.
Posted: Tue Dec 02, 2008 2:41 pm Post subject:
| Uncle Krunkus wrote: | | but I'm not sure where. |
Lets just copy it in then
 _________________ Jan
EdisonRex
Audio files: 172
Posted: Tue Dec 02, 2008 3:13 pm Post subject:
Oh, yay! Thanks Jan. This is very helpful! _________________ Garret: It's so retro.
Sound
Posted: Wed Dec 03, 2008 4:16 pm Post subject:
| Scott Stites wrote: | | No kidding, that is one smart panel and wiring job! How's the cal going? |
Not bad, The behavior of my klee was very weird and trying to rule out reasons I tried to swap the CD4034 of its sockets and I damaged the legs of both... gorila time.
Also I detected and fixed some mistakes in the wiring: switch clock reversed, switch load reversed, Glide A potentiometer connected to AB output and vice versa, one programing potentiometer with one cable not soldered to its leg and the random led reversed.
This morning I went to a local store and they give me two Motorola MC14034, they said that is the same. Will work the Motorola fine in the Klee?
With the Motorola is working again but still is doing rare things:
The bus 1 load, responses to the bus 2 as well the bus 1! It is weird because the BUS2 = NOT 1 NOR 3...
The manual load, doesn't work well, it doesn't load always.
Well, I keep investigating, any idea will be welcome.
http://pdf1.alldatasheet.com/datasheet-pdf/view/3529/MOTOROLA/MC14034.html
http://pdf1.alldatasheet.com/datasheet-pdf/view/26866/TI/CD4034B.html |
Scott Stites
Audio files: 96
Posted: Thu Dec 04, 2008 8:52 am Post subject:
First of all, I'm surprised anyone in this world can still go to a local store and buy an MC14034!
I've never tried an MC14034, but I generally use MC1 and CD parts interchangeably with no problem. I'll peruse the datasheets to see if there's any diff, but I think if you've gotten this far with them, they're working.
Gate Bus 1 Load on Bus 2 is an odd thing. The function can surprise you because a bit that's high somewhere else on Gate Bus 1 may cause a reload when you're not expecting it. Does this ever happen if you do not have any of the gate bus switches set to gate bus 1?
Load Switch: This switch should ground out R27 (220K) which sends a pulse through R19, which is squared off by U2 (input pin 5, output pin 6). Actually, this is the "kinder" of the two momentary switches, because debouncing on it is not critical - in other words, if the CD4034s get two extremely fast pulses because of bounce, they just load the same pattern twice, which, on a human scale, is just once.
On my Klee, when I first turn it on, it has to be clocked at least once before a pattern can be loaded. This is due to the initial on state of my particular brand of CD4013 (U5). Once I've done that, it loads reliably. Is this what you're encountering, or is it deeper than that?
If so, we need to figure out if the load system is working properly. The best way to do that is to see if you can reload reliably using an external signal on the external load port. Do you have a pulse LFO you can connect to that port and see if the Klee is re-loading with each pulse? If so, clock the Klee at a fairly high rate in 16X1 mode and set the reload signal to a freq that's around half of the clock signal. The Klee should reload repeatedly and consistently before it can get through the entire pattern. It that works as expected, we can focus more on the two anomolous anomalies that are anomalating your Klee.
Sound
Posted: Thu Dec 04, 2008 11:59 am Post subject:
| Scott Stites wrote: | | First of all, I'm surprised anyone in this world can still go to a local store and buy an MC14034! |
The salesman was also surprised that one asks for this chip
| Quote: | | Gate Bus 1 Load on Bus 2 is an odd thing. The function can surprise you because a bit that's high somewhere else on Gate Bus 1 may cause a reload when you're not expecting it. Does this ever happen if you do not have any of the gate bus switches set to gate bus 1? |
Yes, all the switches in BUS3 and if I put one switch in BUS2 or BUS1 it reloads when arrives to that step. Also when the Klee is running , all the switches=BUS3, and I switch to LOAD BUS 1, all the leds turn off, and I have to manual load the pattern again. Seems that there is something that it is not well conected.
