today> Twyndyllyngs Chez Mosc
Interested in Tau Pipe Phaser / Flanger boards ?
Page 24 of 26 [640 Posts]
Goto page: Previous 1, 2, 3, ..., 22, 23, 24, 25, 26 Next
jhaible
PostPosted: Tue May 26, 2009 10:20 am    Post subject: Reply with quote  Mark this post and the followings unread
JoeMorris wrote:
Another possibly silly noob question: Are metallized film capacitors like these:
http://uk.farnell.com/jsp/search/productdetail.jsp?SKU=1669202
OK for the 40 15nf caps in the Tau?
Yes.
JH.
JoeMorris
PostPosted: Tue May 26, 2009 10:30 am    Post subject: Reply with quote  Mark this post and the followings unread
TekniK
PostPosted: Wed May 27, 2009 12:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Juergen, CV-out = output from LFO
CV in ,is that direct cv control or is it cv control of the lfo?
funkyfarm
PostPosted: Wed May 27, 2009 3:03 am    Post subject: Reply with quote  Mark this post and the followings unread
It is simple.
Just look at this : http://www.jhaible.de/tau/jh_tau_sch_page3_control.pdf
CV OUT is PITCH pot signal...
But you can have LFO OUT with the CV IN socket (no joke) Very Happy
TekniK
PostPosted: Wed May 27, 2009 3:49 am    Post subject: Reply with quote  Mark this post and the followings unread
i don't understand,what controls the vc in ?
i have to send the frontpanel designs to the manufacture but i think am wrong.
jhaible
PostPosted: Wed May 27, 2009 10:56 am    Post subject: Reply with quote  Mark this post and the followings unread
The CV out and CV in jacks are for linking two devices together.
The CV in doesn't make a good "general" CV input.
But I think I have written about this earlier in this thread.
JH.
TekniK
PostPosted: Wed May 27, 2009 12:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
JH.
Thanks ,i found the answer on page 20
Funky40 wrote:
as it is a crossfade between internal LFO and the external source.
I asssume that this behave is correct ?
Unfortunately i have not made the external CV input with an attenuator.
I would recommend this, and i will change it on one Module that anyway must be repaneled.
Yes, it's a sort of crossfade between manual setting and the internal LFO, just as in the original.
I think it makes a lot of sense that way, as all this is connected to the 1/x branch of the CV circuitry, where you get the "typical" 1/x sweep that evokes a feeling of thru-zero modulation (despite not being a thru zero modulation), only with a certain amount of modulation CV. The "CV crossfade" approach is an easy way to keep the CV level in the "interesting" range for any mix of manual and LFO sweep.
The CV input that breaks the path from the manual sweep pot to this 1/x modulation circuit, is not the recommended input for general-purose external CVs. I have copied this from the original Tau effect, too, and I think it was mainly meant for combining two effect boxes in a master-slave configuration.
For general-purpose external modulation, there is always the exponential (V/oct) input, which works independent from the internal modulation.
JH.
funkyfarm
PostPosted: Wed May 27, 2009 1:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
TekniK wrote:
JH.
I vote to avoid thread over 10 or 12 pages Very Happy
(sorry for my answer, a bit abrupt ?, the whole cv part is not "so" simple...)
and you still can use CV IN socket as an lfo output (SWEEP RANGE full ccw)
Cool
TekniK
PostPosted: Wed May 27, 2009 1:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
funky farm from france,did u know this phaser sounds same like the rsf phaser modul from the modular rsf system,,the rsf had 12 poles and it did contains an epoxyed submodule block,i had 2 of them
funkyfarm
PostPosted: Thu May 28, 2009 11:21 am    Post subject: Reply with quote  Mark this post and the followings unread
you must be lucky !
it sounds the same with 12 stages ? resonance/flanger style ?
I guess rsf is one of the most rare stuff around here Very Happy
TekniK
PostPosted: Thu May 28, 2009 11:25 am    Post subject: Reply with quote  Mark this post and the followings unread
funkyfarm wrote:
you must be lucky !
yes with only 12,but it doesn't matter this one from JH is a direct replacement
in fact on the rsf its when u set the 'flange' mode u get that deep resonance like on the JH one otherwise not
i have somewhere a demo,i will search for it,then we can try the same with those from JH (but mine are not build yet)
JoeMorris
PostPosted: Wed Jun 03, 2009 1:50 am    Post subject: Reply with quote  Mark this post and the followings unread
finished mine last night - started first time, sounding reallly cool. Thanks again Jurgen! Though it did keep me up til 5am twiddling pots leaving me absolutely knackered today. Tired but happy nonetheless. Right - on to the subtle chorus and the krautrock phaser, then better give my lungs a rest from flux fumes and my brain a sabbatical from DIY addiction for a few months before I injure myself.
Stavros
PostPosted: Tue Jul 14, 2009 9:05 am    Post subject: Tempco resistor Reply with quote  Mark this post and the followings unread
Hi Jurgen and all members of this forum.
I have a probably sily question on the Tempco resistor and in particular when this is not available to the use of a standard 560 ohm resistor.
Would it make any difference (better/worse) when using a standard 560 ohm resistor, to use instead of a normal 1/4w, one of 1 or 2 watts (2% tolerance)?
