Can i do partial octave shift on NL1?
Page 1 of 1 [4 Posts]
Natureboy
PostPosted: Sun Apr 05, 2009 2:42 pm    Post subject: Can i do partial octave shift on NL1? Reply with quote  Mark this post and the followings unread
Hello everyone, i'm new on this forum. Firs of all excuse me for my bad english. I have a question, i've bought and used NL1 and i would know if its possible to shift up/down only 1 octave (for example the 1st one) cause when i use octave shift up, all the 4 octaves went shift up. On the manual i didnt found if this is possible or not.
Thank you
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sun Apr 05, 2009 11:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
welcome Natureboy
I'm not at my machine right now, so I can't check it out and I may be confusing it with another synth, but...
The NordLead has a KeyboardSplit function, which is freely to be set. The split divides the keys where one part is controlling Slot A & B where the other part controls Slot C & D. Just load both 'sides' with the same Program and set one of the two in a different octave shift.
Are you using a NordRack, then the controller has to be able to make the split and you have to use different Midi channels.
Wout
Natureboy
PostPosted: Mon Apr 06, 2009 10:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Wout Blommers wrote:
welcome Natureboy
Wout
i have the keyboard version, so slot A controls 1st octave, slot B the 2st octave, C the 3rd octave and D the last octave?
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Mon Apr 06, 2009 12:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
... I'm not at my machine right now, so I can't check it out and I may be confusing it with another synth, but... ...
I hope you'll accept my apologies Embarassed!
The NordLead1 doesn't have a Keyboard Split setting; the only lead which hasn't... This is very logic as being desinged as just a 4 Slot/4 Voices synthesizer. Keyboard Split is almost impossible then...
So, my solution will not work.
Until now the answer has to read: "No, you can't shift a part of the keyboard!" (That is without an external Midi control device, like the Nord Modular G2(X))
Wout