| Quote: | | Load Switch: This switch should ground out R27 (220K) which sends a pulse through R19, which is squared off by U2 (input pin 5, output pin 6). Actually, this is the "kinder" of the two momentary switches, because debouncing on it is not critical - in other words, if the CD4034s get two extremely fast pulses because of bounce, they just load the same pattern twice, which, on a human scale, is just once. |
The load switch seems that works well, only that sometimes don't. And I have to push again the switch, and then yes, it loads.
| Quote: | | On my Klee, when I first turn it on, it has to be clocked at least once before a pattern can be loaded. This is due to the initial on state of my particular brand of CD4013 (U5). Once I've done that, it loads reliably. Is this what you're encountering, or is it deeper than that? |
Mine, I don't need to clock it, just with the manual load switch the pattern is loaded. ( As I said, sometimes I have to push the load switch twice)
| Quote: | If so, we need to figure out if the load system is working properly. The best way to do that is to see if you can reload reliably using an external signal on the external load port. Do you have a pulse LFO you can connect to that port and see if the Klee is re-loading with each pulse? If so, clock the Klee at a fairly high rate in 16X1 mode and set the reload signal to a freq that's around half of the clock signal. The Klee should reload repeatedly and consistently before it can get through the entire pattern. It that works as expected, we can focus more on the two anomolous anomalies that are anomalating your Klee.
Yes the EXT load input works fine. Last edited by Sound on Thu Dec 04, 2008 12:30 pm; edited 1 time in total |
Sound
Posted: Thu Dec 04, 2008 12:23 pm Post subject:
Well,
I have tested the PCBs following step by step the chapter 8" Final Assambly of the Klee" pag91of Building the Klee. All was OK.
Due the bus 2 Is ON when the buses 1 and 3 are OFF, I thought that maybe there is a short within, Logical gate bus2 section after pin 4 of U13 to the front panel (pag 4/4 digital board schematics and pag 5/9 front panel schematics) and the Load in section, before pin10 U3 to the front panel. (pag 2/4 digital schematics and pag 3,6/9 frontpanel schematics)
I have tested all the points of these sections with each other point of the other, with the multimeter and I didn't notice any short.
After I changed all the IC involved in the Load section and the Logic gate bus 2 section.
I don't understand.... well any advice will be welcome.
Ah, I remember that I didn't do a good job when I was soldering the components, I think that I overheated all them. Maybe I damaged anyone? |
Scott Stites
Audio files: 96
Posted: Thu Dec 04, 2008 1:08 pm Post subject:
Here's a quick test I'd like you to perform:
Set the Klee to 16X1, and make it a 1 bit pattern. Set all the gate bus switches to bus 3. Observe your gate bus LEDs - only the gate bus 3 LED should flash.
If you've confirmed only gate bus 3 LED flashes, set gate bus 1 load on. Then clock the pattern and see if the load happens on a particular step or steps. If it doesn't load at all or immediately loads, let me know.
Then, set all the gate bus switches to gate bus 2 and try the same procedure, first observing if only Gate Bus 2 LED flashes, then do the gate bus 1 load switch on thing again. Again, let me know what you find out.
Of course, make sure the gate bus merge switches are not set to "merge" - if they're set to merge for a particular gate bus, the gate bus LED all of these switches are set to will stay on constantly.
D5, D6 and U1 (pins 1 and 2) of the Digital board form the logical gate bus 2 function. My thinking is, if one of these diodes is kaput, or backwards, you're going to get some weird action going on it could feed a signal back into gate bus 1 or gate bus 3.
Let me know!
Scott Stites
Audio files: 96
Posted: Thu Dec 04, 2008 1:20 pm Post subject:
D5 in particular. If that's shorted, gate bus 3 can feed back to gate bus 1. D5 blocks that from happening.
Edit: shorted or backwards, that is. _________________ My Site |
