Nord Rack 3 Program Change
Page 1 of 1 [7 Posts]
Marhof45
PostPosted: Wed Aug 12, 2009 5:47 am    Post subject: Nord Rack 3 Program Change Reply with quote  Mark this post and the followings unread
Hi All,
My Nord Rack 3 won't react on a program change. The MIDI Global Channel is 1 and Program change is set to send and receive. But if I change the program via a master midi keyboard or in Cubase 5, nothing happened. Playing the Nord Rack 3 thru Cubase s no problem.
Is there a setting I have to change?
Regards,
Mark
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed Aug 12, 2009 5:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Try controller 32?
Wout
Marhof45
PostPosted: Wed Aug 12, 2009 6:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Wout,
Again, about the program change. When I set the Nord in performance mode, the program change is working and the Nord is skipping through the performances while changing a program or patch on my master keyboard or in Cubase 5, but in program or patch mode it won't, strange.
Ik heb even met een MIDI monitor gecheked, maar mijn Kurzweil stuurt een Controller 32 uit met bijbehorende prg change. Zie attachment. In performance mode werkt het prima, heel vreemd.
[translation]I've checked using a Midi monitor and it appears the Kurzweil sends Midi CC 32 and the Program Change. (See attachment) It works fine in Performance mode, very starnge.
Regards,
Mark
Wout Blommers wrote:
This is electro-music.com and is English spoken Smile
 Filename:  MIDImon.bmp
 Filesize:  1.26 MB
 Downloaded:  242 Time(s)
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed Aug 12, 2009 7:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Is the PrgCh set to send and receive?
If so, try Global Midi channel 16...
Wout
Marhof45
PostPosted: Wed Aug 12, 2009 7:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Wout,
It works!!
Is this standard on the NL Rack 3, because as far as I know I don't have this with other synths.
Thanks for the solution.
regards,
mark
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed Aug 12, 2009 9:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Don't ask me why, but it seems always be the solution to all Clavia synthts: Global Midi Channel 16! Or at least a number higher then the ones used. 16 is mostly the highest...
Wout
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Thu Aug 13, 2009 1:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Marhof45 wrote:
... I've checked using a Midi monitor and it appears the Kurzweil sends Midi CC 32 and the Program Change. (See attachment) It works fine in Performance mode, very strange. ...
So...
Manual NordLead3 V1.2 Page 139 wrote:
If the Global MIDI Channel happens to be set to the same number as one of the Program Slots, the Performance takes precedence. That is, Program Change messages on the Global MIDI Channel will select Performances, not Programs.
Which explains it all Smile That's why channel 16 always works... Uh, almost.
Wout
