Marhof45
Posted: Wed Aug 12, 2009 5:47 am Post subject:
Nord Rack 3 Program Change |
Hi All,
My Nord Rack 3 won't react on a program change. The MIDI Global Channel is 1 and Program change is set to send and receive. But if I change the program via a master midi keyboard or in Cubase 5, nothing happened. Playing the Nord Rack 3 thru Cubase s no problem.
Is there a setting I have to change?
Regards,
Mark |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Wed Aug 12, 2009 5:56 am Post subject:
Try controller 32?
Wout |
Marhof45
Posted: Wed Aug 12, 2009 6:44 am Post subject:
Hi Wout,
Again, about the program change. When I set the Nord in performance mode, the program change is working and the Nord is skipping through the performances while changing a program or patch on my master keyboard or in Cubase 5, but in program or patch mode it won't, strange.
| Quote: | | Ik heb even met een MIDI monitor gecheked, maar mijn Kurzweil stuurt een Controller 32 uit met bijbehorende prg change. Zie attachment. In performance mode werkt het prima, heel vreemd. | [translation]I've checked using a Midi monitor and it appears the Kurzweil sends Midi CC 32 and the Program Change. (See attachment) It works fine in Performance mode, very starnge.
Regards,
Mark | Wout Blommers wrote: | This is electro-music.com and is English spoken |
| Description: |
 Download (listen) |
| Filename: |
MIDImon.bmp |
| Filesize: |
1.26 MB |
| Downloaded: |
234 Time(s) |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Wed Aug 12, 2009 7:07 am Post subject:
Is the PrgCh set to send and receive?
If so, try Global Midi channel 16...
Wout |
Marhof45
Posted: Wed Aug 12, 2009 7:53 am Post subject:
Hi Wout,
It works!!
Is this standard on the NL Rack 3, because as far as I know I don't have this with other synths.
Thanks for the solution.
regards,
mark |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Wed Aug 12, 2009 9:41 am Post subject:
Don't ask me why, but it seems always be the solution to all Clavia synthts: Global Midi Channel 16! Or at least a number higher then the ones used. 16 is mostly the highest...
Wout |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Thu Aug 13, 2009 1:58 pm Post subject:
| Marhof45 wrote: | | ... I've checked using a Midi monitor and it appears the Kurzweil sends Midi CC 32 and the Program Change. (See attachment) It works fine in Performance mode, very strange. ... | So... | Manual NordLead3 V1.2 Page 139 wrote: | | If the Global MIDI Channel happens to be set to the same number as one of the Program Slots, the Performance takes precedence. That is, Program Change messages on the Global MIDI Channel will select Performances, not Programs. | Which explains it all That's why channel 16 always works... Uh, almost.
Wout |
