Can anyone suggest an LFO...?
Page 2 of 3 [75 Posts]
Coriolis
PostPosted: Sat Jun 06, 2009 12:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Tim - those waveshapers look great!
I'm wondering about the LFO itself though: Do the coarse and fine tune pots work by limiting the current going into IC1b?
If so, would it be possible to add voltage control to the lfo core by inserting an OTA acting (as a vc-resistor) before the fine tune pot?
Just thinking aloud here...
C
Coriolis
PostPosted: Sat Jun 06, 2009 12:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Gaahh! Double post...
C
PostPosted: Sat Jun 06, 2009 3:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
hello coriolis - long time no see!?
Tim Servo
PostPosted: Sat Jun 06, 2009 5:10 pm    Post subject: Can anyone suggest an LFO...? Reply with quote  Mark this post and the followings unread
C
Hey Coriolis,
Actually, that would work very nicely. If you look at things like the VCO-1 or the LM VCO, that's exactly how they do it. I have a couple of new VCOs in the works that also use that principle. Of course that's a secret, so don't tell anyone... oh wait. Anyway, it works nicely and I would probably just ditch the coarse and fine tune pots as they are, and put those controls in the standard place in the CV summer for the OTA. Of course, at that point you've got a basic, generic triangle core VCO, but those usually work well as a VCLFO (just use a bigger cap). The main thing to watch for is the voltage limits to the input of the OTA. Again, check the VCO-1 schematic or check Thomas' 3080 book for some examples.
And glad you like the waveshapers. I totally discovered those by accident (was trying to make a tri to sine shaper) but I'm very pleased with them.
Tim (loves those happy accidents) Servo
Coriolis
PostPosted: Sun Jun 07, 2009 4:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi fonik - yeah, I've been busy playing guitar and...my modular! Laughing
But of course what happens when you actually play a modular is, you find out you need more modules!
So now I'm finally building my Buchla 281 clones, some LPG's - and I really need to stop worrying and start building my Klee as well...
Precisely the ones I was thinking about. I would just build the LM VCO core and tack on your waveshapers, but figured it would be better to use your design, what with the extra +/-2.5 V on the signal and all.
I haven't been able to find a formula I can understand, to help me change the voltage swing of a schmitt-trigger from 10V p-p to 15V p-p...
But thanks for the help - now to the breadboard!
C
nicolas3141
PostPosted: Sun Jun 07, 2009 5:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
If it is an op-amp based schmitt trigger, the trigger voltages are determined by the voltage divider around the + input, relative to the output swing of the opamp. There is generally one resistor from out to +in and a resistor from +in to ground or the signal source. For example if the 1st resistor is 5k and the second resistor is 10k and the opamp output swing is +/-12V then the trigger levels will be +/-8V ... =12Vx10k/(10k+5k)
If the opamp is referenced to some voltage other than ground or its output swing is not symmetrical then the trigger voltages will be assymmetrical too. Sometimes the second resistor is replaced with back to back diodes or zeners - in which case the trigger voltages are the same as the diode voltage drop.
Nicolas
Coriolis
PostPosted: Mon Jun 08, 2009 12:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks a lot Nicholas - that helps.
Although the first thing I had in mind, was to mod the swing of the TH VCO-1, which has a discrete schmitt-trigger. I even think I understand which resistors to fiddle with, just not the ratio...
C
nicolas3141
PostPosted: Mon Jun 08, 2009 1:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah well then ... a very asymmetrical situation. Because it doesn't have a separate output driver stage you might struggle to get sufficient output swing for what you want. R20 is the positive feedback, but R13 is also involved on the positive output swings and R15 on the negative swings so to increase the trigger levels (and hence the triangle levels) you probably need to reduce all of them and probably quite a lot because you are getting close to the limits for a single stage. Then adjust R22 to bring the voltage levels back into symmetry.
Nicolas
Coriolis
PostPosted: Mon Jun 08, 2009 2:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks again Nicholas. Very Happy
Will try your suggestions if I decide to use the VCO-1 as basis...
C
creekree
PostPosted: Sat Jun 27, 2009 6:50 am    Post subject: Reply with quote  Mark this post and the followings unread
i perfboarded nicolas' simple LFO last night - got it up and running within an hour or so and i have to say that i quite like it! (i made it entirely out of used components that i desoldered from my pile of electronic junk)
the skew function is a nice touch...
when i find the time i'll tinker with different LEDs and/or caps.
thanks nicolas!
lostinpurdy
PostPosted: Wed Nov 04, 2009 1:40 pm    Post subject:   Reply with quote  Mark this post and the followings unread
The 8K LFO - can this be made switchable to VCO or Attack/Release mode? I assume that I should be able to get it into VCO range by replacing the resistor that sets the initial frequency, right?
Tim Servo
PostPosted: Wed Nov 04, 2009 2:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey Lost,
Well, you can change the timing cap (C1) to change the range of the 8K, but it won't be a Voltage Controlled Oscillator - just an oscillator with manual control over the frequency. Still, those can be useful for drones and stuff like that. The waveshapers I show definitely sound neat in the audio range. Make the cap smaller (try something around 330pF) to make the frequency higher.
