vtl5c3
Posted: Tue Mar 10, 2009 3:16 pm Post subject:
Hi FF,
In my layout, the NC socket would connect to the point just beyond the output of the MM5837 IC. If you wanted to input noise at point 'a', you probably should use something to protect the CD4016 inputs.
| funkyfarm wrote: | 266-3
But it is mentionned here or there that ou could also add a NC socket input for each circuits. Normally connected to digital noise source (more or less 11V), it allows user to feed the module with standard noise source (is there any interest ?) or wogglebug signals...
If so, any diode or resistor protection is needed ? see "a" point on this schematic :
http://www.musicsynthesizer.com/Buchla/266-3.jpg |
Dunno about this one. I've got regular sample & holds in my system already, so I hadn't thought of hacking the one in the 266. You would need to make sure that the LF398 gets a nice short pulse, if you want to separate its clock input from the other one.
| funkyfarm wrote: |
[b]266-4
SAMPLE & HOLD separate inputs
Is there any use in adding separate pulse inputs and cv inputs for both S&H circuitry ?
separate pulse just requires cutting a trace ; dual cv in requires another R65 10K resistor.
http://www.musicsynthesizer.com/Buchla/266-4.jpg |
funkyfarm
Posted: Tue Mar 10, 2009 7:42 pm Post subject:
266-3
FLUCTUATING RANDOM VOLTAGE
| vtl5c3 wrote: | | In my layout, the NC socket would connect to the point just beyond the output of the MM5837 IC. |
Cool ! I didn't see the input/output pads ; althrough they're already connected together ; soldering a bare jumper would be cool too.
So you could make a noisy triangle from any noise source ! (-/+3dB/oct outputs too...)
| vtl5c3 wrote: | | If you wanted to input noise at point 'a', you probably should use something to protect the CD4016 inputs |
Do you know what kind ? protected from negative (CMOS) and maybe from "overload" with some 47 or 100k resistor in series ?
Do you think it would it be any use for replacing those noisy triangle signals with some noise or other ? you loose the trick, no ?
266-4
SAMPLE & HOLD
| vtl5c3 wrote: |
Dunno about this one. I've got regular sample & holds in my system already, so I hadn't thought of hacking the one in the 266. |
I have two mfos S&h and it's cool to sample the same source, with different timing (clock divided by two, by four...)
I'll try to see how far you could use these circuits separately.
Thank you. |
numbertalk
Posted: Thu Mar 12, 2009 6:33 am Post subject:
vtl5c3 - is the pdf of the pcb image for the 2nd board updated with the latest fixes yet?
Thanks! |
vtl5c3
Posted: Thu Mar 12, 2009 8:40 am Post subject:
Hi! Yes. The one that's posted has the fixed traces. I haven't added pads for 10uF caps after the ferrite beads, but it will work without them.
| numbertalk wrote: | vtl5c3 - is the pdf of the pcb image for the 2nd board updated with the latest fixes yet?
Thanks! |
funkyfarm
Posted: Thu Mar 12, 2009 12:22 pm Post subject:
Subject description: RV |
| funkyfarm wrote: | | ericcoleridge wrote: |
| LetterBeacon wrote: |
Board 1 - 266_1 - Quantized Random Voltages
The first output adds up a mix of all equal quantized voltages (all 1.2V, for instance). The second output adds up a mix of different quantized voltages (for instance: 1.2V, 2.4V, 4.8V, 9.6, etc--all in related ratio)
Damn !?
So I want a 1 V/Oct QRV module  |
As those outputs (QRV SRV FRV...) are all "high range" cv signals (buchla) - ten octaves or more can be a lot for controlling 1v/o vco or quantiser - i guess attenuator would be use on cv input, therefore varying quantisation.
I'll first build it in a 1,2v way  |
numbertalk
Posted: Fri Mar 13, 2009 6:01 pm Post subject:
Thank you!
| vtl5c3 wrote: | Hi! Yes. The one that's posted has the fixed traces. I haven't added pads for 10uF caps after the ferrite beads, but it will work without them.
Thanks! |
funkyfarm
Posted: Sun Mar 15, 2009 3:06 pm Post subject:
266-2 STORED RANDOM VOLTAGE
I need your opinion to know if my SRV works or not.
I've connected the probability pot between 0 and 15V (instead of 12), and I find it cool from position 10 to 4 (distribution decrease), then distribution begins to increase upto position zero.
12v is not available on board, right ?
You've put 10v ?
schematic
Here is few sample where I slowly turn pot from cw to fully ccw (stay a few seconds in the middle position).
Without any clock signal
With input clock in
Potentiometer fully ccw with CV (lfo triangle +/-5V)
Do you hear any sweep on output 2 as you turn the potentiometer ? |
billy pilgrim
Posted: Tue Mar 24, 2009 11:13 pm Post subject:
266-1 Subject description: 4070 power connection |
Vtl3c....This is a such great project.....
I've just started to build the QRV 266-1 and I notice that on the 4070 pin 7 is tied to 10v. I would have thought it should be 0v ? Is this correct What am I missing ? |
vtl5c3
Posted: Wed Mar 25, 2009 8:54 am Post subject:
Re: 266-1 Subject description: 4070 power connection |
Hmmm.... I think I may have made a mistake. Good eye! Let me check my work. I'll update the PCB if necessary.
| billy pilgrim wrote: | Vtl3c....This is a such great project.....
vtl5c3
Posted: Wed Mar 25, 2009 12:50 pm Post subject:
OK, you were correct about the CD4070. Thanks for pointing it out. My parts placement diagram had it upside down. One of the traces was off too. I've corrected the layout and diagram and posted the changes at the beginning of this thread.
