Buchla 111 Ring Mod Layout
Page 1 of 2 [42 Posts]
vtl5c3
PostPosted: Sat Jul 11, 2009 5:57 pm    Post subject: Buchla 111 Ring Mod Layout Reply with quote  Mark this post and the followings unread
OK, Kiddies! Here's another Buchla pcb layout for you to play with. This time it's the 100 series ring mod, based off the schematics on the interweb (sorry can't find the link ATM)....
THis one is untested by me, but the layout matches the schematic 100%. I triple checked before I posted it.
I have a board etched and partially stuffed, but a low back injury has me momentarily immobilized. I will try to complete it as soon as I recover.
Anyway, happy summer!
Romeo
Buchla111_PCB.pdf
Updated PCB Layout and Parts placement diagram. 7/31/09
 Filename:  Buchla111_PCB.pdf
 Filesize:  363.39 KB
 Downloaded:  2456 Time(s)
Funky40
G2 patch files: 5
PostPosted: Sat Jul 11, 2009 6:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
wow, thanks alot !
And i wish you good recovery
ff
ericcoleridge
PostPosted: Sat Jul 11, 2009 7:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
The schematic was here. The page is not opening for me at the moment Sad
Maybe he's up-loading some more schematics onto the site Very Happy
vtl5c3
PostPosted: Sun Jul 12, 2009 10:20 am    Post subject: ¡esquimatico? Reply with quote  Mark this post and the followings unread
Here's the one I got off the interweb. And now it's time for bacon!
 Filesize:  371.52 KB
 Viewed:  2040 Time(s)
vtl5c3
PostPosted: Thu Jul 23, 2009 10:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Quick update: I soldered most of the components to my PCB last night. I'm waiting for mouser to send me a replacement trimmer, since they sent me a broken one. I hope to be able to test it by the end of next week.
R.
ericcoleridge
PostPosted: Thu Jul 23, 2009 12:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is in my que. Thanks again for posting.
I drew layouts for the 106 mixer and 170 Preamp, for practice, and because they were easy. I need to re-do them on graph paper or some program. What do you use for your layouts (like this 111)?
vtl5c3
PostPosted: Thu Jul 23, 2009 1:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
I usually start in Photoshop 5.5, using the line tool. I then finish up in Photoshop CS2. Not an ideal workflow, but I learned it when that was the best I had to work with. I'd like to learn Eagle or some other PCB layout program, but you know how that goes....
ericcoleridge
PostPosted: Thu Jul 23, 2009 2:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, I'd almost rather use Eagle and/or some other free layout program; least that way I'd have a better chance of getting the spacing correct. But I don't have enough memory left on my ancient abacus to download them! Very frustrating. Fortunately, I have Illustrator and Photoshop already installed; I'll give it another try. I want to ultimately tackle the 140 and 180, then possibly the 295... Very Happy
vtl5c3
PostPosted: Fri Jul 24, 2009 8:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Hold off on the 180, since I already have a layout for that. I'll clean it up and post it before long.
Fernando
PostPosted: Mon Jul 27, 2009 9:00 am    Post subject: Reply with quote  Mark this post and the followings unread
nice and inspiring Romeo! as usual
any sound yet?
it is a discrete four quadrant multiplier?
vtl5c3
PostPosted: Mon Jul 27, 2009 9:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Fernando,
It's all soldered and wired to a front panel. I'm just waiting for a replacement trimpot from Mouser. I hope to have it running by the weekend, providing that there aren't errors in the schematics. As far as I can tell, it is a four quadrant multiplier.
any sound yet?
vtl5c3
PostPosted: Thu Jul 30, 2009 10:03 pm    Post subject: Progress Reply with quote  Mark this post and the followings unread
So I've been testing it since last night. Last night it was completely not working. I'm using the new Kobicon 1/8" jacks from mouser and wired everything up incorrectly, because they changed the pinout. On top of that, they are flimsy. I will have to find better jacks.
Tonight I made another attempt, this time with the jacks wired correctly. The signal is getting all the way to the bases of the output transistors (Q9 & 10), but not any further. My guess is that R39 & 40 need to be changed since I subbed 2N3906s for the PNPs in the original circuit. They are probably not getting turned on enough to pass the signal through. I will experiment further in the next few days and let you know how it goes.
