Natureboy
Posted: Sun Apr 05, 2009 2:42 pm Post subject:
Can i do partial octave shift on NL1? |
Hello everyone, i'm new on this forum. Firs of all excuse me for my bad english. I have a question, i've bought and used NL1 and i would know if its possible to shift up/down only 1 octave (for example the 1st one) cause when i use octave shift up, all the 4 octaves went shift up. On the manual i didnt found if this is possible or not.
Thank you |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Sun Apr 05, 2009 11:50 pm Post subject:
Natureboy
I'm not at my machine right now, so I can't check it out and I may be confusing it with another synth, but...
The NordLead has a KeyboardSplit function, which is freely to be set. The split divides the keys where one part is controlling Slot A & B where the other part controls Slot C & D. Just load both 'sides' with the same Program and set one of the two in a different octave shift.
Are you using a NordRack, then the controller has to be able to make the split and you have to use different Midi channels.
Wout |
Natureboy
Posted: Mon Apr 06, 2009 10:57 am Post subject:
| Wout Blommers wrote: | Natureboy
Wout |
i have the keyboard version, so slot A controls 1st octave, slot B the 2st octave, C the 3rd octave and D the last octave? |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Mon Apr 06, 2009 12:57 pm Post subject:
| Wout Blommers wrote: | | ... I'm not at my machine right now, so I can't check it out and I may be confusing it with another synth, but... ... | I hope you'll accept my apologies !
The NordLead1 doesn't have a Keyboard Split setting; the only lead which hasn't... This is very logic as being desinged as just a 4 Slot/4 Voices synthesizer. Keyboard Split is almost impossible then...
So, my solution will not work.
Until now the answer has to read: "No, you can't shift a part of the keyboard!" (That is without an external Midi control device, like the Nord Modular G2(X))
Wout |
