Division with remainder
Page 1 of 1 [3 Posts]
Tim Kleinert
G2 patch files: 236
PostPosted: Fri Jan 16, 2009 1:39 pm    Post subject: Division with remainder
Subject description: math function
"Division with remainder" function building block, based on audiorate counters. Eg., the calculation of "6/1" equals 6 samples calculation duration etc.
Dividend and divisor have to be positive-going numbers. A inputted logic high flank engages the calculation. A logic gate goes high when the results (quotient and remainder) are ready, stored in two S/H modules.
A divisor of zero will let the calculation hang in there for ever. (It takes a while to count out infinity Laughing). Just re-engage with a more "substantial" divisor value.
6,4% cycles count, 9,4% memory.
tim
Addendum: Since the range of the Clavia numerical system is -256 to +256 Clavia units, 256 is the highest possible result. 96000/256 equals 375, so actually you can clock the circuit constantly at 375Hz and always get reliable results. Hey, that's better than the control refresh rate of most synths. Smile
Div w Remain TK.pch2
"Division with remainder" math function.
 Filename:  Div w Remain TK.pch2
 Filesize:  1.7 KB
 Downloaded:  1870 Time(s)
Tim Kleinert
G2 patch files: 236
PostPosted: Fri Jan 16, 2009 1:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
sweeping dividend and divisor with LFOs makes funny noises.
DivRemainNoodlTK.pch2
simple "division with remainder" noodle
 Filename:  DivRemainNoodlTK.pch2
 Filesize:  1.82 KB
 Downloaded:  1820 Time(s)
Audio files: 310
PostPosted: Sun Jan 25, 2009 7:14 am    Post subject: Reply with quote  Mark this post and the followings unread
It plays nice sequences when set to a slow clock too!