As far as an Attack/Release mode, I guess you could do that by removing the feedback from the integrator (IC1b) to the comparator (IC1a). Take out R6, and put a gate signal through a resistor (try 100k) to the + input of IC1a. The output will be inverted, so you'll want to invert the gate first to get a 'normal' envelope out. Additionally, you could use a couple of diodes to have separate Attack and Decay rate controls. Check out some other AD envelope generator designs to get a better idea of how this works.
Tim (Voltage Controlled Nerd) Servo
lostinpurdy
PostPosted: Wed Nov 04, 2009 7:53 pm    Post subject:   Reply with quote  Mark this post and the followings unread
thanks - (I think) it should be CV controllable if I add a CV stage followed by a simple inverter and a switch to bypass the frequency pot? I really don't care much for correct key-to-key CV tracking since I intend to control that from a baby 10 type sequencer. I'm aiming to build a small modular synth with the simplest possible circuits available. It would implement three modulators which I call "VCHLFO/AR's" or "UVCM/O's" (pick one), which can be switched to VCO, LFO, AR modes. It's kind of a space saving measure to avoid having to build extra AR's and LFO's, kind of multi-function modulators, which Could also make a nice module for modulars.. at least that's what my wicked mind just cooked up Very Happy
Ojd
PostPosted: Mon May 10, 2010 5:26 am    Post subject: Reply with quote  Mark this post and the followings unread
I've made your LFO, nicolas. To get +/-6V had to put 3 LEDs in series though. Also made capacitor switch - 4,4 uF (two of 2,2uF back to back), and 10nF. From 10 second to 1000hz, not bad at all! By the way, i've changed 100k rate pot to 500k pot. I think Audio taper would give me better lower range.
You know, i didn't think i would start DIYing modular again (first time i had less experience took much complicated circuits, and failed). But with your modules its sooo easy. Especially i liked the tweaking part, it really puts a part of you into what you're doing. Waiting for more modules!
nicolas3141
PostPosted: Mon May 10, 2010 1:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Brilliant. I always encourage everyone to build simple circuits and on stripboard, because I think the fun is in understanding how they work and then adapting and extending them.
Nicolas
emdot_ambient
PostPosted: Mon May 10, 2010 2:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for reviving this old thread...would have missed it otherwise thumb up
nicolas3141
PostPosted: Mon May 17, 2010 3:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's a simple LFO I have just built (x2). Only two opamps, but with the skew control I like so much. Reduce R1 to something smaller (not less than 10k tho) if you want the LEDs to shine a bit brighter.
Nicolas
 Filesize:  52.62 KB
 Viewed:  27954 Time(s)
2thick4uni
PostPosted: Mon May 17, 2010 2:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Brilliant Nicolas, I have been following your posts with great interest. I can't believe you can get a sawtooth thru to tri LFO with such a low component count!
Is there any way this circuit could be made to work on a single rail psu, ideally +9v? I'd guess I'd need a lower voltage opamp and a virtual ground, however I'm not clever enough with circuit design yet to implement it - any suggestions or hints?
nicolas3141
PostPosted: Tue May 18, 2010 12:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Running this little one off a single 9V battery is actually harder than the others because it needs to sink/source up to a milliamp from ground. On the other hand the first LFO I posted will run fine, just use yellow/green LEDs rather than blue. Increase R4 from 22K to 47K. Connect the 9V battery + to pin 4 of the LM324, battery - to pin 11. Connect the ground (0V) of the circuit to a voltage divider 10K to battery + and 10K to battery -. And augment the 100nF power smoothing caps with 10uF electrolytics in parallel with the little ceramics. Does that make sense?
Nicolas
2thick4uni
PostPosted: Tue May 18, 2010 10:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Nicolas
Excellent, many thanks!
I can understand all of the the changes, the 2 of 10k resistor pd puts the "ground" at 4.5V, hence the term virtual ground?.
I've just checked the LM324 datasheet and it will work on 3v to 32v so I don't even need a more expensive opamp Smile
I'll build it on stripboard at the weekend.
Allan
Ojd
PostPosted: Sun Jul 04, 2010 2:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Is there any way to make D3 and D4 shine brighter? Each is in series with 2 more LEDs, so its quite a drop in brightness
nicolas3141
PostPosted: Sun Jul 04, 2010 3:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
The brightness of the LEDs is set by R4 (shown as 22k). Reduce this to 2k or 3k or 4k to get them bright for daytime use. Will run your batteries down quicker though.
Nicolas
Ojd
PostPosted: Mon Jul 05, 2010 1:19 am    Post subject: Reply with quote  Mark this post and the followings unread
No worries, i use 15 volt bipolar supply.
Ojd
PostPosted: Thu Aug 05, 2010 12:02 am    Post subject: Reply with quote  Mark this post and the followings unread
I use linear 500K pot for speed, with little resistor at node 1, to give it some speed even at lowest position (without this resistor if you turn pot CCW it seemed like LFO gets frozen, i mean cycle time would be so long that it was annoying). Nice toy you made, nicolas!
oozitron
PostPosted: Mon Feb 07, 2011 8:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
I am stumped by my LFO... the chip is getting it's +15 and -15 volts. But both LEDs stay lit, and the output is a slight amount of negative voltage.
It's just the plain LFO (no freq CV) with just the two pots. Neither pot changes the output.
Are there specific voltages I should be seeing on the various pins of the chip?
I've tried swapping chips and the 1u cap to no avail. I'm no EE genius, but this is such a simple circuit Rolling Eyes
Drew