Thanks in advance for your attention
Best Regards
Stavros
jhaible
PostPosted: Tue Jul 14, 2009 10:59 am    Post subject: Re: Tempco resistor Reply with quote  Mark this post and the followings unread
Best Regards
Stavros
I would simply use an ordinary 1/4 Watt 560 Ohm resistor and never look back.
JH.
Stavros
PostPosted: Fri Jul 17, 2009 4:38 am    Post subject: trimmers setting Reply with quote  Mark this post and the followings unread
Hi JH
I have just started completing my TAU modules and I have been reading again your documentation and the forum messages exchanged so far.
There have been clarifications on the trimmers calibration/setting but unfortunately my knowledge does not help me a lot to fully comprehend the replies as other did, so I would appreciate your corrections/further clarifications to the bellow summarization of my understanding so far.
1. Pitch trimmer setting. (I guess No input signal is needed to do this, or Yes?)
First set:
a. The external “Pitch” pot to middle position (?)
b. The external “Modulation Depth (Oscil. Level)” pot to maximum (cw) position (?)
c. The external “Modulation Rate (Sweep Rate)” pot to lowest (ccw) position (?)
Then adjust the pitch trimmer for the most pleasant sweep sound.
Q. Are other external pot settings relevant? If yes what is the suggested setting?
2. Resonance trimmer setting. (Is an input signal necessary and if yes, any suggested frequency?)
First set:
a. The “Resonance” trimmer to maximum (cw).
b. The external “Resonance” pot to maximum.
c. The nice/screaming oscillation “switch” (if installed), to the “off” (nice) position.
Then reduce “Resonance” trimmer until you like it
I thank you in advance for your understanding and patience
Best Regards
Stavros
jhaible
PostPosted: Fri Jul 17, 2009 12:31 pm    Post subject: Re: trimmers setting Reply with quote  Mark this post and the followings unread
Stavros wrote:
Hi JH
First set:
First set:
Best Regards
Stavros
Really, you can't do much wrong with these trimmers.
The reange of each is so small that there is only minor adjustment.
Best start with each in mid position, apply signal, and then adjust!
JH.
TekniK
PostPosted: Fri Jul 17, 2009 1:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
I did finish with the wiring of mine today ,and this module sound like i expected to be,its wonderfull,one of the best phasers i like,sound same like the rsf phaser,i also did liked very much the moog 12 stage phaser but this goes deeper.
Thanks Juergen!
Luka
PostPosted: Sun Aug 02, 2009 1:25 am    Post subject: Reply with quote  Mark this post and the followings unread
hey jurgen
just finishing populating the tau pcb
i ran out of 620ohm resistors
would substituting with 680 be a bad decision?
problemchild
melbourne australia
jhaible
PostPosted: Sun Aug 02, 2009 5:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Luka wrote:
hey jurgen
No problem!
JH.
mph
PostPosted: Tue Oct 27, 2009 1:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello
I have finished mine ( deluxe version in a 2U rack) few weeks ago and it worked perfect at the first time.
But I am doubting about the transformer wiring to the onboard power supply.
I have wired only a pair of the transformer's output to the PCB, so one 18V and one 0V.
On the schematic it appears that the two coils of the transformer are used, but on the project decription page there is only mentioned a 18VAC voltage.
Everything is working all right on my phaser, so I'd like to know if it's necessary to wire the other coil of my transformer to the PCB.
I'd also wish to add a snubber to the main power switch... a friend told me to use a 100nF cap with a 100ohm resistor. Are these values good?
Many thanks for this project!
jhaible
PostPosted: Tue Oct 27, 2009 1:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
mph wrote:
Hello
You can run it with either one, or two secondary windings.
Only difference is less electromagnetic interference with two windings.
I'm not experienced with calculating snubber networks, I'm afraid.
Best Regards,
JH.
druish
PostPosted: Thu Nov 05, 2009 9:55 pm    Post subject: hand matched transistors Reply with quote  Mark this post and the followings unread
I'm interested in building the pipe with hand matched transistors. Would these trannys work?
http://mouser.com/Semiconductors/Transistors-FETs-Bipolars-IGBTs/Bipolar-Transistors/_/N-2xpqhZscv7?P=1z0yrkaZ1z0z60lZ1z0y4diZ1z0stflZ1z0stf4Z1z0srhw&Keyword=low+noise&FS=True
I came upon these because they are low noise if anyone was wondering.
If these are no good, does anyone have any suggestions for transistors that will work?
Thx Smile
jhaible
PostPosted: Fri Nov 06, 2009 3:18 am    Post subject: Re: hand matched transistors Reply with quote  Mark this post and the followings unread
Thx Smile
I have no doubt that they will work. Don't ask me to what degree they have to be matched - I haven't tried.
JH.
druish
PostPosted: Fri Nov 06, 2009 5:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool. I figure i'd match them as close as possible. At least to CA3086 or CA3046 specs. Wink I'll let everybody know how it works out.
jhaible
PostPosted: Fri Dec 04, 2009 4:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Tau PCBs are sold out.
www.bridechamber.com might still have some, though.
JH.
