ARP Odyssey Oscillators
Page 7 of 20 [488 Posts]
Goto page: Previous 1, 2, 3, 4, 5, 6, 7, 8, 9, ..., 18, 19, 20 Next
simmeau
PostPosted: Mon Dec 22, 2008 6:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm doing a dual of this and I just got the first one up and running today. I used an ordinary 2k in place of the tempco (probably put them in later). I did little resistor teepees in series for the odd values. Was this necessary or could I just have used closest within 5% for everything except the 121k?. It took a long time. Anyway, it sounds great. Thanks for the project Andy Very Happy
funkyfarm
PostPosted: Mon Dec 22, 2008 9:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Good news !
You mean you will put 2K tempco after ?
There is no resistor value to tweak for tracking V/OCT scale ?
It seems 1.87k tempco is about to be obsolete...
simmeau
PostPosted: Mon Dec 22, 2008 11:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Actually i haven't trimmed it yet Embarassed I will do it tomorrow and see how it goes. I don't mind the flaky so hopefully it will be OK for my bedroom noodlings.
ericcoleridge
PostPosted: Tue Dec 23, 2008 1:39 am    Post subject: Reply with quote  Mark this post and the followings unread
It seems the 1.87K Tempco Resistor can be ordered, custom, from Precision Resistor Company. This is where Ray Wilson gets his 1k and 2k Tempcos. I don't know what the price or minimum order amount is(could be 10), but, it's probably worth looking into if there's enough interest here on the forum. This 1K87 is not only used in the Oddy VCO, but also in the Arp 4023 VCF that Andy posted (and maybe the 4035 also?). Depending on price, I'd want at least 5.
etaoin
PostPosted: Tue Dec 23, 2008 1:45 am    Post subject: Reply with quote  Mark this post and the followings unread
There's also half of an idea of a group buy on the sdiy list. So don't start two...
http://www.casia.org/modular/
Broadwave
Audio files: 6
PostPosted: Tue Dec 23, 2008 2:08 am    Post subject: Reply with quote  Mark this post and the followings unread
I've recently used 2K Tempco's with no problems - there's a 100k trimmer onboard to adjust the V/Oct scaling. Just enough tolerance to allow for a 2K.
Andy.
Synth DIY Projects
Musical Doodlings
simmeau
PostPosted: Tue Dec 23, 2008 3:11 am    Post subject: Reply with quote  Mark this post and the followings unread
There's been a bit of tempco discussion on this thread and I'm a bit curious about it on a practical level. I'm not using them on my diy masterpiece thus far (mostly due to cost). If you don't have them the scaling gets stuffed up as the temperature rises, correct ? In a VCO circuit like this one does the temperature reach a peak after a certain time or does it fluctuate? So far I have waited about 15 minutes warm up time before trimming the scaling. Is this a decent strategy? It sounds ok to me but I have a dream where I show it to someone who knows things and they hear the scaling and I get slapped in the face with a calf skin glove.
Broadwave
Audio files: 6
PostPosted: Tue Dec 23, 2008 3:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, I usually let things warm up for about 30 mins before any adjustments.
It also helps if the modules are adjusted in situ i.e. in the case where they'll eventually go as heat generated from the other modules, PSU etc can be higher than the ambient room temperature that you're working in.
Andy.
Synth DIY Projects
Musical Doodlings
simmeau
PostPosted: Thu Dec 25, 2008 7:53 am    Post subject: Reply with quote  Mark this post and the followings unread
I replaced the 2k with 1.87k metal and tuned it. I got giddy when I heard the sound. I put on my duck-egg blue terry towelling bodysuit and and danced around for hours only pausing to photograph myself with my mobile phone and twitter how I was feeling with each passing second. Anyway, I will probably do another pair of these.
Broadwave
Audio files: 6
PostPosted: Fri Dec 26, 2008 2:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Ahh, welcome to my world... you can't beat a good "Priscilla" moment when something works out well LOL!
Merry Christmas & a Happy New Year to all.
Synth DIY Projects
Musical Doodlings
PostPosted: Fri Dec 26, 2008 5:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey Simmeau,
Where's the video? Shocked
I think that even rhymes! Laughing
simmeau
PostPosted: Sat Dec 27, 2008 5:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Uncle Krunkus wrote:
Hey Simmeau,
I did do video of the dancing.
