filtr0
Joined: Jun 12, 2009 Posts: 1 Location: Buenos Aires, Argentina
Posted: Fri Jun 12, 2009 4:03 pm Post subject:
NG2 modular bug, noise with reverb/delays and polyphonia Subject description: very loud white noise coming from some patches |
OS synth > original one, i havent updated it
OS in PC > windows xp pro
OS editor > version 1.40
description of the problem
im getting a very loud noise when i use some patches, usually the white noise is caused by the combination of either a reverb and delay, or sometimes when the patch is in polyphonic mode. the noise stops usually when i either turn both the delay and reverb or when i turn off the polyphonic mode
example patch
i cannot reall upload one, because these even happens in some of the factory presets of the ng2 patch bank. it also happens on some other patches i downloaded.
im trying right to update the usb driver and synth os, hopefully its not a hardware problem...
please if someone knows about this or anything similar please contact me |
Joined: Apr 03, 2004 Posts: 24506 Location: The Netherlands, Enschede
Posted: Sun Jun 14, 2009 6:26 pm Post subject:
Hmm .. still an example patch might be helpful here ... it could be a bug, or something odly patched ... hardly imaginable that it would be hardware problem with the synth. _________________ Jan
Chrono
Audio files: 37
G2 patch files: 38
Posted: Tue Jun 23, 2009 6:39 am Post subject:
i have the same, i believe its the input wich is too loud. the verber clips or something. Not really sure tough. You can also hear noise if you use a lowpass filter before a custom chorus on low cutoff frequencies.
I solved a little of that by using a custom chorus in the polyfonic section right after the osc's and route the rest in stereo. wich costs double filters but then there is no noise in the lower frequencies. |
jksuperstar
G2 patch files: 18
Posted: Tue Jun 23, 2009 8:37 am Post subject:
| I'm with Jan, there must be some example patch by now? If anyone needs help using the "Add Attachment" button below text editing window, let us know. |
Chrono
Audio files: 37
G2 patch files: 38
Posted: Fri Jun 26, 2009 9:45 am Post subject:
Ive made some examples hope you can help with the issues.
Just use the filter cutoff in the noizy patch, and the Level Add with the Filter After patch.
i will try make a faulty reverb one as well, the thing i noticed with that , is that the Reverb has a random input overload or something. I dont know what it couses.
| Description: |
| This fragment has the unwanted noise comming from the quad delay in the patch. |
 Download (listen) |
| Filename: |
ChorusFilterError.mp3 |
| Filesize: |
445.84 KB |
| Downloaded: |
1537 Time(s) |
| Description: |
| This one has the Filter after the QuadDelay in Stereo and you can hear the difference , but still some distortion is noticable on the lowest frequencies. |
 Download (listen) |
| Filename: |
ChorusFilterAfter.mp3 |
| Filesize: |
276.86 KB |
| Downloaded: |
1537 Time(s) |
| Description: |
 Download (listen) |
| Filename: |
ChorusLoFilter.pch2 |
| Filesize: |
1.59 KB |
| Downloaded: |
2222 Time(s) |
| Description: |
 Download (listen) |
| Filename: |
ChorusLoFilterAfter.pch2 |
| Filesize: |
1.86 KB |
| Downloaded: |
2250 Time(s) |
varice
Audio files: 29
G2 patch files: 54
Posted: Sat Jun 27, 2009 3:25 pm Post subject:
mixer level is too high |
Chrono,
Looks like you have the patch level mixed too high which is causing clipping distortion on the main audio output bus. Try reducing the Master level of the stereo mixer module until there is no more distortion. Keep in mind that the output level meter in the VA section only shows the signal level of one voice, not the sum of all voices in a polyphonic patch.
