today> Various Artists March Equinox concert
today> Twyndyllyngs Chez Mosc
Pedals for the wave.
Page 1 of 1 [9 Posts]
AbjectEvolution
PostPosted: Sun Mar 08, 2009 8:38 am    Post subject: Pedals for the wave.
Subject description: Suggestions?
I just ordered a Wave from Nova. Can someone suggest some models/brands of pedals that I should get? I have never bought pedals before, so I don't know what's good. Thanks.
ark
G2 patch files: 31
PostPosted: Sun Mar 08, 2009 8:47 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm using a Yamaha FC-4 and Roland EV-5 with my Nord G2. They both work fine.
AbjectEvolution
PostPosted: Sun Mar 08, 2009 10:35 am    Post subject: Reply with quote  Mark this post and the followings unread
That Yamaha looks good. The reviews for the Roland aren't "great" on musicians friend. I'll have to look into both of them some more. Thanks for the suggestions.
AbjectEvolution
PostPosted: Sun Mar 08, 2009 7:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey... I have a question as well.
Are the mod wheel and the control pedal the same thing, or can you set separate parameters to each? If you can't make them separate, then I'm not sure if I want to even get one. I'm guessing that it would free my hand up to do other things instead of worrying about the mod wheel. I don't know.
ark
G2 patch files: 31
PostPosted: Sun Mar 08, 2009 8:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
They're separate.
The mod wheel is normally CC#1; the expression pedal is CC#11. On the Wave, you can use each of them separately as a morph source.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sun Mar 08, 2009 10:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
ark wrote:
... On the Wave, you can use each of them separately as a morph source.
When using the Wheel/Pedal Morph both use the same parameters!!! However, the ControlPedal can be set to the overall volume parameter where the Wheel will be the Morph control. See also [Manual NordWave pages 13, 18 and 66] This Manual is download able at http://www.clavia.se/main.asp?tm=Products&clpm=Nord_Wave&clnwm=Manuals
Wout
AbjectEvolution
PostPosted: Mon Mar 09, 2009 7:34 am    Post subject: Reply with quote  Mark this post and the followings unread
So I can't have both the wheel and the pedal control a separate morph source? If I chose them to both have morph control, they will control the same thing?
Thanks for the manual.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Mon Mar 09, 2009 8:05 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't own a Wave, but that's what I think the Manual tries to tell me...
Wout
AbjectEvolution
PostPosted: Mon Mar 09, 2009 6:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
I went ahead and got these. I don't get my Wave until Thursday though. Can't wait.
