today> Twyndyllyngs Chez Mosc
What's your personal opinion on the Sound Lab Ultimate?
Page 1 of 1 [9 Posts]
Blendomatic
PostPosted: Tue Aug 11, 2009 5:44 pm    Post subject: What's your personal opinion on the Sound Lab Ultimate? Reply with quote  Mark this post and the followings unread
I'm looking for a nice project this winter that can give me a basic, but nice sounding system with room to grow. What are your thoughts about the MFOS Ultimate? Sounds good? Too pricey? Not pricey enough? I haven't read too many reviews of this beast.
Thanks
jingkon
PostPosted: Mon Aug 24, 2009 11:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
What is your skill level? I just started working on the Soundlab Plus and if you are as experienced as me (a little electronics in High School, but nothing since) I'd suggest starting with the Plus as well. The hardest part for me so far has been not getting too psyched to double check my orders before I click buy...
creatorlars
PostPosted: Fri Aug 28, 2009 11:38 am    Post subject: Reply with quote  Mark this post and the followings unread
I'd reccomend the Soundlab Ultimate over the Soundlab Plus as a first project -- the wiring/PCB is much less confusing and there are no board-mounted components on the Soundlab Ultimate. It is a "bigger" project, but probably "easier" for a newbie.
PostPosted: Fri Aug 28, 2009 1:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
So there must be plenty of room for little tumble weeds to go rolling across the PCB? Laughing Wink
creatorlars
PostPosted: Fri Aug 28, 2009 2:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Err... I mean there are no panel mounted resistors/capacitors/diodes. Wink Those elements were the biggest hassle for me, when building a Soundlab.
PostPosted: Fri Aug 28, 2009 2:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, I thought that's what you meant. Very Happy
I actually get into a bit of "air wiring" from time to time. It's like doing tiny sculptures with wire and solder.
Audio files: 161
PostPosted: Sun Aug 30, 2009 1:32 am    Post subject: Reply with quote  Mark this post and the followings unread
I agree, i usually spend 20mins looking for R666 or whatever value on the pcb only to read in large letters that it is across pot X Y or Z, oops, more vigilance needed Smile Smile , it happens to more people than would admit to Smile .
If i had not already built soundlab V1 with mods to make it the plus version, i would have got the ultimate which is the most distilled version of the original soundlab to date.
thundarr
PostPosted: Sun Aug 30, 2009 3:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
So true... I spent a good 15 minutes today doing this exact thing. Smile
LektroiD
PostPosted: Fri Sep 18, 2009 12:57 am    Post subject: Reply with quote  Mark this post and the followings unread
You have it easy, maybe you should try the stripboard version...
http://electro-music.com/forum/topic-32826.html
LektroiD
