phiol
Audio files: 9
Posted: Wed Jul 01, 2009 3:22 pm Post subject:
nord rack 2 freeze |
Hi all
Just wondering if this is something that ever happens to any of you. I am on the rack 2 and I use MaxMSP to drive two (P0-9) slots and 1 synth slot.
And I have some notes being triggered as fast as 5 ms . And when I used
the echo option of LFO 2 bang!, my rack totally froze.
Yes , I know a lot of note on&off's are being sent per time, but this has happened to me twice now. The freeze thing where I have to restart my rack.
It's always when tweaking it while a lot of midi messages are being sent.
The reason I ask is I'm starting to doubt using it live. But that's why started switching to hardware in the 1st place.
Oh boy, the saga continues.....
thanks
phiol |
Joined: Apr 03, 2004 Posts: 24468 Location: The Netherlands, Enschede
Audio files: 297
Posted: Wed Jul 01, 2009 3:55 pm Post subject:
It's possible to freeze the NM G2 as well by overdoing the MIDI .. especially with internal MIDI ... so what I do is I try to limit the MIDI rates, not just take an LFO and send out every detected change on it's output, but put a sample and hold after it that is clocked from some lower rate and use that to generate the MIDI from. _________________ Jan
phiol
Audio files: 9
Posted: Wed Jul 01, 2009 10:18 pm Post subject:
thanks for the tips
Not quite certain i understand, but here is what I get.
Use the LFO rate for fast triggering instead of notes on and note off @ 5ms.
** But the sequenced beats that come out are so tasty **
Is that what you meant ??
You mean in the nord right? Just making sure.
You mean it gets grumpy if you ask to much from it?
Then she decides to let these crazy sounDS!! then she overreacts and does want to play anymore
thanks
phil |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Thu Jul 02, 2009 12:27 am Post subject:
phiol wrote: | thanks for the tips
Not quite certain i understand, but here is what I get. | Well, reading this post further your interpretation is very nice  Quote: | Use the LFO rate for fast triggering instead of notes on and note off @ 5ms.
** But the sequenced beats that come out are so tasty ** | EXTREMIST Quote: | Is that what you meant ?? | Not exactly, I think, but it isn't my line...  Quote: | >>especially with internal MIDI
Then she decides to let these crazy sounDS!! then she overreacts and does want to play anymore  | Indeed, the NordLead is a lady, a special one All Nord gear tend to be oversensitive to a lot of Midi data. The Nordlead3 crashes for sure if it receives during booting a normal Midi stream, like a MidiClock signal. Jan is referring to the internal Midi in the G2, because in that synth you can use Midi data being processed in a Modular way and can be send from one Slot to another, very sophisticated! But also a bit sensitive...
Anyway, using a rack version it means all controlling has to go through that one and only MidiIn port: maybe a very fast running MidiNote signal and some CC data at the same time. Even your mother would be a little confused, I think And you know, women can do two things at the same time...
At the moment I think a lot of readers on this forum would love to hear some of your songs using the speed-of-light sound by now
And I am a lot of readers...
Here are two of mine I made recently as an illustration to the effect.
The first one is a-tonal, using the RingModulator and controlled by the Wheel (AmpAttack morphed to create a fixed range), the Arp Range and at the end the RingMod tuning going down.
The second one is pure tonal, I think, and illustrates the gritty quality of the technique.
Wout
Description: |
 Download (listen) |
Filename: |
Granular_Etude_01.mp3 |
Filesize: |
989.34 KB |
Downloaded: |
1136 Time(s) |
Description: |
 Download (listen) |
Filename: |
Frere_Jaques.mp3 |
Filesize: |
247.66 KB |
Downloaded: |
1100 Time(s) |
phiol
Audio files: 9
phiol
Audio files: 9
phiol
Audio files: 9
Posted: Thu Jul 02, 2009 11:57 pm Post subject:
What does this mean ,
Sorry, you have reached your maximum Upload Quota Limit of 20 MB
for how long ???
in the extension it says max of 200. it's been almost 3 hours. it's 3 am . i call it a day .