I showed it to some people who's opinion I value.
They said it was an 'abomination' and followed me home in their car to make personally sure that it was destroyed for all time. Sad
I did some ody noodling which is not much but shows a little of the cool sync:
ody_sync1.mp3
ody vco with sync . 2nd osc fm'd with MFOS AR gen and CGS utility LFO. (little bit delay)
 Filename:  ody_sync1.mp3
 Filesize:  833.23 KB
 Downloaded:  922 Time(s)
funkyfarm
PostPosted: Sat Dec 27, 2008 11:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Do you etch your board from
http://electro-music.com/forum/phpbb-files/arp_odyssey_dual_vco_126.pdf
It seems it's bit out of scale, and some security stuff prevent me from openning it in photoshop...
Confused
I'm saying that, anyway, I can't have access to any schematic online...
ericcoleridge
PostPosted: Sat Dec 27, 2008 1:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
I also noticed that the PCB was slightly less than 100% scale-- but only after I etched it! I think it will be OK, however. I'm populating it anyway.
Can you confirm this Andy?
numbertalk
PostPosted: Sun Dec 28, 2008 4:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Damn I already etched mine too. Hopefully won't be too tough to kloodge the IC sockets in.
ericcoleridge
PostPosted: Sun Dec 28, 2008 5:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
I was able to squeeze mine into the layout, but it definitely appeared to be a little scaled down.
drapdap
PostPosted: Mon Dec 29, 2008 2:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Confused
That's just a password. Try some PDF-password remover, it'll work.
r.
Audio files: 297
PostPosted: Mon Dec 29, 2008 4:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Or alternatively ... when you want a "toolbox" like solution for windows without concerns about spy/add-ware ...
Install Ghostscript, install the Gimp, set the GS_PROG environment variable to point to your ghostscript exe. Then install a postscript printer, any printer will do you don't need to actually have that printer, and use that that printer to print the PDF to a file with a .ps extension, it will be a postscript file then. Next thing is to open the .ps in Gimp, and then you can do anything you like to the images.
It is a bit more work of course ...
etaoin
PostPosted: Mon Dec 29, 2008 4:28 am    Post subject: Reply with quote  Mark this post and the followings unread
However, if the pdf just needs to be scaled up or down before printing, you can just do that in the print window of acrobat reader. No need to create a new file.
Luka
PostPosted: Mon Dec 29, 2008 4:41 am    Post subject: Reply with quote  Mark this post and the followings unread
i usually print out of corel draw so i can layout a bunch of pcbs onto an a4 page. you can import pdf layouts easily and re-scale with no probs. when pcb images are out of scale i simply grab one i know is the correct scale (i usually use yusson's designs for this) and just make one transparent and stretch the poor scaled image to match the IC pin dimensions of the correct sized layout. pretty simple.
i think you can do this in inkscape too, though haven't used it for awhile
problemchild
melbourne australia
Audio files: 297
PostPosted: Mon Dec 29, 2008 4:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Just checked, it will read PDF indeed, didn't know that ... handy !!
urbanscallywag
PostPosted: Mon Dec 29, 2008 9:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Windows Office Document Writer can do this too. I don't know if it only comes with Office or if its a Windows default. Anyhow you can print the PDF to .msi then double click the file and save it as a .tif.
Broadwave
Audio files: 6
PostPosted: Tue Dec 30, 2008 7:02 am    Post subject: Reply with quote  Mark this post and the followings unread
I've not had a problem using the same PDF - Please remember not to select the Shrink (or Fit) to Page scaling option if you're using Acrobat - make sure you select page scaling as "None", as this will definitely reduce the image... maybe that's the problem?
Andy.
Synth DIY Projects
Musical Doodlings
funkyfarm
PostPosted: Tue Dec 30, 2008 8:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Do I have to buy the schematic online in order to build this module ?
ff
etaoin
PostPosted: Tue Dec 30, 2008 8:52 am    Post subject: Reply with quote  Mark this post and the followings unread
No, ARP died ages ago. Just pick one of the free ones from the Google results, like : http://manuals.fdiskc.com/flat/