Romeo
billy pilgrim
Posted: Wed Mar 25, 2009 8:48 pm Post subject:
That's great, thanks for figuring it out.
| vtl5c3 wrote: | OK, you were correct about the CD4070. Thanks for pointing it out. My parts placement diagram had it upside down. One of the traces was off too. I've corrected the layout and diagram and posted the changes at the beginning of this thread.
Romeo
ericcoleridge
Posted: Tue Apr 07, 2009 5:29 pm Post subject:
| Anyone here tackle board 4 yet? Although it's been a while since I've looked at it, I had some problems with mine. Just wondering what other's experience has been? |
Photon
Posted: Wed Apr 08, 2009 6:32 am Post subject:
Soon! I'm etching a front panel for this today (along with the 208 URV).
What problems are you having? |
funkyfarm
Posted: Mon May 11, 2009 7:21 am Post subject:
CD4070 was upside down, ok !
But I've already etched a 266-1 board from the old layout and wonder what is meant by "One of the traces was off too." |
vtl5c3
Posted: Mon May 11, 2009 1:39 pm Post subject:
Hi FF,
I'm a little strapped for time ATM, otherwise I'd create a graphic showing the differences. If you print out the new layout and compare to the old one - just the traces under the CD4070 - you'll see what's different. Just a trace or two that needs to be cut, IIRC.
R. |
funkyfarm
Posted: Mon May 11, 2009 4:01 pm Post subject:
Thank you.
(I got it ; pin "14") |
CJ Miller
Posted: Wed May 13, 2009 3:51 am Post subject:
This project is finally getting me to try PnP. I've been scared to do it, but even if I mess up a few boards at first does me more good than daydreaming about it. I've got some 8"x10" boards so I am just trying to panel a few things together. Including these and a few 258s.
I am looking forward to making some kind of portable Buchloid performance thing, kind of like the Sili-Con Cello. If these PCBs turn out decent then I might try doing a few layouts myself. |
vtl5c3
Posted: Wed May 13, 2009 6:46 am Post subject:
| Glad to hear that you will try out the 266! PnP is not hard to figure out. The most important thing I've found is to have a clean copper board. I like to clean it with steel wool and vinegar (or dish soap) so that it gets a fine scratched/brushed texture and very clean. That seems to help the toner stick to the copper. The other tip I can pass on is to keep a close eye on the iron's temperature. If it gets too hot, the PnP plastic wrinkles and that screws it up. Also, if you really goof up when you iron the PnP to the copper, you can just scrub it off and do it over. Anyway, good luck! |
fluxmonkey
Posted: Wed May 13, 2009 7:49 am Post subject:
what he said: don't be scared of PnP, and definitely take care in the pre-cleaning of the board, that is the secret. also: if the transfer isn't perfect, you can usually touch it up w/ a Sharpie marker, which is also an etch resist.
for myself, i wouldn't try combining projects and etching one big board. i will combine designs on to one sheet of PnP, but then i cut them apart and transfer/etch one at time. it make the heat transfer process easier (the larger the board, the harder to apply even heat and pressure all over), also etching (smaller tank, less etchant).
good luck!
b _________________ www.fluxmonkey.com |
LetterBeacon
Posted: Wed May 13, 2009 9:07 am Post subject:
I've only just started etching my own boards and found it a lot easier than I thought it was going to be. I spend a lot of time cleaning the copper boards beforehand.
So out of the four boards, which ones are confirmed as 100% working? From reading through the thread it looks as though 266-1 and 266-2 have been updated and are working, has anyone completed 266-3 or 266-4?
I only ask because I have limited access to a laser printer and so I need to know that what I'm printing is going to work! |
funkyfarm
Posted: Wed May 20, 2009 2:09 pm Post subject:
I think one 457 diode is upside down around 2^n output ; P regions are connected together on schematic. |
vtl5c3
Posted: Wed May 20, 2009 2:51 pm Post subject:
>ouch!< You caught another one. Good eye!
OK, I fixed the parts placement guide at the beginning of this thread. Thanks for pointing it out. Now I need to check my actual board and see if I made the same mistake on it.
R.
| funkyfarm wrote: | Board 1 - 266_1 - Quantized Random Voltages
ericcoleridge
Posted: Wed May 20, 2009 4:14 pm Post subject:
I finished Board 3 a while back and felt everything was working well. I didn't do any specific measured testing on it, other than trying out the noise sources, cvs, controls. Seemed good. |
inform3r
Posted: Mon May 25, 2009 2:07 pm Post subject:
Wow vtl5c3! Quite an undertaking here. Thanks! I've read the thread a couple of times. I'm just getting around to plotting things out. Planning the panel, etc.... For now I'm just curious about one thing.... I know you added a couple of features here and there. You added the possibility for people to inject their own noise source via a jack for instance. Well, if I decide to keep the module without certain additions can I just leave the associated pad alone and everything will be cool? No need to jumper it or anything? Sorry, just curious and taking it slow.
Best Regards,
John |
inform3r
Posted: Mon May 25, 2009 2:35 pm Post subject:
| vtl5c3 wrote: |
Inputs:
1) CV input jack with attenuator pot. The PCB layout has extra inputs in case someone wants to add them.
2) Clock input jack.
Manual control:
1) 1 Pot
vtl, another stumper.... What is the "Manual Control Pot"? In the QRV section of the old 266 there's 2 inputs and one of them has a dedicated pot (attenuator?). Are there 2 pots in your QRV section or is the "manual control" pot the attenuator for the CV in? |