I got a few more that show interest pseudo granular stuff.
here is the note that will go w. the one calles "ping"
(This one is too long for a demonstration but what is really interesting is that is displays what can be done w. just one is single sound.
If bear w. it, 3/4 into it , you can hear a snare like function done w. LFO 1. <- I mean add other layers 2 this point , re-edit the whole thing to avoid redundancy andyou've got yourself something interesthing. We @ least i think )) |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Fri Jul 03, 2009 1:37 am Post subject:
phiol wrote: | Holly bloody hell !!
This has been a nightmare. ...
... THIS HAPPENED TWICE!!! | Phil, my dear Phil! Was there really somebody on the day you were born that ever told you: "Hear this: life is easy!" Quote: | ... They were all done in realtime w. no editing. | So are mine  Quote: | Wout Blommers wrote: | At the moment I think a lot of readers on this forum would love to hear some of your songs using the speed-of-light sound by now
And I am a lot of readers... |
Thanks for the "show us the size of your ......" Wout LOL!!!  | Uhh... Enlighten me in PM, please
Wout |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Fri Jul 03, 2009 1:56 am Post subject:
phiol wrote: | ... in the extension it says max of 200. it's been almost 3 hours. ... | A site administrator has to grant you that. Jan probably will, so I'm asking him now... Quote: | ... here is the note that will go w. the one calles "ping"
If bear w. it, 3/4 into it , you can hear a snare like function done w. LFO 1. <- I mean add other layers 2 this point , re-edit the whole thing to avoid redundancy andyou've got yourself something interesthing. We @ least i think )) | I didn't found 'Ping' yet.
BTW 'Kee eprom' is here only 64.4 kB large. Do I miss something? Downloaded it three times now.
(There was nobody except my mom with me the day I was born and she has something else to do, so live isn't easy
Wout |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Fri Jul 03, 2009 1:59 am Post subject:
What I surely hear: the brightness and livelyness in the sounds, special when they are a little bit longer. It is the same as Frequerncy Modulation. I think it's because one adds something to the sound instead of substractin it by filtering.
Wout |
Audio files: 297
Posted: Fri Jul 03, 2009 3:14 am Post subject:
phiol wrote: | What does this mean ,
for how long ??? |
until someone ups your quota, which I just did.
Anyway, there is a limited amount of data that forum members are allowed to store on the server, for new members the limit is 20 MB and it will be upped (usually) on request ... ask mosc or me, or post a remark in a forum thread, usually I'll see it (and if not, Wout will tell me ) _________________ Jan
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Fri Jul 03, 2009 3:17 am Post subject:
Blue Hell wrote: | until someone ups your quota, which I just did. ... | Well, it costs you beer for Jan and me, of course. Where to can we send the bill?
Wout |
phiol
Audio files: 9
Posted: Fri Jul 03, 2009 7:30 am Post subject:
Eh boys thanks for upping the space.
Quote: | Well, it costs you beer for Jan and me, of course. Where to can we send the bill? Wink |
Wait a minute , you want to here the stuff , but I pay the beer LOL!
Quote: | Phil, my dear Phil! Was there really somebody on the day you were born that ever told you: "Hear this: life is easy!" |
Sure it is, I believe it's a choice of how you choose to live it
This was just 3 am to much computer screen for one day baby burpin' cartoon style exaggeration!
To to add to the 1st part. After teaching for 14 years , the most coming human behavior I think we could agree on is either laziness OR short attention/concentration/focus <- which cause bluriness and confusion which cause laziness and finally which result in abandonment.
One has to have patience , and a lot of passion to fuel this patience, to keep at something.
But we have to agree that what make the meaning of this last phrase easier is when the "boring" technical details go fast. <-less branches to have our coats stuck in.