Also, I have noticed that is very easy to overload the Reverb module. I usually just reduce the signal level on the module input to prevent clipping distortion. _________________ varice |
Chrono
Audio files: 37
G2 patch files: 38
Posted: Sun Jun 28, 2009 5:19 am Post subject:
thanks i will try fix it  |
Chrono
Audio files: 37
G2 patch files: 38
Posted: Wed Aug 05, 2009 6:29 am Post subject:
i've been balancing a lot with the volume clipping issue. It seems it needs a very subtle configuration on both nord and soundcard input. Also, a maximizer in cubase can fix unwanted clipping even tough it seems its not distorting through the cubase mixer at all.
cheers |
stiiiiiiive
Joined: Sep 21, 2006 Posts: 24 Location: Paris - Versailles, France
G2 patch files: 4
stiiiiiiive
G2 patch files: 4
Tim Kleinert
G2 patch files: 236
Posted: Wed Nov 09, 2011 1:00 pm Post subject:
Could also be a faulty RAM chip. Each DSP has its own RAM chip for delay-based stuff. You don't always notice something wrong - only when the patch that is allocated to the DSP with a faulty RAM chip uses some kind of delay-based thing (comb filter, delay, chorus, reverb etc.).
One way to test this is to create a performance and open up a 2.7 delay module in each VA and FX slot (total of 4 or 8 delays, depending on if your G2 is expanded or not), input some audio into each of them (eg. a simple sine oscillator) and listen to each output individually. If only one of the delay modules outputs crackles, then that is a sure sign of a defective RAM chip.
I had this problem once with a G2X i bought off eBay. Pitch stick was broken too.  |
stiiiiiiive
G2 patch files: 4
Posted: Wed Nov 09, 2011 1:06 pm Post subject:
Thanks Tim, I'll try this.
What did you do about this broken G2X? _________________ Folie à 6
Lawx and Mowk
Tim Kleinert
G2 patch files: 236
Posted: Wed Nov 09, 2011 2:17 pm Post subject:
| stiiiiiiive wrote: | | What did you do about this broken G2X? |
The defective RAM chip was on the expansion board. I bought a new one from Encore Electronics and swapped it. Tony from Encore Electronics however asked me if he could have a shot at repairing the defective expansion board. I sent it to him and he was indeed able to fix it. He sold it afterwards and gave me a share, which was very nice of him.
The pitch stick issue was just a loose solder joint.
So I eventually had four G2Xs all hooked up simultaneously in the studio. Those were the days...  |
iPassenger
Joined: Jan 27, 2007 Posts: 1070 Location: Sheffield, UK
G2 patch files: 78
Posted: Fri Nov 11, 2011 2:06 am Post subject:
| tim wrote: | Could also be a faulty RAM chip. Each DSP has its own RAM chip for delay-based stuff. You don't always notice something wrong - only when the patch that is allocated to the DSP with a faulty RAM chip uses some kind of delay-based thing (comb filter, delay, chorus, reverb etc.).
I have on rare occasions had similar issues and have a niggling feeling I might have the same problem.. Random noise issues with delays.
Got to test this out. _________________ iP (Ross)
Tim Kleinert
G2 patch files: 236
Posted: Fri Nov 11, 2011 4:14 am Post subject:
| Could also be this, although this phenomenon tend to be more subtle. The demo mp3 by the OP definetely sounds more nasty and has that typical cyclical thing going that makes me think it might be a defective RAM. My defective RAM chip produced hideous noise, but only when audio was being inputted, otherwise dead silent. |
iPassenger
G2 patch files: 78
Posted: Fri Nov 11, 2011 5:04 am Post subject:
| tim wrote: | | Could also be this, although this phenomenon tend to be more subtle. The demo mp3 by the OP definetely sounds more nasty and has that typical cyclical thing going that makes me think it might be a defective RAM. My defective RAM chip produced hideous noise, but only when audio was being inputted, otherwise dead silent. |
Ahh yeah it could be, seem to remember I tested it with no audio in, so could well be that then.. I'll do your test above and see what it does anyway. _________________ iP (Ross)