R.
vtl5c3
PostPosted: Fri Jul 31, 2009 10:09 am    Post subject: Reply with quote  Mark this post and the followings unread
I think I found the problem. The CBS/Buchla Schematic has an error in it. R38, the 47Ω resistor that goes from Q8's collector to Q10 and the top matched pairs should actually connect to V+. Luckily I have two other versions of this schematic that don't have this error. I'll update the PCB layout ASAP.
R.
vtl5c3
PostPosted: Fri Jul 31, 2009 6:28 pm    Post subject: Success! Reply with quote  Mark this post and the followings unread
Quick update: I modified the the 47 ohm resistor as mentioned in my last post. Now it works like a charm! I've updated the PCB layout at the beginning of this thread. In my version I used MAT02s for the matched pairs, but it's quite likely that any matched NPN pairs will work.
To my ears it sounds like most other ring modulators, but I'll give it more of a workout this weekend to see if it has any unique characteristics.
Fix to CBS schematic
 Filesize:  73.14 KB
 Viewed:  53807 Time(s)
LektroiD
PostPosted: Sun Dec 19, 2010 8:20 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm thinking of building a couple of these but the matched transistors are prohibitively expensive (if available). The diagram posted suggests you can match your own, however the originals are dual monolithic transistors, and by the looks of things these are rather complex designs:
Monolithic Transistor Circuit
A semiconductor body of collector material has a first and second base region diffused into the collector material, and a first and second emitter region diffused into the base regions. A narrow channel of base material connects the two base regions. A metallic coating connects the first emitter region with the second base region. This metallic coating extends over the connecting channel and is situated directly on the surface of the semiconductor body. The first emitter region may be extended into the second base region directly under the metal coating which connects the first emitter with the second base.
With the above in mind, I have a feeling this can not be replicated with a straight matched pair. Has anyone tried matched 2n3904's in this board?
LektroiD
vtl5c3
PostPosted: Sun Dec 19, 2010 9:42 am    Post subject: Reply with quote  Mark this post and the followings unread
My 2 cents: try it!
I'd be surprised if the design didn't work with hand-matched transistors. There's plenty of trimmers to compensate for mismatches.
tokyomatik
Audio files: 6
PostPosted: Thu Feb 23, 2012 10:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
anybody verified if this layout works?
vtl5c3
PostPosted: Fri Feb 24, 2012 8:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Worked for me.
tokyomatik
Audio files: 6
PostPosted: Fri Feb 24, 2012 12:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
is it possible to make it work also at +12v ?
tokyomatik
Audio files: 6
PostPosted: Fri Feb 24, 2012 12:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
....ehm....and would be possible to listen some samples? Razz
ericcoleridge
PostPosted: Fri Feb 24, 2012 7:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
ehem, he said it sounded like a typical ring modulator. No one else has built this, you'll have to try 12v yourself and see. I'm guessing it will work.
vtl5c3
PostPosted: Mon Feb 27, 2012 10:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
I was playing it tonight. It's very old school sounding... similar to the CGS ARRM, maybe.... I'll post some mp3s to demonstrate.
LektroiD
PostPosted: Mon Feb 27, 2012 10:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm stuck looking for 5.6µF tantalums.. I'm thinking of using 6.8µF tants in their place.
Also I'm using 2n3904/2n3906 throughout.. I'll report back once I have it finished
vtl5c3
PostPosted: Tue Feb 28, 2012 8:57 pm    Post subject: audio sample Reply with quote  Mark this post and the followings unread
LektroiD
PostPosted: Wed Feb 29, 2012 8:14 am    Post subject: Reply with quote  Mark this post and the followings unread
I've just finished this. It works and sounds awesome...
I used 6.8µF Tantalums in place of the 5.6µF Tantalums.
I used 2n3904/2n3906 transistors throughout and none have been matched - as someone mentioned earlier in the thread, there's enough presets to compensate for this.
I'm not sure of the calibration method, but I ran a sine through one input, calibrated until no sound was present, then did the same with the other input. I'm actually liking this more than my Moog ring mod! Really smooth and well rounded sound, even at high frequencies.
