today> Various Artists March Equinox concert
please help
Page 1 of 1 [6 Posts]
liveinrock000
PostPosted: Thu May 21, 2009 7:00 am    Post subject: please help Reply with quote  Mark this post and the followings unread
i want to circuit bend something that doesnt run on batteries, how do i avoid electricuiting myself? and does this have to do with the term "safe bend"?
Inventor
Audio files: 267
PostPosted: Thu May 21, 2009 7:06 am    Post subject: Reply with quote  Mark this post and the followings unread
1: stay away from the power supply
2: do all mods with the unit unplugged, obviously....
3. I'm not a bender but i think it's kewl
Les
Lorenzo
PostPosted: Mon May 25, 2009 12:33 pm    Post subject: Re: please help Reply with quote  Mark this post and the followings unread
Try to make it run with batteris... than you could circuit bent as usual.
From wiki: Circuit bending is the creative short-circuiting of electronic devices such as low voltage, battery-powere ... d Very Happy
Yes!
Oh Yeah!
Wow!
Lofi Ninja
PostPosted: Mon May 25, 2009 1:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Don't do any touch bends !
Stay away from power supply !
Wear eye safety glasses. If you stay away from power supply this shouldn't be a problem, but if you do mess around the power supply you can risk that electrolytic capacitors will explode = Plastic+acid in your eye...
www.youtube.com/user/lofininja
jochem
PostPosted: Wed May 27, 2009 2:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Maybe it has a power supply with transformer? Than you can replace the transformer with a battery to supply the correct voltage and include a fuse?
I'm no psu wizard,just thinking out loud Smile
Liam Semple
PostPosted: Wed Aug 19, 2009 8:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
What is the item you're trying to bend? Does it plug directly into the wall or does the elctricity pass through an adaptor/transformer first? Does it say on the item what voltage etc it uses?
This information could be handy. Goodluck.