LOL! I just open doors for a lot of teasing w. the last paragraph
Quote: | Uhh... Enlighten me in PM, please Shocked |
LOLOLOL!!
Unless you really want me to PM, i just having a laugh.
here are few more clips
for "ping" This one is too long for a demonstration but what is really interesting is that is displays what can be done w. just one is single sound.
If bear w. it, 3/4 into it , you can hear a snare like function done w. LFO 1. <- I mean add other layers 2 this point , re-edit the whole thing to avoid redundancy andyou've got yourself something interesthing. We @ least i think Wink
phil
Description: |
 Download (listen) |
Filename: |
_ping_.mp3 |
Filesize: |
10.37 MB |
Downloaded: |
628 Time(s) |
Description: |
 Download (listen) |
Filename: |
Keeeprom.mp3 |
Filesize: |
6.2 MB |
Downloaded: |
665 Time(s) |
Description: |
 Download (listen) |
Filename: |
nordjam 4.mp3 |
Filesize: |
16.28 MB |
Downloaded: |
688 Time(s) |
Audio files: 297
Posted: Fri Jul 03, 2009 7:44 am Post subject:
phiol wrote: | Wait a minute , you want to here the stuff , but I pay the beer LOL! |
Hmm .. you could steal it too But being put that way it seems a bit odd indeed.
phiol
Audio files: 9
Posted: Fri Jul 03, 2009 7:58 am Post subject:
here you go 2 stolen beers!!
beer
I have a question Blue Hell, How come I never ever receive update message in my hotmail. @ 1st , when I started on this forum, it worked fine. I never changed anything in my hotmail or in my account here preferences.
Is this normal ??
thanks
phil |
phiol
Audio files: 9
Posted: Fri Jul 03, 2009 8:00 am Post subject:
also, I tried copy pasting your beer emoticons but as I look now it only wrote "beer".
Were can I grab these cool ones?
phiol |
Audio files: 297
Posted: Fri Jul 03, 2009 9:50 am Post subject:
@phil : the email notification doesn't work too well, it's a constant source of entertainment
@phiol : when you compose a message there are emos at the left, but under it is a link "view more emoticons" ... the beer emoticon is just written as [:]beer[:] without the brackets btw.
@both, is one of the names a typo  _________________ Jan
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Fri Jul 03, 2009 10:43 am Post subject:
Blue Hell wrote: | ... @both, is one of the names a typo  | I think not, but maybe a very worst case of a splitt personality?
Tuow
(reversed personality) |
phiol
Audio files: 9
Posted: Fri Jul 03, 2009 10:47 am Post subject:
Definitively a split personality if your talking about the
phiol
phil
thing .
Who is he anyways...
phiol |
phiol
Audio files: 9
Posted: Fri Jul 03, 2009 10:54 am Post subject:
bubblings w. Adio 6
fast trigger on note on/off's
ooops, for some reason I can,t post this attachment. I 'll try again later.
phiol |
Audio files: 297
Posted: Fri Jul 03, 2009 11:08 am Post subject:
phiol wrote: | ooops, for some reason I can,t post this attachment. I 'll try again later. |
oh oh ... I better up you again  _________________ Jan
Wout Blommers
Audio files: 123
G2 patch files: 12
I can't upload 'Ping" (only 66.2 kB)
Maybe...
(If you do, delete the first one)
Wout |
Audio files: 297
Posted: Fri Jul 03, 2009 11:10 am Post subject:
Hmm .. its really up time I guess .. I upped you too Wout. _________________ Jan
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Fri Jul 03, 2009 11:52 am Post subject:
Blue Hell wrote: | Hmm .. its really up time I guess .. I upped you too Wout. | It's a download problem at my side, not upload...
Anyway, still nothing...
Wout |
Audio files: 297
Posted: Fri Jul 03, 2009 1:09 pm Post subject:
Wout Blommers wrote: | It's a download problem at my side, not upload... |
ok ... but your next upload would have failed too
Let me check on the DL .. _________________ Jan
